Prosze o pomoc - warto kupić z takimi błędami? logi z VCDS
touran_my
- Auto:: touran
- Imię:: touran
- Podziękował: 5 razy
Jaki koszt napraw patrząc na logi tych 2 touranów, czy auta wartę są uwagi.
Moge gdzieś nieodpłatnie rozszyfrowac VIN aby sprawdzić wyposażenie aut?
Czyżby ten drugi touran miał cofnięty licznik?
PIERWSZY
Friday,18,April,2014,14:32:29:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVGZZZ1TZ5W175679 License Plate: MH
Mileage: 249710km-155162mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 47 52 56 62 72
VIN: WVGZZZ1TZ5W175679 Mileage: 249710km/155162miles
15-Airbags -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L EDC G000SG 6246
Revision: 12345678 Serial number: VWZ7Z0E1984166
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 67DD5D1756980F26359-8032
1 Fault Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
RPM: 882 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.60 V
Bin. Bits: 00001100
Temperature: 11.7°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Part No: 1K0 907 379 K
Coding: 0021190
Shop #: WSC 01150 210 64825
VCID: 3A7BD46375AA42CE9A7-806F
2 Faults Found:
01435 - Brake Pressure Sensor 1 (G201)
00810 - Sensor 1/2 for Brake Pressure
005 - No or Incorrect Basic Setting / Adaptation
Part No: 1K0 820 047 EF
Component: Climatic PQ35 084 0404
Shop #: WSC 00000 000 00000
VCID: 6CD7223B4F7E2C7E58B-8039
2 Faults Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
00898 - Control Circuit A/C compressor
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H37 0803
Revision: 00H37000 Serial number: 00000001743535
Coding: 00890F020004100000120C000000000000087B075C
VCID: 3979CB6F70AC49D693D-806C
Coding: 00065493
Shop #: WSC 00000
No fault code found.
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0CPL07
Coding: 0012338
VCID: 3561C75F5CB4ADB6775-8060
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000042
Part No: 1T0 920 961 AX
Component: KOMBIINSTRUMENT VDD 1014
Coding: 0003403
VCID: 8919FBAFE0CC195643D-80DC
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Coding: 0000011
VCID: 2A5BE423850AF24EEA7-807F
4 Faults Found:
01411 - Temperature Sensor (G18)
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 159
Reset counter: 83
Mileage: 248973 km
Time Indication: 0
Date: 2000.00.00
Time: 19:21:15
Malfunction
Temperature: 205.0°C
Temperature: 70.0°C
01409 - Repeated Flame-Out
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 14
Mileage: 246197 km
Time Indication: 0
Date: 2000.00.00
Time: 19:58:04
Malfunction
Temperature: 39.0°C
02251 - Heater Unit Locked
Fault Priority: 0
Fault Frequency: 1
Reset counter: 14
Mileage: 246197 km
Time Indication: 0
Date: 2000.00.00
Time: 19:58:04
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 20
Reset counter: 81
Mileage: 248877 km
Time Indication: 0
Date: 2000.00.00
Time: 29:36:36
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 290010540808DE
Coding: 3D3F1342078003
VCID: 29591B2F800CF956E3D-807C
Component: IMMO VDD 1014
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0158
Coding: 0000052
VCID: F4E7BA5B974E74BE00B-80A1
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.6 1502
VCID: 3169F34FA8DC81962BD-8064
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 01C802087F2D8505485FC61010CC
VCID: 79F90B6F302C89D6D3D-802C
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Shop #: WSC 00000
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 7 - Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1T0 035 456
Component: 08K Audioverst. 0003
Revision: 00001000 Serial number: 00000000000400
VCID: ECD7A23BCF7EAC7ED8B-80B9
Part No: 1T0 959 702
Coding: 0000052
VCID: F5E1875F9C346DB6375-80A0
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal
Part No: 1K0 035 195 A
Component: Radio BVX 006 0013
Coding: 0010010
VCID: 24470A1BE72E243ED0B-8071
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
VCID: 2F6DF537BEE897663D9-807A
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 306FF64BA3D6889E243-8065
DRUGI
Friday,18,April,2014,12:55:05:62939
VIN: WVGZZZ1TZ6W003178 License Plate: 05MH
Mileage: 280610km-174362mi Repair Order:
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ6W003178 Mileage: 280610km/174362miles
01-Engine -- Status: Malfunction 1010
Revision: 12345678 Serial number: VWZ7Z0E2155452
Coding: 0000072
6 Faults Found:
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 -
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00001100
Temperature: 60.3°C
(no units): 144.0
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
18051 - Please check DTC Memory of Electric Load Controller
P1643 - 000 -
RPM: 1554 /min
Torque: 34.0 Nm
Speed: 12.0 km/h
Load: 14.9 %
Voltage: 14.14 V
Bin. Bits: 00001100
Torque: 160.0 Nm
Bin. Bits: 0 00 0
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Revision: 00T12001
Coding: 0021190
VCID: 408FA68B1376181ED43-8015
1 Fault Found:
Part No: 1K0 820 047 DF
Component: Climatic PQ35 090 0505
VCID: 6BD521274A702B46511-803E
1 Fault Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000001918905
Coding: 00890F210004100000120C000000000000087B075C
Subsystem 1 - Part No: 2K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW357 012 0402
Coding: 00065493
Shop #: WSC 01324
3 Faults Found:
01505 - Bulb for Blinkers; Rear Right (M8)
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 278713 km
Time Indication: 0
ON
Voltage: 14.05 V
ON
ON
OFF
OFF
ON
00988 - Lamp for Brake Light; Right (M10)
Fault Priority: 1
Fault Frequency: 4
Reset counter: 171
Mileage: 279076 km
Time Indication: 0
ON
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
00985 - Right Tail Light (M2)
Fault Priority: 2
Fault Frequency: 3
Reset counter: 171
Mileage: 279085 km
Time Indication: 0
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
Revision: 09025000 Serial number: 0038BD0DCJMF
Coding: 0012338
1 Fault Found:
00532 - Supply Voltage B+
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
VCID: 76E300530132E6AEBEF-8023
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Part No: 1T0 920 962 A
Component: KOMBIINSTRUMENT VDD 1012
Coding: 0003401
Shop #: WSC 00630 210 88377
VCID: 326BFC43ADDABA8E527-8067
Coding: 0000011
5 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 255
Reset counter: 182
Mileage: 476612 km
Time Indication: 0
Date: 2000.00.00
Time: 23:13:16
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Malfunction
Temperature: 14.0°C
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Fault Status: 00101010
Fault Priority: 0
Fault Frequency: 19
Reset counter: 231
Mileage: 258589 km
Time Indication: 0
Date: 2000.00.00
Time: 08:15:55
OFF
Temperature: 158.0°C
Temperature: 17.0°C
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001055140FDF
Coding: 3D0F1340078003
1 Fault Found:
01314 - Engine Control Module
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 279032 km
Time Indication: 0
Date: 2000.00.00
Time: 09:39:31
Component: IMMO VDD 1012
Coding: 0000052
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 3365F94752C0B386591-8066
Component: KSG 0401
Coding: 00C802087F2D8405485BC61010CC
Shop #: WSC 12345 123 45725
Coding: 00000000
Shop #: WSC 00000
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
00893 - Switch for Trunk Handle (E234)
Coding: 0000052
1 Fault Found:
00936 - Electric Window Switch in Front Passenger Door (E107).
Part No: 1K0 035 186 P
Component: Radio BVX 016 0023
Coding: 0020200
-- Pt kwi 18, 2014 19:57 --
PIERWSZY
Coding: 0000072
1 Fault Found:
RPM: 882 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.60 V
Bin. Bits: 00001100
Temperature: 11.7°C
Bin. Bits: 10110000
Coding: 0021190
2 Faults Found:
2 Faults Found:
Coding: 00065493
Shop #: WSC 00000
Coding: 0012338
Coding: 0000042
Coding: 0003403
Coding: 0000011
4 Faults Found:
Fault Priority: 0
Reset counter: 83
Mileage: 248973 km
Time Indication: 0
Date: 2000.00.00
Time: 19:21:15
Malfunction
Temperature: 70.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 14
Mileage: 246197 km
Time Indication: 0
Date: 2000.00.00
Time: 19:58:04
Malfunction
Temperature: 39.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 14
Mileage: 246197 km
Time Indication: 0
Date: 2000.00.00
Time: 19:58:04
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 20
Reset counter: 81
Mileage: 248877 km
Time Indication: 0
Date: 2000.00.00
Time: 29:36:36
Coding: 0000052
Component: KSG 0401
Coding: 00000000
Shop #: WSC 00000
Coding: 0000052
2 Faults Found:
Coding: 0010010
Coding: 0000048
1 Fault Found:
Coding: 0000048
DRUGI
Coding: 0000072
6 Faults Found:
P1641 - 000 -
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00001100
Temperature: 60.3°C
(no units): 144.0
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
P1643 - 000 -
RPM: 1554 /min
Torque: 34.0 Nm
Speed: 12.0 km/h
Load: 14.9 %
Voltage: 14.14 V
Bin. Bits: 00001100
Torque: 160.0 Nm
Bin. Bits: 0 00 0
Revision: 00T12001
Coding: 0021190
1 Fault Found:
1 Fault Found:
Coding: 00065493
Shop #: WSC 01324
3 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 278713 km
Time Indication: 0
ON
Voltage: 14.05 V
ON
ON
OFF
OFF
ON
Fault Priority: 1
Fault Frequency: 4
Reset counter: 171
Mileage: 279076 km
Time Indication: 0
ON
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
Fault Priority: 2
Fault Frequency: 3
Reset counter: 171
Mileage: 279085 km
Time Indication: 0
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
Coding: 0012338
1 Fault Found:
Coding: 0000042
1 Fault Found:
Coding: 0003401
Coding: 0000011
5 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Reset counter: 182
Mileage: 476612 km
Time Indication: 0
Date: 2000.00.00
Time: 23:13:16
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Malfunction
Temperature: 14.0°C
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Fault Priority: 0
Fault Frequency: 19
Reset counter: 231
Mileage: 258589 km
Time Indication: 0
Date: 2000.00.00
Time: 08:15:55
OFF
Temperature: 17.0°C
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 279032 km
Time Indication: 0
Date: 2000.00.00
Time: 09:39:31
Coding: 0000052
Component: KSG 0401
Coding: 00000000
Shop #: WSC 00000
1 Fault Found:
Coding: 0000052
1 Fault Found:
Coding: 0020200
- darekm
- Auto:: Touran, 1.9TDi, `08
- Imię:: Darek
Re: Prosze o pomoc - warto kupić z takimi błędami? logi z VC
witam,
nie ruszałbym ani jednego ani drugiego. chyba że masz możliwość sprawdzenia w serwisie lub u dobrego mechanika! ten drugi to już wogóle same błędy !
pozdr/
pozdr/
touran_my
- Auto:: touran
- Imię:: touran
Ten drugi ma chyba cofnięty licznik z tego co domyślam się patrząc na "mileage" przy którym psuły się odpowiednie rzeczy.
Dopiero wtajemniczam się w to wszystko więc moge być w błędzie
- marnon
- Auto:: Golf V variant
dokładnie ja bym odpuścił oba... za dużo błędów, zbyt dużo spraw do ogarnięcia zbyt rozległe uszkodzenia i pytanie dlaczego tyle tych błędów nałapał - pytanie czy po skasowaniu one powracają ? sprawdzałeś najpierw auto pod kątem blacharskim ? czy nie jest po dzwonie, zalaniu?
ja zawsze zaczynam w ten sposób:
1) dzwonię proszę o VIN - jak czuję że sprzedający jest w miarę sensowny sprawdzam dzięki chłopakom VIN i mam historię z ASO - i mam pierwszy etap zweryfikowany czy odpuszczać bo np. kręcony licznik lub miał naprawę blacharką poważną itp
2) jeśli VIN się zgadza - miernik lakieru i oględziny blacharskie
3) jak dochodzę do tego miejsca to diagnostyka silnika - i tu komputer
4) przejażdżka, ew stacja diagnostyczna
5) negocjacje i zakup
- admin
- Imię:: Maciek
- Podziękował: 24 razy
Błędy prawie nic nie znaczące więc nie ma co przeżywać.
Usunąć, pojeździć, sprawdzić ponownie, jak wrócą to powymieniać drobnostki i tyle.
W pierwszym świeca, nabicie klimy, odblokowanie pieca, w drugim świece + pompa V55 do wymiany - no i tu raczej przebieg duży
touran_my
- Auto:: touran
- Imię:: touran
Sprawdzałem auta miernikiem, 2 był czysty, 1-wszy miał szpachlę na tylnym lewym słupku, prowadził się dobrze, nic nie ściągało, przy hamowaniu, przyspieszaniu.
Ten 2-gi odpada za wzdlędu na błedy jakich jest mnogo jak i wygląd zewnątrzny i wewnątrzny, ten przebieg prawie 500tyś km widac w każdej częsci auta:)
Interesuje mnie ten 1-wszy touran, od czasu gdy zacząłem sprawdzać autko do momentu aż ruszyłem przetestowac na drodze minęło około 30min, czyli silnik zdąrzył trochę się schłodzić...1-wsze co to musiałem dłużej kręcić rozrusznikiem żeby auto zapaliło co mnie zaczęło zastanawiać, ale to może właśnie wina "17057 - Cylinder 3 Glow Plug Circuit (Q12) "
Sprzęgło twardsze niż zazwyczaj, brało w połowie.
O co chodzi z tymi błędami od ABS w 1-wszym aucie?
Jak można sprawdzić historię VIN z ASO dzięki tutejszym chłopakom? któż taki pomocny?
Dobrze myślę że w tym 1-wszym patrząc na log nie działa nawiew? nie sprawdziłem na miejscu;/
- Turanek
- Auto:: 2x5T1
- Podziękował: 23 razy
Po pierwsze popraw tytuł posta, bo jest niezgodny z regulaminem
Temat odpalania na ciepłym i zimnym 1,9l jest na forum, poszukaj.
Przy obecnych temp. zew. i ciepłym silniku to nie ma wpływu.touran_my pisze:1-wsze co to musiałem dłużej kręcić rozrusznikiem żeby auto zapaliło co mnie zaczęło zastanawiać, ale to może właśnie wina "17057 - Cylinder 3 Glow Plug Circuit (Q12)
Pompę ABS'u trzeba rozbierać i wymieniać czujnik - sam tego raczej nie zrobisz. Temat też jest na forum.touran_my pisze:O co chodzi z tymi błędami od ABS w 1-wszym aucie?
trial70
- Auto:: Touran 2,0 BMM DSG 2006
- Imię:: Jarek
- Podziękował: 10 razy
- Otrzymał podziękowań: 22 razy
Z ciekawości mogłeś wkleić linki to by się luknęło na te super bryki... ten drugi jeśli ma tyle śmignięte to szacun że daje jeszcze radę
Jaro-J
- wujo_sam
- Auto:: Touran 2.0
- Podziękował: 68 razy
- Otrzymał podziękowań: 70 razy
Kolego w UK mozez sobie sprawdzic historie samochodu (poszukaj u wujka google i sie dowiesz co i jak). Angole maja to do siebie i jak naprawiaja samochód to nie czyszcza bledow wiec samochod kupujesz 50/50 bo byc moze usterka jest usunieta ale bledy nie wykasowane. Chyba ze ty wykasujesz je i zrobisz sprzedawcy prezent. Ja juz wielokrotnie sie z tym spoktalem przy kupnie samochodu dla siebie czy dla klienta. Duzo szrotow jest wystawionych na sprzedaz (zalezy co dla kogo jest szrot oczywiscie) wiec musisz uwazac. Uslugi sa drogie bo godzna pracy mechanika wynosi od 40-70 funtow a naprawa samochodu przeliczna jest w roboczogodzinach zazwyczaj. Samochod dla ciebie czy na handel?
touran_my
- Auto:: touran
- Imię:: touran
Szukam dla siebie auta.
Ile dziengów trzeba by włożyć w ten czarny aby auto nadawało się do jazdy? oczywiście auto jeździ ale...
Czarny touran sprowadzony został do irlandii w 2009 roku, jedna osoba ma go od tamtego czasu, sprzedaje go teraz bo jak mowi dostal auto po zmarlym wuju-nie wnikalem ile w tym prawdy.
Odnośnie sprawdzania aut z uk to wiem lecz obecny wlasciciel nie ma zadnych potrzebnych do tego danych, w koncu troche czasu minęło.
- magic
- Auto:: Touran 1.6 MPI 2008
- Imię:: Maciej
- Otrzymał podziękowań: 48 razy
tego pierwszego już nie mawięc niemam porównania
ale tak sobie posiedziałem chwile i cos takiego znalazłem http://cars.donedeal.ie/cars-for-sale/0 ... st/6613745 wydaje mi sie fajny , climatronik - rzadko spotykane na IRL rynku wdodatku highline no i cena nie zawysoka proponuje zadzwoń pogadaj mysle że 3900 odda
sprawdź także na adwerts -ie też czasami są fajne turki
never ever give up
