to może ktoś i moje logi oceni
1.9 BLS 2007
na wolnych obrotach buja budą (nie zawsze)
włącza się tryb awaryjny i sprężyna
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 1010
56-Radio -- Status: OK 0000
69-Trailer -- Status: Sporadic communication error 1000
Address 01: Engine Labels: Redir Fail!
2 Faults Found:
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit - Intermittent
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 4
Mileage: 234282 km
Time Indication: 0
Date: 2000.00.00
Time: 18:00:03
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00001100
Temperature: 15.3°C
Bin. Bits: 00110000
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - MIL ON
Fault Status: 11110000
Fault Priority: 1
Fault Frequency: 8
Mileage: 234364 km
Time Indication: 0
Date: 2000.00.00
Time: 15:56:29
RPM: 2457 /min
Speed: 53.0 km/h
Load: 52.2 %
Voltage: 14.36 V
Bin. Bits: 00001000
Absolute Pres.: 1785.0 mbar
Absolute Pres.: 1152.6 mbar
Readiness: 1 1 0 0 0
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
000 - - - Intermittent
2 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 5
Mileage: 234269 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.00 V
OFF
ON
OFF
OFF
OFF
Fault Priority: 2
Fault Frequency: 4
Reset counter: 240
Mileage: 234269 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.00 V
OFF
ON
OFF
OFF
OFF
3 Faults Found:
02245 - Connection; RF Remote Control
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 34
Reset counter: 220
Mileage: 234269 km
Time Indication: 0
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 19
Reset counter: 5
Mileage: 234341 km
Time Indication: 0
OFF
Temperature: 33.0°C
Temperature: 32.0°C
Voltage: 14.24 V
01408 - Under-Voltage Shut-Off (fixed Value)
Fault Priority: 7
Fault Frequency: 1
Reset counter: 251
Mileage: 1048575 km
Time Indication: 0
Full Throt
Temperature: 67.0°C
Temperature: -48.0°C
Voltage: 11.20 V
2 Faults Found:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 13
Reset counter: 3
Mileage: 234269 km
Time Indication: 0
Date: 2000.00.00
Time: 15:04:44
Fault Priority: 2
Reset counter: 4
Mileage: 234269 km
Time Indication: 0
Date: 2000.00.00
Time: 15:03:59
1 Fault Found:
00109 - Left Mirror Turn Signal Lamp (L131)
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 190
Mileage: 234269 km
Time Indication: 0
Date: 2000.00.00
Time: 15:02:18
Address 69: Trailer
Cannot be reached
