Witam , czy może ktoś powiedzieć coś wiecej na temat skanu ? Czarna magia dla mnie.
VCDS Version: Release 12.12.3 (x64)
Data version: 20140822
Saturday,24,October,2015,16:40:45:33490
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 52 56 62 72 77
VIN: WVGZZZ1TZ9W041338 Mileage: 351930km/218679miles
37-Navigation -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 MJ HW: 03G 906 021 AB
Component: R4 2,0L EDC G000SG 2115
Revision: --H08--- Serial number: VWX7Z0H73NF0R8
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 73E3A9971237FA8696F-8026
3 Faults Found:
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 221957 km
Time Indication: 0
Date: 2000.00.00
Time: 11:07:48
RPM: 840 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00101000
Temperature: 17.1°C
Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 221957 km
Time Indication: 0
Date: 2000.00.00
Time: 11:07:48
RPM: 840 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00101000
Temperature: 17.1°C
Bin. Bits: 10110000
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 000 - Open Circuit
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 332628 km
Time Indication: 0
Date: 2000.00.00
Time: 11:22:25
RPM: 840 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 00001000
Temperature: 6.3°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023238
No fault code found.
Part No SW: 1K0 907 044 CT HW: 1K0 907 044 CT
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 7BF381B73A67B2C6CEF-802E
1 Fault Found:
01592 - Air Quality Sensor (G238)
014 - Defective - Intermittent
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008740414
Coding: 01890F2100040F0047120C000000000000097F075C00012C000000000000
VCID: 3363699752B7BA8656F-8066
Subsystem 1 - Part No: 2K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 040808 021 0501
Coding: 00038805
Shop #: WSC 01324
Part No SW: 1T0 909 605 D HW: 1T0 909 605 D
Component: 04 AIRBAG VW8 021 0100
Revision: 02021000 Serial number: 003B9D0A4PWL
Coding: 0012340
Shop #: WSC 01324 020 00200
VCID: 3665508341C5AFAE711-8063
Subsystem 1 - Serial number: 6332QSME781216156
Subsystem 2 - Serial number: 6342QSME7E227653M
Subsystem 3 - Serial number: 6352QSME7B560861L
Subsystem 4 - Serial number: 6362QSME7B30455FS
1 Fault Found:
00532 - Supply Voltage B+
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 752 0101
Coding: 0002022
VCID: 810F735FD88B5816143-80D4
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Part No SW: 1T0 920 874 A HW: 1T0 920 874 A
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: VWX7Z0H73NF0R8
Coding: 0003101
Shop #: WSC 39772 123 90918
VCID: 34616A8B57B9BDBE4F5-8061
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Coding: 0000011
3 Faults Found:
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 10
Reset counter: 199
Mileage: 235446 km
Time Indication: 0
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 41
Reset counter: 159
Mileage: 236948 km
Time Indication: 0
Locked
Temperature: 14.0°C
Temperature: 18.0°C
Voltage: 14.45 V
02251 - Heater Unit Locked
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 159
Time Indication: 0
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 140808F1000995
Coding: E9807F06400E028002
VCID: 3567578F5CC3A4B678B-8060
Component: IMMO VDD 2416
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 B HW: 1T0 035 680 B
Component: RNS-MID H03 0900
Revision: AB001001 Serial number: VWZ6Z7H9238019
Coding: 040004000400002200
VCID: 2D577FEF7493EC7600B-8078
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 2
Reset counter: 227
Mileage: 264824 km
Time Indication: 0
Date: 2000.00.00
Time: 20:26:41
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 M HW: 1T0 959 701 M
Component: Tuer-SG 008 2007
Coding: 0001205
VCID: 418F335F180B1816D43-8014
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A5D74F3857DFB4EE59-807F
Address 46: Central Conv. Labels: 1K0-959-433-MAX.lbl
Component: KSG PQ35 G2 020 0204
Coding: 9A900A8851030C7F2D06840560084F03E0FC00
Shop #: WSC 00148 211 56330
VCID: 83037957C2974A0606F-80D6
1 Fault Found:
01038 - Central Locking Thermal Protection
000 - - - Intermittent
Fault Priority: 4
Fault Frequency: 34
Reset counter: 227
Mileage: 350709 km
Time Indication: 0
Date: 2000.00.00
Time: 10:33:57
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 M HW: 1T0 959 702 M
Coding: 0001205
VCID: 428D3C531D0D030ECD9-8017
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 227
Mileage: 264824 km
Time Indication: 0
Date: 2000.00.00
Time: 20:26:41
Part No SW: 1K0 959 703 AK HW: 1K0 959 703 AK
Component: Tuer-SG 007 2002
Coding: 0001168
Shop #: WSC 01324 785 1012552
VCID: 79FF9BBF305B80D6DC3-802C
Part No SW: 1K0 959 704 AK HW: 1K0 959 704 AK
Coding: 0001168
VCID: 7AFD84B3355D8BCED59-802F
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 HW: 1K8 035 730
Component: Telefon H06 3100
Revision: 00006000 Serial number: 20387920029494
Coding: 012100
VCID: E6C540C311E59F2E811-80B3
Scan tourana
karl
- Auto:: BMN,2.0 tdi,2006
- Imię:: Karol
- Podziękował: 27 razy
- Otrzymał podziękowań: 44 razy
Re: Scan tourana
Wykasować i zobaczyć jakie wrócą
Ale chyba wymiana świec żarowych nieunikniona uwalone trzy sztuki.
Zablokowany dogrzewacz, raczej pompka obiegowa nie działa.Jak odblokować piecyk znajdziesz na forum.
- Letis
- Auto:: Touran 2.0 AZV 2003
- Imię:: Paweł
- Otrzymał podziękowań: 32 razy
Re: Scan tourana
Silnik- swiece lub wiązka do nich . Klimatyzacja - czujnik jakosci powoetrza (blad nieobecny . Zapisany). Airbag - problem z napieciem (slaby akumulator. Blad nieobecny zapisany) webasto - uszkodzona pompka cieczy - dogrzewacz zablokowany. Radio - blad anteny gps (nieobecny zapisany)lusterko kierowcy nie grzeje problem z instalacja - szklem
. Prawe lusterko kierunkpwskaz kiedys nie działał
