Błędy z Autoscanu
- Auto:: 5T 1,6 CRKB 2016
- Imię:: Staniaław
- Podziękował: 7 razy
witam póki co znowu wyjechałem i nie mam dostępu do auta
mam jeszcze scan przed uszczelnieniem intercoolera
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 18 19 25 3D 42 44 46 52 56 62 72 76
77
VIN: WVGZZZ1TZ5W037214 Mileage: 335580km/208519miles
02-Auto Trans -- Status: OK 0000
15-Airbags -- Status: OK 0000
3D-Special Function -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Part No SW: 03G 906 016 DK HW: 028 101 194 6
Component: R4 1,9L EDC G000AG 6247
Revision: 12345678 Serial number: VWZ7Z0D0318158
Coding: 0000078
Shop #: WSC 34614 142 09746
VCID: 6FE7CD657E862D1
2 Faults Found:
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
RPM: 2562 /min
Torque: 146.0 Nm
Speed: 52.0 km/h
Load: 49.0 %
Voltage: 14.44 V
Bin. Bits: 00001000
Absolute Pres.: 1774.8 mbar
Absolute Pres.: 1101.6 mbar
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 000 - Signal too High
RPM: 840 /min
Torque: 24.0 Nm
Speed: 10.0 km/h
Load: 3.1 %
Voltage: 14.36 V
Bin. Bits: 00001000
Temperature: 43.2°C
Temperature: 36.0°C
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 R HW: 02E 927 770 AD
Component: GSG DSG 041 0812
Revision: 00004010 Serial number: 00000407220488
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 2143FB5DF8D2CB1
No fault code found.
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021190
VCID: 3A712C317544B89
Part No: 1K0 820 047 CE
Component: Climatic PQ35 050 0303
Shop #: WSC 00000 000 00000
VCID: 69D3A37D4062C31
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K1 937 049 HW: 1K1 937 049 *
Component: Bordnetz-SG 1.0 H30 0201
Revision: 00H30000 Serial number: 00000000890364
Coding: 018B8F0000041000001200000000000000
VCID: EDDB576DF48A5F1
Coding: 00065493
Shop #: WSC 00000
4 Faults Found:
00985 - Right Tail Light (M2)
01519 - Bulb for Back-Up Lights; Right (M17)
00380 - Special Vehicle Control Module (J608)
Part No SW: 1T0 909 605 B HW: 1T0 909 605 B
Component: 02 AIRBAG VW62 0506 1400
Revision: 07023000 Serial number: 0037SD08HW8U
Coding: 0012338
VCID: 346D020957204E9
Component: Lenksäulenmodul 012 0030
Coding: 0010042
VCID: 30650E19A338729
Part No: 1T0 920 871 A
Component: KOMBIINSTRUMENT VDD 0812
Coding: 0007103
Shop #: WSC 00012 000 00000
VCID: 31630B1DA8327B1
Part No: 1K0 815 007 BG
Component: Standheizer 021 3803
Revision: 00021000 Serial number: 09011559000000
Coding: 0001112
Shop #: WSC 34614 142 86913
VCID: 6AD1DC714564C89
4 Faults Found:
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
01410 - Heater Over-Temp
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 148.0°C
Temperature: 32.0°C
02251 - Heater Unit Locked
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 26001047220566
Coding: 3F3F17C1078002
VCID: 2757E54596F6351
Component: IMMO VDD 0812
Shop #: WSC 01942 161 63991
Address 3D: Special Function Labels: None
Part No SW: 1T0 907 427 HW: 1T0 907 427
Component: MFG 010 X411
Revision: M0010000 Serial number: 00000000001652
Coding: 0101010101
Shop #: WSC 40380 123 17214
VCID: F2E14411EDB4809
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0157
Coding: 0000116
VCID: F4ED420997A08E9
1 Fault Found:
00120 - Outside Warning Light/Door exit Light Driver Side
Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.6 1401
VCID: 2F670D65BE066D1
Address 46: Central Conv. Labels: 1K0-959-433-MIN.lbl
Part No SW: 1K0 959 433 J HW: 1K0 959 433 J
Component: 01 KSG PQ35 G2 031 0308
Revision: 00031000 Serial number: 00000000000000
Coding: 80E802087F2D8404084F016001
VCID: 377735054656A51
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Part No: 1T0 959 702
Coding: 0000116
VCID: F5EB7F0D9CDA971
Part No: 1K0 035 186 P
Component: Radio BVX 016 0023
Coding: 0010400
VCID: 336F0115522E491
3 Faults Found:
01042 - Control Module; Not Coded
000 - -
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
Part No: 1K0 959 704 B
Coding: 0000048
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 02 Einparkhilfe 0101
VCID: 2D5B176DB40A1F1
1 Fault Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
009 - Open or Short to Ground
Address 77: Telephone Labels: 1K0-035-729-UNI.lbl
Part No: 1K0 035 729 E
Component: CIB PAH HW 202 SW 0308
Coding: 0000364
VCID: 2B5F19758A1E111
uszczelniłem potem rurę intercoolera
mechanior chciał mi wkręcić dwa wkręty bo ząbki w rurze wyrobione ale nie pozwoliłem i zastosowaliśmy taki prowizoryczny mostek tzn dwie opaski kablowe ściągnięte kolejnymi opaskami
auto odzyskało moc i nie miałem już czasu podłączyć kabelka
moje pytanka
-czy błędy turbiny mogły być spowodowane tą nieszczelnością
-o co chodzi z tym bo się powtarza 16502 - Engine Coolant Temp. Sensor (G62)
-o co chodzi z radiem
Chassis Type: 1K0
77
Coding: 0000078
2 Faults Found:
RPM: 2562 /min
Torque: 146.0 Nm
Speed: 52.0 km/h
Load: 49.0 %
Voltage: 14.44 V
Bin. Bits: 00001000
RPM: 840 /min
Torque: 24.0 Nm
Speed: 10.0 km/h
Load: 3.1 %
Voltage: 14.36 V
Bin. Bits: 00001000
Temperature: 43.2°C
Temperature: 36.0°C
Coding: 0000020
Coding: 0021190
Coding: 00065493
Shop #: WSC 00000
4 Faults Found:
Coding: 0012338
Coding: 0010042
Coding: 0007103
Coding: 0001112
4 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 32.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Coding: 0101010101
Coding: 0000116
1 Fault Found:
Coding: 0000116
Coding: 0010400
3 Faults Found:
000 - -
011 - Open Circuit
011 - Open Circuit
Coding: 0000048
Coding: 0000048
1 Fault Found:
Coding: 0000364
moje pytanka
- darek8677
- Auto:: Touran'06BXE 105KM
- Imię:: Darek
witam,
robilem auto-scan i wyskoczył mi taki błąd:
Address 01: Engine Labels: None
Part No SW: 03G 906 021 KC HW:
Component: R4 1 9L EDC G000SG 9243
Revision: --H03--- Serial number: VWZ7Z0F3756503
Coding: 0000072
Shop #: WSC 04330 995 88871
VCID: 6ADFC69B3CEF
1 Fault Found:
012547 - Motor for Intake Manifold Flap (V157): Malfunction
P3103 - 000 - - - Intermittent
Fault Priority: 0
Fault Frequency: 1
Mileage: 200109 km
Time Indication: 0
Date: 2000.00.00
Time: 18:57:22
RPM: 1071 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.87 V
Bin. Bits: 00001100
Torque: 161.0 Nm
Torque: 0.0 Nm
Readiness: 0 0 0 0 0
Po skasowaniu juz sie nie pojawia (narazie) Rozumiem z tego ze jast to silnik klapy gaszącej przepustnicy i jest to bląd sporadyczny. Jest sie czym przejmowac o ile pojawi sie na nowo? dodam ze w tym czasie kiedy sie pojawil widzac po kilometrach jechalismy nad morze jakies 500km. Niczym sie to nie objawiło typu; spadek mocy czy telepanie przy gaszeniu itd. Teraz tez jezdzilem po skasowaniu bledu i wszystko jest w porządku. Miał ktos stycznosc z takim błędem? Pozdrawiam
Coding: 0000072
VCID: 6ADFC69B3CEF
1 Fault Found:
Fault Priority: 0
Fault Frequency: 1
Mileage: 200109 km
Time Indication: 0
Date: 2000.00.00
Time: 18:57:22
RPM: 1071 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.87 V
Bin. Bits: 00001100
Torque: 161.0 Nm
Torque: 0.0 Nm
ZWzPD
280<kkm;)
280<kkm;)
- marnon
- Auto:: Golf V variant
- Podziękował: 5 razy
proszę was o pomoc w rozkodowaniu błędów:
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ8M276362 Mileage: 187030km/116215miles
01-Engine -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 021 TQ HW: 03G 906 021 AB
Component: R4 1,9L EDC 000SG 1781
Revision: --H07--- Serial number: VWX7Z0H324D0RJ
Coding: 0000071
Shop #: WSC 00066 000 00000
VCID: 810D0137A42D
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021121
VCID: 73E1DBFF6E91
Part No SW: 1K0 820 047 HB HW: 1K0 820 047 HB
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
VCID: 6BD1C39F36A1
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000000897204
Coding: 01890F2700041500470000001C00000000097F075C000100000000000000
VCID: 71EDD1F7148D
Subsystem 1 - Part No: 1K1 955 119 E
Component: Wischer 100408 021 0501
Coding: 00038805
Shop #: WSC 00066
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 5P AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1VAB0G
Coding: 0013648
VCID: 3D753DC71855
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0100
Coding: 0000012
VCID: 7F0907CF52D9
4 Faults Found:
00576 - Terminal 15
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Part No SW: 1K0 920 874 M HW: 1K0 920 874 M
Component: KOMBIINSTRUMENT 3HL 2220
Revision: V0002000 Serial number: VWX7Z0H324D0RJ
Coding: 0003103
Shop #: WSC 75426 146 102541
VCID: 37792FEF3A69
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 060308F1002125
Coding: E9807F060002022002
VCID: 306B14F3DF07
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3HL 2220
VCID: 37792FEF3A69
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1133
Revision: 32008001 Serial number: 00000126788407
Coding: 0000180
VCID: 3B7133DF0641
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 356525E72065
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Component: KSG PQ35 G2 020 0204
Coding: 8090020052830C7F2D04840560084F03E0FC00
VCID: 83010B3FBE31
1 Fault Found:
00332 - Control Circuit for Tank Flap
Fault Status: 00100111
Fault Priority: 4
Fault Frequency: 254
Reset counter: 150
Mileage: 174422 km
Time Indication: 0
Date: 2000.00.00
Time: 11:56:48
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1133
Revision: 32008001 Serial number: 00000033988116
Coding: 0000180
VCID: 3C7330C3034F
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 156 HW: 1K0 035 156
Component: Radio 013 0023
Revision: R0013000 Serial number: VWZAZ1G6816546
Coding: 0000020002
Shop #: WSC 75426 146 97922
VCID: E0CB24B34F67
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1120
Revision: 11006001 Serial number: 00000002943464
Coding: 0000144
VCID: 3D753DC71855
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1120
Revision: 11006001 Serial number: 00000002916565
Coding: 0000144
VCID: 3E773ACB1553
Chassis Type: 1K0
Coding: 0000071
VCID: 810D0137A42D
Revision: 00H11001
Coding: 0021121
VCID: 73E1DBFF6E91
VCID: 6BD1C39F36A1
VCID: 71EDD1F7148D
Coding: 00038805
Shop #: WSC 00066
Coding: 0013648
VCID: 3D753DC71855
Coding: 0000012
VCID: 7F0907CF52D9
4 Faults Found:
00576 - Terminal 15
Coding: 0003103
VCID: 37792FEF3A69
VCID: 306B14F3DF07
VCID: 37792FEF3A69
Coding: 0000180
VCID: 3B7133DF0641
VCID: 356525E72065
VCID: 83010B3FBE31
1 Fault Found:
Fault Priority: 4
Reset counter: 150
Mileage: 174422 km
Time Indication: 0
Date: 2000.00.00
Time: 11:56:48
Coding: 0000180
VCID: 3C7330C3034F
Coding: 0000020002
VCID: E0CB24B34F67
Coding: 0000144
VCID: 3D753DC71855
Coding: 0000144
VCID: 3E773ACB1553
- Rafik
- Auto:: Passat 2007 2.0 140KM DSG
- Imię:: Rafał
- Podziękował: 3 razy
Witam zarzucam scan z Turka kolegi
może rzucicie okiem
Friday,02,August,2013,08:44:56:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 18 19 25 37 42 44 46 52 56 62 72 76
VIN: WVGZZZ1TZ5W04.... Mileage: 204830km/127275miles
76-Park Assist -- Status: OK 0000
Revision: 12345678 Serial number: VWZ7Z0D0387688
Coding: 0000078
Shop #: WSC 00066 001 57865
1 Fault Found:
18051 - Please check DTC Memory of Electric Load Controller
P1643 - 000 - - Intermittent
RPM: 1512 /min
Torque: 114.0 Nm
Speed: 9.0 km/h
Load: 40.0 %
Voltage: 14.14 V
Bin. Bits: 00001000
Torque: 216.0 Nm
Bin. Bits: 0 00 0
Revision: 00004010 Serial number: 00000407080192
Coding: 0000020
Coding: 0021190
Cannot be reached
Address 09: Cent. Elect. Labels: User\3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000001018864
Coding: 098B8F020004200000120C000000000000
VCID: 40855ED91398E29
Coding: 00065493
Shop #: WSC 00000
3 Faults Found:
01598 - Drive Battery Voltage
01049 - Supply Voltage Term 50
006 - Short to Plus - Intermittent
00924 - Relay for Headlamp Cleaning System (J39)
Revision: 07023000 Serial number: 0037SD08PTN7
Coding: 0012338
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 500 0010
Coding: 0012042
Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0030
Address 17: Instruments Labels: User\1K0-920-xxx-17.lbl
Part No: 1T0 920 861 A
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0007103
Shop #: WSC 00999 444 64523
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Coding: 0000011
VCID: 2A511C7185E4089
5 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 106
Reset counter: 54
Mileage: 195462 km
Time Indication: 0
Date: 2000.00.00
Time: 25:52:08
01411 - Temperature Sensor (G18)
Fault Priority: 0
Reset counter: 75
Mileage: 197271 km
Time Indication: 0
Date: 2000.00.00
Time: 22:59:33
Malfunction
Temperature: 205.0°C
Temperature: 88.0°C
01409 - Repeated Flame-Out
Fault Priority: 0
Fault Frequency: 1
Reset counter: 167
Mileage: 182459 km
Time Indication: 0
Date: 2000.00.00
Time: 07:37:17
Malfunction
Temperature: 55.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 167
Mileage: 182459 km
Time Indication: 0
Date: 2000.00.00
Time: 07:37:17
Fault Priority: 0
Fault Frequency: 1
Reset counter: 167
Mileage: 182459 km
Time Indication: 0
Date: 2000.00.00
Time: 07:37:17
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104728000B
Coding: 3F3F1748078002
Shop #: WSC 26158 136 61581
VCID: 2953E37D80E2031
Component: IMMO VDD 0814
Address 37: Navigation Labels: 1T0-919-887.lbl
Part No: 1T0 919 887 B
Component: Navigation 0311
Coding: 0000002
Shop #: WSC 01279 785 00200
VCID: 41835BDD1892EB1
Coding: 0000116
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 98E802087F2D8404084F016011
VCID: 7BFFE9353AFE411
Coding: 0000116
Address 56: Radio Labels: 1T0-035-095.lbl
Part No: 1T0 035 095
Component: Radio 0311
Coding: 0001400
VCID: EBDF5975CA9E511
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
Coding: 0000048
Coding: 0000048
Chassis Type: 1K0
Coding: 0000078
1 Fault Found:
RPM: 1512 /min
Torque: 114.0 Nm
Speed: 9.0 km/h
Load: 40.0 %
Voltage: 14.14 V
Bin. Bits: 00001000
Torque: 216.0 Nm
Bin. Bits: 0 00 0
Coding: 0000020
Coding: 0021190
Cannot be reached
Coding: 00065493
Shop #: WSC 00000
3 Faults Found:
Coding: 0012338
Coding: 0012042
Coding: 0007103
Coding: 0000011
5 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Reset counter: 54
Mileage: 195462 km
Time Indication: 0
Date: 2000.00.00
Time: 25:52:08
Fault Priority: 0
Reset counter: 75
Mileage: 197271 km
Time Indication: 0
Date: 2000.00.00
Time: 22:59:33
Malfunction
Temperature: 88.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 167
Mileage: 182459 km
Time Indication: 0
Date: 2000.00.00
Time: 07:37:17
Malfunction
Temperature: 55.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 167
Mileage: 182459 km
Time Indication: 0
Date: 2000.00.00
Time: 07:37:17
Fault Priority: 0
Fault Frequency: 1
Reset counter: 167
Mileage: 182459 km
Time Indication: 0
Date: 2000.00.00
Time: 07:37:17
Coding: 0000002
Coding: 0000116
Coding: 0000116
Coding: 0001400
1 Fault Found:
Coding: 0000048
Coding: 0000048
TDI To Doch Idze
- areczek
Proszę was o pomoc w rozkodowaniu błędów i ich usuniecu
Z gory bardzo dziekuje
VIN: WVGZZZ1TZ3W011449 Mileage: 244090km/151670miles
18-Aux. Heat -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Malfunction 0010
Part No SW: 03G 906 016 BT HW: 028 101 073 1
Component: R4 1,9L EDC G000SG 5644
Revision: 12345678 Serial number: VWZ7Z0C7419021
Coding: 0000072
VCID: 76E7E2EB7A07
Readiness: 0 0 1 1 1
Part No: 1K0 907 379 D
Coding: 0053958
VCID: 33611BFF29F5
Part No: 1T0 907 044 R
Component: ClimatronicPQ35 040 0202
VCID: 3F8947CF15BD
1 Fault Found:
01272 - Positioning Motor for Central Flap (V70)
Part No SW: 1K0 937 049 G HW: 1K0 937 049 G*
Component: PQ35 BordnetzSG 1.0 0302
Revision: 12345678 Serial number: 00000000034362
Coding: 01890F000004100000120C000000000000
VCID: 33611BFF29F5
Subsystem 1 - Part No: 1T0 955 119 A
Component: Wischer WWS A-MPV 0101
Coding: 16711700
Shop #: WSC 00000
10 Faults Found:
004 - No Signal/Communication
00978 - Lamp for Low Beam; Left (M29)
01320 - Control Module for Climatronic (J255)
00466 - Control Module for Steering Column Electronics (J527)
01331 - Door Control Module; Driver Side (J386)
02397 - Parking Light Right Rear (M2)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Component: 04 AIRBAG VW62 0102 2112
Coding: 0012340
VCID: F2EF5EFB966F
1 Fault Found:
00532 - Supply Voltage B+
Component: Lenksäulenmodul 007 0030
Coding: 0000042
VCID: 306B14F3D8E3
Part No: 1T0 920 860 A
Component: KOMBIINSTRUMENT VDD 1312
Coding: 0001101
Shop #: WSC 00352 211 14820
VCID: 2F69178FC5DD
2 Faults Found:
00457 - Control Module for Network (J519)
Cannot be reached
Part No SW: 1K0 907 530 A HW: 1K0 907 951
Component: Gateway H06 0020
Revision: 06 Serial number: 00000133042E82
Coding: 3D3F1340078002
VCID: 2545F5A79721
1 Fault Found:
Fault Status: 01100100
Fault Priority: 2
Reset counter: 77
Mileage: 223261 km
Time Indication: 0
Date: 2000.00.00
Time: 08:49:55
Component: IMMO 1312
VCID: 2F69178FC5DD
Part No: 1K0 959 701 B
Component: Tuersteuergeraet 08 1915
Coding: 0000116
VCID: 2D550D87CFD1
Part No: 1K1 909 143 K
Component: EPS_ZFLS Kl.0 0308
VCID: 326F1EFBD6EF
Part No: 1K0 959 433 C
Component: KSG 0545
Coding: 18E802087F2D8404084F0100
Shop #: WSC 00240 211 05075
VCID: 306B14F3D8E3
Part No: 1K0 959 702 B
Coding: 0000116
VCID: 2E570A8BC2D7
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio PM6 016 0021
Revision: 00016000 Serial number: VWZ5Z7E2044282
Coding: 0040400
VCID: 204BE4B38803
3 Faults Found:
02218 - Satellite Radio (R146)
Fault Status: 01110100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 12
Mileage: 242787 km
Time Indication: 0
Date: 2000.00.00
Time: 00:10:00
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 212
Mileage: 232308 km
Time Indication: 0
Date: 2000.00.00
Time: 05:15:01
000 - -
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 12
Reset counter: 12
Mileage: 1048575 km
Time Indication: 0
Component: Tuersteuergeraet 04 0014
Coding: 0000048
VCID: 2F69178FC5DD
Coding: 0000048
VCID: 306B14F3D8E3
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
Coding: 0000072
VCID: 76E7E2EB7A07
Coding: 0053958
VCID: 33611BFF29F5
VCID: 3F8947CF15BD
1 Fault Found:
VCID: 33611BFF29F5
Coding: 16711700
Shop #: WSC 00000
10 Faults Found:
Coding: 0012340
VCID: F2EF5EFB966F
1 Fault Found:
Coding: 0000042
VCID: 306B14F3D8E3
Coding: 0001101
VCID: 2F69178FC5DD
2 Faults Found:
Cannot be reached
VCID: 2545F5A79721
1 Fault Found:
Fault Priority: 2
Reset counter: 77
Mileage: 223261 km
Time Indication: 0
Date: 2000.00.00
Time: 08:49:55
VCID: 2F69178FC5DD
Coding: 0000116
VCID: 2D550D87CFD1
VCID: 326F1EFBD6EF
Component: KSG 0545
VCID: 306B14F3D8E3
Coding: 0000116
VCID: 2E570A8BC2D7
1 Fault Found:
Coding: 0040400
VCID: 204BE4B38803
3 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 12
Mileage: 242787 km
Time Indication: 0
Date: 2000.00.00
Time: 00:10:00
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 212
Mileage: 232308 km
Time Indication: 0
Date: 2000.00.00
Time: 05:15:01
000 - -
Fault Priority: 3
Fault Frequency: 12
Reset counter: 12
Mileage: 1048575 km
Time Indication: 0
Coding: 0000048
VCID: 2F69178FC5DD
Coding: 0000048
VCID: 306B14F3D8E3
1 Fault Found:
- Auto:: 1T1
- Imię:: -
- Podziękował: 32 razy
areczek, co do błędu 00935 spróbuj zrobić adaptację http://wiki.ross-tech.com/wiki/index.php/00935
, a co robiłeś z radiem?
z dogrzewacza tak jak Ci mówłem nie masz odpowiedzi... w zimę lipa
zerkinij tutaj http://touranklub.pl/forum/viewtopic.php?t=3721
Witam, mam problem braku mocy w moim turku, przy okolo 30 tyś obrotów silnik zaczyna buczeć i się trząsć . Do go słychać jakiś syk jakby gdzieś uchodzilo powietrze w okolicach silnika, z jakiejś rurki ... Po podłączeniu do kompa wykryto takie błędy:
17055
17057
17058
16725
17026
Gość który mi podpinał powiedzial ze to najpewniej może chodzic o ten osttatni bład.
Ktoś może pomóc w rozkodowaniu ich?
17055
17057
17058
16725
17026
- Rafik
- Imię:: Rafał
17055 świeca żarowa 1cylinder
17057 świeca żarowa 3 cylinder
17058 świeca żarowa 4 cylinder
16725 czujnik położenia wałka rozrządu uszkodzony
17026 http://wiki.ross-tech.com/wiki/index.ph ... 642/001602 tu masz opis
TDI To Doch Idze
- jakubek666
- Auto:: touran 1.9tdi bkc 2005 HL
- Imię:: kuba
- Podziękował: 10 razy
Chłopaki pomóżcie, bo nie wiem w czym jest problem z tymi kodami błędów.
Wyciąłem z raportu wszystko co było OK, by nie robić zamieszania.
Jeśli chodzi o zasilanie haka, to podpiąłem przyczepkę i instalacja działa poprawnie(wszystko świeci jak należy).błąd nadal występuje.
Sterowanie tylnych drzwi - tak jak jeżu sugerował - góra/dół i po 5 sekund trzymałem, by zaprogramował początek/koniec. błędy nadal występują.
Ps. Martwi mnie ten Aux Heat - not reached.
Pewnie chodzi o Webasto, ale czy działa to nie wiem, bo chyba za ciepło jest by się włączyło.
Raport:
VIN: WVGZZZ1TZ5W159617 Mileage: 173320km/107696miles
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: Cannot be reached 1100
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H37 0803
Revision: 00H37000 Serial number: 00000001620447
Coding: 01890F020004100000120C000000000000087F075C
Coding: 00065493
Shop #: WSC 00000
2 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
00834 - Signal for Activation of Heated Rear Window
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0C7H1T
Coding: 0012338
VCID: 356B3F0D5C5A571
1 Fault Found:
Cannot be reached
Component: Gateway H11 0110
Revision: 11 Serial number: 290010530405CD
Coding: 3D3F5340078002
Shop #: WSC 02534 202 82412
2 Faults Found:
Fault Priority: 2
Reset counter: 167
Mileage: 166008 km
Time Indication: 0
Date: 2000.00.00
Time: 13:11:13
Fault Priority: 2
Reset counter: 167
Mileage: 166008 km
Time Indication: 0
Date: 2000.00.00
Time: 13:11:16
Coding: 0000116
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 18C802087F2D8404084F016011CC
Shop #: WSC 00680 202 06222
VCID: 79F3F33D30C2731
2 Faults Found:
00668 - Supply Voltage Terminal 30
Coding: 0000116
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Coding: 0000048
2 Faults Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
00934 - Electric Window Motor; Rear Left (V26)
Address 69: Trailer
Cannot be reached
Coding: 0000048
2 Faults Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Z góry dzięki za podpowiedzi gdzie szukać problemu by błędy się już nie pojawiały.
Pozdrawiam,
Kuba
Raport:
Coding: 00065493
Shop #: WSC 00000
2 Faults Found:
Coding: 0012338
1 Fault Found:
Cannot be reached
2 Faults Found:
Fault Priority: 2
Reset counter: 167
Mileage: 166008 km
Time Indication: 0
Date: 2000.00.00
Time: 13:11:13
Fault Priority: 2
Reset counter: 167
Mileage: 166008 km
Time Indication: 0
Date: 2000.00.00
Time: 13:11:16
Coding: 0000116
1 Fault Found:
Component: KSG 0401
2 Faults Found:
Coding: 0000116
1 Fault Found:
Coding: 0000048
2 Faults Found:
Address 69: Trailer
Cannot be reached
Coding: 0000048
2 Faults Found:
Pozdrawiam,
Kuba
- Tomasz_W-wa
- Podziękował: 285 razy
Mam taki o to problem.
Wymieniłem Gateway z "C" na "Q" i wywaliło mi taki o to błąd:
Part No: 1T0 920 860 G
Component: KOMBIINSTRUMENT VDD 3354
Coding: 0001101
Shop #: WSC 00481 211 21006
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Gdzieś przeczytałem na forum, że taki błąd wyskakuje jak zmienimy piec na nowszy np. wsadzimy do przedlifta piec Webasto z polifta, a ja nie zmieniałem pieca.
Musze nadmienić że od kupienia autka mam błąd Webasta, ale ono działa bez problemu:
Part No: 1K0 815 071 P
Coding: 0000011
VCID: 32610411AD34409
1 Fault Found:
02456 - Line Filling
I teraz moje pytanie jak zlikwidować błąd w sekcji 17: Instruments, może uruchomić Webasto i może zniknie (czytaj da się skasować w taki sposób żeby się nie pojawiał)
Jak Wy to widzicie.
Będę wdzięczny za wszystkie porady.
Coding: 0001101
1 Fault Found:
Coding: 0000011
1 Fault Found:
Jak Wy to widzicie.
- Cesarz
- Imię:: Michał
- Podziękował: 629 razy
17 Instruments - to licznik, uruchomienie webasta nic Ci nie da
[ Dodano: Wto Sie 13, 2013 18:45 ]
A co do webasto to
02456 - Line Filling: No or Incorrect Basic Setting / Adaptation
Possible Symptoms
Fault Code can not be erased
Possible Causes
Line Filling not performed
New Auxiliary Heater installed
Possible Solutions
Perform Line Filling
Special Notes
When found in VW Touran (1T): Auxiliary Heating (or similar), perform Line Filling. Set Adaptation Channel 030 to a New Value of 30.
Set Adaptation Channel 043 to a New Value of 0.
Perform Basic Setting in Measuring Value Block (MVB) 066.
A co do webasto to
Possible Symptoms
Possible Causes
Possible Solutions
Special Notes
- Tomasz_W-wa
marynarz75
Ale co z licznikiem, przepinałem Gateway oczywiście odłączając aku, przebiegu na liczniku się wykasowały ale nic więcej.
Co do pieca to czytałem to:
http://wiki.ross-tech.com/wiki/index.php/02456
