Prośba o analizę VCDS
DANIOB
Post autor: DANIOB »
Wtam
Proszę o pomoć w rozszyfrowaniu scanu VCDS, ponieważ mam kilka problemów z moim tourankiem.
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ4W168404 Mileage: 166930km/103725miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Sporadic communication error 1000
56-Radio -- Status: Not registered 0011
Part No SW: 03G 906 016 BT HW: 028 101 176 1
Component: R4 1,9L EDC G000SG 5644
Revision: 12345678 Serial number: VWZ7Z0D9736829
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 76E7E2EB7DE3
No fault code found.
Readiness: 0 0 0 0 1
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021190
VCID: 3A7F36DB097B
Part No: 1K0 907 044 K
Component: ClimatronicPQ35 061 0201
Shop #: WSC 00000 000 00000
VCID: 2F69178FC239
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 K HW: 1K0 937 049 K*
Component: Bordnetz-SG 1.0 H30 0701
Revision: 00030000 Serial number: 00000000696847
Coding: 00890F020004200000120C000000000000
VCID: 37792FEF3A69
Subsystem 1 - Part No: 1T0 955 119 C
Coding: 00065493
Shop #: WSC 00000
3 Faults Found:
00059 - Terminal 30 for Interior Lighting
02399 - Control Circuit for Terminal 30 for Interior Illumination
009 - Open or Short to Ground - Intermittent
Part No SW: 1T0 909 605 B HW: 1T0 909 605 B
Component: 02 AIRBAG VW62 0506 1400
Revision: 07023000 Serial number: 0037SD07530N
Coding: 0012338
VCID: 346318E32B1F
Component: Lenksäulenmodul 012 0030
Coding: 0000042
VCID: 306B14F3DF07
Part No: 1T0 920 860 G
Component: KOMBIINSTRUMENT VDD 3354
Coding: 0003101
Shop #: WSC 00011 888 96745
VCID: 356525E72065
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Coding: 0000011
Shop #: WSC 00397 211 84961
VCID: 2A5F069BF9DB
5 Faults Found:
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 0
Reset counter: 164
Mileage: 232469 km
Time Indication: 0
Date: 2000.00.00
Time: 29:09:27
OFF
Temperature: 84.0°C
Temperature: 14.0°C
000 - - - Intermittent
Fault Priority: 0
Reset counter: 164
Mileage: 232469 km
Time Indication: 0
Date: 2000.00.00
Time: 29:09:27
00003 - Control Module
014 - Defective - Intermittent
Fault Priority: 0
Reset counter: 164
Mileage: 232469 km
Time Indication: 0
Date: 2000.00.00
Time: 29:09:27
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 14
Reset counter: 80
Mileage: 221485 km
Time Indication: 0
Date: 2000.00.00
Time: 17:03:13
01320 - Control Module for Climatronic (J255)
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 48
Mileage: 260070 km
Time Indication: 0
Date: 2000.00.00
Time: 13:50:12
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 260010432400CF
Coding: 3D0F1300078002
Shop #: WSC 00397 211 57993
VCID: 2759FFAFEAC9
2 Faults Found:
000 - -
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 141
Reset counter: 164
Mileage: 166133 km
Time Indication: 0
Date: 2000.00.00
Time: 00:10:59
00474 - Control Module for Immobilizer
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Time Indication: 0
Date: 2000.00.00
Time: 16:16:38
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3354
VCID: 356525E72065
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0127
Coding: 0000052
VCID: F4E358E3EB9F
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.6 1301
VCID: 2E570A8BC533
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 00E802087F2D8404084B0100
VCID: 306B14F3DF07
Part No: 1T0 959 702
Coding: 0000052
VCID: F5E565E7E0E5
Part No: 1K0 035 186 AD
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2H7319518
Coding: 0040401
Shop #: WSC 05314 000 00000
VCID: 68DBBC932757
4 Faults Found:
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit - Intermittent
00873 - Bass Speaker Rear Right (R17)
00876 - Treble Speaker Rear Left (R14)
00877 - Treble Speaker Rear Right (R16)
Ponadto chciałbym powiedzieć, że po sprowadzeniu samochodu miałem problem z ciężkim odpalaniem samochodu jak był ciepły (temat często poruszany na naszych forach), nie mniej jednak mechanik do którego podjechałem powiedział mi, że nie ma co się pakować w koszty "mapowania silnika" bo wystarczy zmniejszyć napięcie (niestety nie wiem gdzie), co też zrobił i problem ciężkiego palenia przestał istnieć.
Teraz natomiast mam problem z:
1. zapalającymi się w trakcie jazdy kontrolkami świec żarowych (na forach czytałem, że to może być problem czujnika pod pedałem hamulca - światła stop)
2. utratą mocy i jakimś świstem przy dodawaniu gazu (czytałem że to najprawdopodobniej jest problem turbiny, bo wszystkie rurki dolotowe i wylotowe są ok.)
Nie mniej jednak, jako, że dopiero niedawno zacząłem przygodę z Touranem i programem VCDS nie wiem, czy w/w problemy mogę w jakiś sposób powiązać z błędami wykazanymi przy auto scanie, dlatego też zwracam się z prośbą o pomoc.
Przede wszystkim, błąd jaki popełniłeś to założenie nowego wątku, ponieważ analizą błędów zajmujemy się w innych tematach.
QQRYDZA
Auto:: 1,9tdi
Imię:: dar
Post autor: QQRYDZA »
Daniob przywitaj się w innym dziale i na pewno dostaniesz szybciej odpowiedz ;)
[you]--->Niebieski
ZWzPD
Darku, kolega się przywitał, przeoczyłeś :>
QQRYDZA
Auto:: 1,9tdi
Imię:: dar
a to sorry wielkie,zwracam honor ;)
[you]--->Niebieski
ZWzPD
DANIOB
Przeglądałem fora i widziałem kilka tematów w "ogólnej technice" dotyczących analizy VCDS i nikt tego nie negował więc i ja napisałem tutaj, bo gdzie indziej nie widziałem.
Nie mniej jednak dziękuje za uwagę następnym razem napiszę na właściwym forum :)
QQRYDZA
Auto:: 1,9tdi
Imię:: dar
-Immobilizer -- Status: Sporadic communication error 1000 -problem a hakiem
jak z twoim aku?
i jakie masz radio? ewentualnie kodowanie?
[you]--->Niebieski
ZWzPD
DANIOB
Akumulator mam ok. Radio po sprowadzeniu było jakieś Sony, ja zmieniłem na RCD 300 mp3 i wszystko sprawnie działa do tej pory. Niestety nie robiłem adaptacji tego radia, ponieważ nie miałem odpowiedzniego programu dziwią mnie też błędy chyba tylnych głośników - z tego co się oriętuję to wcale nie mam głośników w tylnych drzwiach.
QQRYDZA
Auto:: 1,9tdi
Imię:: dar
Bo być może kodowanie jest złe ;)
a co z hakiem?
[you]--->Niebieski
ZWzPD
Troche roboty masz..
Piszesz że aku jest ok, ale ja bym go bardziej sprawdził..Webasto do roboty-sprawdzić pompke.-->pytaj "Jarry" albo aledrogo, ebay.
Do sprawdzenia przekaźnik świec żarowych..Czujnik pod pedału hamulca to najczęstsza przypadłość Passata B5.
Kodowanie też jest nieteges :mrgreen:
Radio zostawił bym na sam koniec.
W twojej miejscowości jest dużo forumowiczów więc możesz liczyć na pomoc. ;)
P.S Gdy pisałem tego posta to już są 4 odpowiedzi.......ale szybko chłopaki działacie :ok:
DANIOB
Niedawno dostałem program do diagnozy, więc kodowanie radia sobie zrobię, aku też sprawdzę raz jeszcze, następnie sprawdzę przekaźniki świec a jak to nie pomoże to będę temat drążył dalej. Natomiast nie wiem o co chodzi z tym hakiem?
[ Dodano: Sob Lis 03, 2012 21:58 ]
Nie mniej jednak dziękuję za porady :piwo:
DANIOB,
śledź kolego temat o spotach regionalnych - napisz przywitanie i automatycznie będziesz śledził temat (nowe wiadomości będą przychodzić na e-mail) to Cię spotkanie warszawskie nie ominie.
DANIOB
Spoko, Spoko przywitanie napisałem 23.10.12 a do grupy mazowieckiej dołączę niedługo :)
Dodi
Auto:: Sharan 7N CFGB
Otrzymał podziękowań: 58 razy
Post autor: Dodi »
tak sobie patrze na ten autoscan i widze, że ktoś chyba zapomniał wykasować błędów po cofnięciu przebiegu... ;)
admin
Imię:: Maciek
Post autor: admin »
Dodi pisze:tak sobie patrze na ten autoscan i widze, że ktoś chyba zapomniał wykasować błędów po cofnięciu przebiegu... ;)
No tak, ostatni błąd z dogrzewacza przy 260kkm, chyba kolego z połowę km zdjęli Ci z licznika przed sprzedażą :)
Jak błędów sprzedawca nie skasował to sprawdź VCDSem przebieg w sterowniku - pewnie też nie zmieniony ;)
