Auto nie odpala
Paco75
Auto:: Touran 2.0 TDI 2004 136KM
Imię:: Jarek
Auto nie odpala
Post autor: Paco75 »
Witam mam problem z odpaleniem auta . mianowicie po postoju ok 2dni auto sie niechce nawet odezwać podłączyłem pod kompa i wyszło takie coś. wszystkie błędy pokasowałem i dalej to samo kręci ale sie nie odzywa.PORATUJCIE
Monday,01,February,2021,13:06:06:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.0.2
Data version: 20150729
www.Ross-Tech.com
VIN: WVGZZZ1TZ4W073921 License Plate:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ4W073921 Mileage: 277140km-172206miles
01-Engine -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 AL HW: 028 101 145 0
Component: R4 2,0L EDC G000SG 5249
Revision: 12345678 Serial number: VWZ7Z0C8471177
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 6DC9DEFFED910B6AC426679-8038
No fault code found.
Readiness: 0 0 0 0 0
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023238
VCID: 3A6325A3EC5F6CD2112454D-806E
Part No: 1K0 907 044 BG
Component: ClimatronicPQ35 090 0808
Shop #: WSC 00000 000 00000
Part No SW: 1K0 937 049 L HW: 1K0 937 049 L*
Component: Bordnetz-SG 1.0 H29 0701
Revision: 00029000 Serial number: 00000000245798
Coding: 01890F000004100000120C000000000000
VCID: 38673FABD2537EC2E750BE5-806C
Subsystem 1 - Part No: 1T0 955 119 B Labels: 1TX-955-119.CLB
Component: Wischer WWS A-MPV 0201
Coding: 16711828
Shop #: WSC 00000
1 Fault Found:
Component: 05 AIRBAG VW62 0506 2112
Coding: 0012341
VCID: 72F3CD83F4AFD49219143CD-8026
1 Fault Found:
00532 - Supply Voltage B+
Component: Lenksäulenmodul 012 0030
Coding: 0000042
VCID: 3077078B3A23A682AF80C65-8064
Part No: 1T0 920 860 G
Component: KOMBIINSTRUMENT VDD 3350
Coding: 0000101
Shop #: WSC 00001 001 00001
VCID: 3579369FC54183AAFC769F9-8060
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 1K0 815 007 BT
Component: Standheizer 022 3907
Revision: 00022000 Serial number: 09020188000000
Coding: 0000012
Shop #: WSC 47380 001 104857
VCID: 77E5FC979FCDB1BA2ECAF51-8022
1 Fault Found:
00003 - Control Module
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 75
Mileage: 277143 km
Time Indication: 0
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07522825D
Coding: E9807F06000A020101
Shop #: WSC 06314 123 12345
1 Fault Found:
01304 - Radio
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 115
Mileage: 267646 km
Time Indication: 0
Date: 2000.00.00
Time: 18:28:48
Component: IMMO 3350
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0111
Coding: 0000116
VCID: 74FFCB9B8EBBDAA20BE82A5-8020
Part No: 1K1 909 144 E
Component: EPS_ZFLS Kl.7 1202
VCID: 2D491EFF2D11CB6A84A6279-8078
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 01E802087F2D8404084F0180
Part No: 1T0 959 702
Coding: 0000116
VCID: 75F9F69F85C1C3AA3CF6DF9-8020
Address 56: Radio
Cannot be reached
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 05 0107
Coding: 0000048
VCID: 2F7504F7271DB97AB6BADD1-807A
Part No: 1K0 959 704 B
Coding: 0000048
End-------------------------(Elapsed Time: 01:33)--------------------------
Dziadek13
Auto:: Touran '04 1.9TDI AVQ
Imię:: Jorg
Podziękował: 12 razy
Otrzymał podziękowań: 68 razy
Re: Auto nie odpala
Post autor: Dziadek13 »
Błąd 00532 zapisuje się jak są problemy z napięciem np alternatorem lub akumulatorem
Słaby akumulator i słabe kontakty mogą spowodować taki błąd.
Sprawdził bym klemy połączenia masowe i podmieniłbym akumulator,może być już słaby.
1-połączenie masy z silnikiem
2-połączenie złącza alternatora
3-złącze sterownika silnika
Ale mnie to wygląda że wszystkie błędy robi niskie napięcie lub nie kontakty.
Ale błąd 01064 oświetlenia ściemniania wnętrza to już trza szukać.
Ogólnie od napięcia takie jest moje zdanie, może ktoś coś więcej napisze.
Jaki masz spadek napięcia na aku i po za klemami.
