Błędy z Autoscanu
- Marco_Polo
- Podziękował: 9 razy
A ja mam coś takiego:
Part No SW: 1K0 907 044 DA HW: 1K0 907 044 DA
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 69D2BFFA7F23F454
1 Fault Found
00716 - Air recirculation Flap Positioning Motor (V113)
000 - - - Intermittent
Tutaj jasne wymiana lub przeczyszenie silniczka flapy
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 HW: 1T0 919 475
Component: PARKHILFE PLA H07 0002
Revision: -------- Serial number: 62230734801864
Coding: 100101
Shop #: WSC 00001 123 11111
VCID: F8F46ABEB489DDDC
No fault code found.
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Coding: 0000011
VCID: 366824867E1D6BAC
1 Fault Found
01406 - No Flame
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 192
Mileage: 173481 km
Time Indication: 0
Start
Temperature: 72.0°C
Temperature: 69.0°C
Voltage: 13.95 V
Revision: H07 01 Serial number: 100308F2003774
Coding: EDA07F06500E028002
Shop #: WSC 01324 785 00200
VCID: 3064129E9C79459C
1 Fault Found
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 173605 km
Time Indication: 0
Date: 2000.00.00
Time: 16:56:41
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.071 H08 1901
VCID: 356A238A631B60B4
1 Fault Found
03075 - Parallel Parking Assistance Control Module (J791)
Mileage: 173360 km
Temperature: 21.0°C
Voltage: 12.90 V
Voltage: 12.70 V
Address 77: Telephone Labels: 3C0-035-729.lbl
Part No SW: 3C0 035 729 G HW: 3C0 035 729 G
Component: Telefon 7609
Revision: 00012000 Serial number: 0000B6A083848
Coding: 0016043
VCID: 2756F9C2A9B70224
2 Faults Found
01530 - Radio Mute Switch
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 135
Mileage: 173373 km
Time Indication: 0
Date: 2000.00.00
Time: 11:59:42
00992 - Consumption Cut-Off Active
000 - -
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 173759 km
Time Indication: 0
Date: 2000.00.00
Time: 12:20:51
Może jakieś wskazówki
1 Fault Found
Coding: 100101
Coding: 0000011
1 Fault Found
01406 - No Flame
Fault Priority: 3
Fault Frequency: 1
Reset counter: 192
Mileage: 173481 km
Time Indication: 0
Start
Temperature: 72.0°C
Temperature: 69.0°C
Voltage: 13.95 V
1 Fault Found
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 173605 km
Time Indication: 0
Date: 2000.00.00
Time: 16:56:41
1 Fault Found
Mileage: 173360 km
Temperature: 21.0°C
Voltage: 12.90 V
Voltage: 12.70 V
Coding: 0016043
2 Faults Found
Fault Priority: 3
Fault Frequency: 1
Reset counter: 135
Mileage: 173373 km
Time Indication: 0
Date: 2000.00.00
Time: 11:59:42
000 - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 173759 km
Time Indication: 0
Date: 2000.00.00
Time: 12:20:51
- Marco_Polo
Ja miałem wymienione 3 pompowtryski i też wyskoczył mi poniższy błąd:
000 - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 173759 km
Time Indication: 0
Date: 2000.00.00
Time: 12:20:51
Wiadomo co to jest?
Oprócz tego:
1 Fault Found
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 173605 km
Time Indication: 0
Date: 2000.00.00
Time: 16:56:41
Poniższy to przypuszczam, że włączyła mi się chyba rezerwa i zgasło Webasto.
Coding: 0000011
1 Fault Found
01406 - No Flame
Fault Priority: 3
Fault Frequency: 1
Reset counter: 192
Mileage: 173481 km
Time Indication: 0
Start
Temperature: 72.0°C
Temperature: 69.0°C
Voltage: 13.95 V
Mi po tych błędach auto zmuliło.
Pozdawiam
000 - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 173759 km
Time Indication: 0
Date: 2000.00.00
Time: 12:20:51
Wiadomo co to jest?
Oprócz tego:
1 Fault Found
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 173605 km
Time Indication: 0
Date: 2000.00.00
Time: 16:56:41
Coding: 0000011
1 Fault Found
01406 - No Flame
Fault Priority: 3
Fault Frequency: 1
Reset counter: 192
Mileage: 173481 km
Time Indication: 0
Start
Temperature: 72.0°C
Temperature: 69.0°C
Voltage: 13.95 V
Pozdawiam
- Rauko
- Auto:: 06.2006 2.0BMM DSG
Marco_Polo, nie, to nie rezerwa. Coś Ci się skopało z komunikacją z piecem (np. przewody, bezpiecznik), a wcześniej bo błędy są w odwrotnej kolejności (patrząc na przebieg, przy którym wystąpiły), miałeś brak płomienia, ale przyczyny tego zna pewnie tylko nasz spec jarry
Zrób to zanim zima się rozpocznie na dobre, bo bez tego nigdy w mieście silnika nie rozgrzejesz, a co za tym idzie i wnętrza - doświadczyłem przez 2 tygodnie - odradzam
- Dodi
- Auto:: Sharan 7N CFGB
- Podziękował: 29 razy
do oceny...
Chassis Type: 3C0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 76
VIN: WVWZZZ3CZ8E093924 Mileage: 191720km/119129miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
Part No SW: 03G 906 018 EP HW: 03G 906 018 EP
Component: R4 2.0l PPD1.2 G 4368
Revision: --H42--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00191 264 15243
VCID: 77F9EFEF7AE9
Readiness: N/A
Address 03: ABS Brakes Labels: 3C0-614-109-C4.lbl
Part No SW: 3C0 614 109 C HW: 3C0 614 109 C
Component: J104 C4 440 V1 0003
Revision: --020--- Serial number: 00000776008847
Coding: 0000282
Shop #: WSC 05311 000 00000
VCID: 1E37DA4BB593
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CB HW: 3C0 907 044 CB
Component: ClimatronicPQ46 122 0707
Revision: 00122021 Serial number: 00000000000000
VCID: 63C1ABBFDE71
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007545271
Coding: FD888E0700041A00470A00000F00000000095D433200012C000000000000
Shop #: WSC 05124 000 00000
VCID: 71EDD1F7148D
Subsystem 1 - Part No: 3C1 955 419 A
Component: Wischer 290807 003 0205
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AF
Component: RLS 230907 046 0204
Coding: 00471077
Shop #: WSC 05124
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 0B AIRBAG VW8 032 2522
Revision: 12032000 Serial number: 003B1PJFP0T%
Coding: 0012354
VCID: 306B14F3DF07
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 L HW: 3C0 953 549 L
Component: Lenksäulenmodul 006 0010
Revision: 00006000 Serial number: 3C9953507BK
Coding: 0000014
VCID: 356525E72065
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 860 N HW: 3C0 920 860 N
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0005105
Shop #: WSC 00230 259 17801
VCID: 2D550D87C835
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P0791804E4
Coding: F9807F0E4002022002
VCID: 2341EBBF9EF1
Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 397D29D70C7D
Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 37: Navigation Labels: None
Part No SW: 1K0 035 191 DX HW: 1K0 035 191 DX
Component: J401 0303
Revision: 00019000 Serial number: VWZ1Z2F6522156
Coding: 0041400
Shop #: WSC 00621 202 82037
VCID: 7BF1F3DF46C1
1 Fault Found:
000 - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 191726 km
Time Indication: 0
Date: 2000.00.00
Time: 19:02:05
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1131
Revision: 31008001 Serial number: 00000002278916
Coding: 0000247
VCID: 3C7330C3034F
Component: EPS_ZFLS Kl.135 H08 1901
Shop #: WSC 02069 000 90108
VCID: 356525E72065
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 1991020051034E76300494157000CFCE707CA0
Shop #: WSC 04049 202 07098
VCID: 397D29D70C7D
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Component: Innenraumueberw.004 0611
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1131
Revision: 31008001 Serial number: 00000533478907
Coding: 0000246
VCID: 3D753DC71855
Address 53: Parking Brake Labels: 5N0-907-801.lbl
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000175867
Coding: 0000056
VCID: 295DF997FCDD
Address 56: Radio Labels: None
Component: R 0303
Coding: 0041400
VCID: 7BF1F3DF46C1
1 Fault Found:
000 - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 191726 km
Time Indication: 0
Date: 2000.00.00
Time: 19:02:05
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1119
Revision: 11006001 Serial number: 00000002345094
Coding: 0000208
VCID: 3D753DC71855
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1119
Revision: 11006001 Serial number: 00000002381308
Coding: 0000208
VCID: 3E773ACB1553
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 C HW: 3C0 919 283 C
Component: Parkhilfe 8-Kan 004 0013
Revision: 00004000 Serial number: 90630726015254
Coding: 0000024
VCID: 295DF997FCDD
Chassis Type: 3C0
Coding: 0000072
VCID: 77F9EFEF7AE9
Readiness: N/A
Coding: 0000282
VCID: 1E37DA4BB593
VCID: 63C1ABBFDE71
VCID: 71EDD1F7148D
Coding: 00046997
Shop #: WSC 05124
Coding: 00471077
Shop #: WSC 05124
Coding: 0012354
VCID: 306B14F3DF07
Coding: 0000014
VCID: 356525E72065
Coding: 0005105
VCID: 2D550D87C835
VCID: 2341EBBF9EF1
VCID: 397D29D70C7D
Coding: 0041400
VCID: 7BF1F3DF46C1
1 Fault Found:
000 - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 191726 km
Time Indication: 0
Date: 2000.00.00
Time: 19:02:05
Coding: 0000247
VCID: 3C7330C3034F
VCID: 356525E72065
VCID: 397D29D70C7D
Coding: 0000246
VCID: 3D753DC71855
Coding: 0000056
VCID: 295DF997FCDD
Component: R 0303
Coding: 0041400
VCID: 7BF1F3DF46C1
1 Fault Found:
000 - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 191726 km
Time Indication: 0
Date: 2000.00.00
Time: 19:02:05
Coding: 0000208
VCID: 3D753DC71855
Coding: 0000208
VCID: 3E773ACB1553
Coding: 0000024
VCID: 295DF997FCDD
KKS4eVeR
- Auto:: Touran, 1.9tdi BLS, 2006
- Imię:: Adam
Wie ktos co to moze byc?
Swieca mi kontrolki ABS ESP w Caddym
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017106
Shop #: WSC 35110 377 00158
VCID: 3F875D256E669D1
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
Bezpiecznik? Czujniki?
Coding: 0017106
1 Fault Found:
pawel07777
- Auto:: Touran 2.0 2011
andreass211
- Auto:: 2.0tdi AZV,2004r
- Imię:: andrzej
- Podziękował: 82 razy
KKS4eVeR
- Imię:: Adam
Drodzy Panowie niezwykle dziwna sytuacja
Miałem 2 spalone bezpieczniki, lecz zupelnie od czegos innego.
(Paweł 14 była ok). Teraz mam wszystkie sprawne(z wygladu) bezpieczniki lecz problem nie ustapił.
Co ciekawe 2 duze bezpieczniki pod maska 30 i 40 były zaśniedziałe, przeczyściłem je papierem ściernym włożyłem i ku mojemu zdziwieniu KONTROLKA ASR znikła, został ABS. Po przejechaniu 50m ABS również zgasł. Lecz za 10 sekund ponownie zaświeciły się obie kontrolki i swieca do tej chwili. VCDS pokazuje nadal ten sam błąd.
Co wy na to?
PS. Moja radość trwała 10 sekund xD
Co wy na to?
pawel07777
Sprawdź wszystkie bezpieczniki z schematu.
opis błędu:
kod błędu : 01276
Ten kod błędu dotyczy tylko pojazdów z grupy VAG.
pl ABS Hydraulic Pump (V64)
du Hydraulikpumpe ABS (V64)
i ABS Hydraulic Pump (V64)
Dodatkowe informacje na temat kodów błędów. Intermittent
Możliwe objawy:
ABS lampka świeci
ABS nie działa
Możliwe przyczyny:
Bezpiecznik (s) co słaby kontakt lub są uszkodzone
Zbyt duża rezystancja przewodów lub połączeń (może / prawdopodobnie z powodu przepalonego bezpiecznika)
ABS Pump (V64) wadliwe
Złącze do modułu sterującego pompy ABS (V64) wadliwe
Hydraulic Pump Relay (J185) wadliwe
Czujnik do pompy hydraulicznej (G101) wadliwe
Brake Electronics Control Module (J104) wadliwe
Możliwe rozwiązania:
Sprawdzić / wymienić bezpiecznik (s)
Wyjmij bezpiecznik (s) z
aby końce bezpiecznika (s) czyste (bardzo lekkie szlifowanie drobnym papierem ściernym, a następnie bardzo mało sprayu kontakt na nim)
bezpiecznik (s), poprzez pomiar multimetrem (bezpiecznik (s) czasami wygląda dobrze, ale pozory mogą mylić)
bezpiecznik (s) zastępując / wymienione
Sprawdzić / naprawić okablowanie i połączenia
Zaciski akumulatora i zaciski akumulatora czyste papierem ściernym lub szczotką drucianą. Potem wystarczy posmarować wazeliną i lizać zasadniczo ustalony wierzchowca
Sprawdź złącze do modułu sterującego dla pompy ABS (V64)
Sprawdź (pomiar bloków) czujniki ABS kół.
Operacja odczytu z czujników kół, zgadzam się z VAG-COM. Być może jednym z pierścienia ABS zablokowane (brud, śnieg, śmieci soli), powodując odchylenie w jednym z czterech pomiarów prędkości kół mogą wystąpić. Jeśli czujnik nie jest uszkodzony, ale jest inny pomiar jest zrobione, system wyłączy się z błędem pozornie dziwne.
Wymień ABS pompa hydrauliczna (V64)
Sprawdź (pomiarowe bloki) / wymienić przekaźnik pompy hydraulicznej (J185)
Sprawdź (pomiarowe bloki) / wymienić pompa hydrauliczna (G101)
Sprawdź (pomiar bloków) / wymienić moduł sterowania hamulca Electronics (J104)
Dodatkowe info:
ABS
źródło VW Freak . VW Golf 4 i Bora. Dziewięć razy na dziesięć, w tym błędzie bezpieczniki w skrzynce na akumulatorze jest winowajcą. Gabinet demontować, czyste nogi, kontakty trzech bezpieczników zielone i lekkiego szlifowania czyszczenia natryskowego kontaktowych (jeszcze lepiej postawić trzy nowe bezpieczniki). Jeden z tych trzech bezpieczników wysyła jednostki ABS. Kontakty te chcą korodować i wtedy pojawia się błąd, który jest opisany tutaj. Agregat ABS jest bardzo wrażliwy na (mały) spadek napięcia.
opis błędu:
kod błędu : 01276
Możliwe objawy:
ABS lampka świeci
ABS nie działa
Możliwe przyczyny:
Dodatkowe info:
ABS
WITAM [you]
KKS4eVeR
- Imię:: Adam
Znalazłem przyczyne!
Dwa małe bezpieczniki które wymieniłem to był klucz!
Jeden z nich (w skrzynce koło aku) najmniejszy 5A znów sie przepalił!
Założyłem 7,5A i wszystko śmiga! ABS I ESP juz nie świecą i działaja bardzo dobrze.
Zastanawia mnie tylko czy tam powinien byc bezpiecznik 5A czy wiekszy...
Może ktoś włożył tam bezpiecznik na sztuke...
Problem rozwiazany
Paweł
za chęci i pomoc !! Dzieki wszystkim
Problem rozwiazany
Paweł
- Mateoo21
- Auto:: Touran 1.9 TDI BLS 2006
Part No: 1K0 815 071 P
Component: Zuheizer 031 1312
Coding: 0000011
VCID: 32610411AD34409
3 Faults Found:
01489 - Over-Temp Sensor (G189)
Fault Status: 00101010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 200083 km
Time Indication: 0
Date: 2000.00.00
Time: 21:47:59
Start
Temperature: 45.0°C
Temperature: 46.0°C
02251 - Heater Unit Locked
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 200083 km
Time Indication: 0
Date: 2000.00.00
Time: 21:47:59
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 67
Mileage: 200216 km
Time Indication: 0
Date: 2000.00.00
Time: 07:06:36
co te błędy oznaczaja? bo ja jestem zielony a chciałbym wiedziec czemu nie działa mi webasto
Friday,07,December,2012,17:03:17:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 52 56 62 69 72 77
VIN: WVGZZZ1TZ6W139384 Mileage: 200610km/124653miles
46-Central Conv. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 03G 906 021 FE HW: 03G 906 021 FE
Component: R4 1,9L EDC G000SG 8823
Revision: --H02--- Serial number: VWZ7Z0F3381574
Coding: 0000072
Shop #: WSC 06325 000 00000
VCID: 67D7A5455676F51
Readiness: 0 0 0 0 0
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Revision: 00H13001
Coding: 0021190
VCID: 71E3CB1D68B23B1
Part No: 1K0 907 044 BE
Component: ClimatronicPQ35 090 0808
VCID: 6BDFD9754A9ED11
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005442283
Coding: 01898F2100040F0000120C000000000000097F075C
VCID: 2B5F19758A1E111
Subsystem 1 - Part No: 2K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW357 012 0402
Coding: 00063445
Shop #: WSC 01324
2 Faults Found:
01800 - Light Switch (E1)
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 254
Reset counter: 122
Mileage: 140526 km
Time Indication: 0
OFF
Voltage: 12.15 V
OFF
ON
OFF
OFF
OFF
01517 - Control Module for Trailer/Towing Sensor (J345)
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 108
Mileage: 0 km
Time Indication: 0
OFF
Voltage: 12.75 V
OFF
OFF
OFF
OFF
OFF
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0HD8E1
Coding: 0012338
VCID: 356B3F0D5C5A571
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
VCID: 76E9F80101DC1C9
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Part No: 1T0 920 872 F
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0001101
Shop #: WSC 00011 888 96745
VCID: 377735054656A51
Coding: 0000011
3 Faults Found:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 200083 km
Time Indication: 0
Date: 2000.00.00
Time: 21:47:59
Start
Temperature: 45.0°C
Temperature: 46.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 200083 km
Time Indication: 0
Date: 2000.00.00
Time: 21:47:59
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 2
Reset counter: 67
Mileage: 200216 km
Time Indication: 0
Date: 2000.00.00
Time: 07:06:36
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001062150947
Coding: 3D3F53C8078002
Shop #: WSC 20791 150 02301
VCID: 2A511C7185E4089
Component: IMMO VDD 4312
Address 37: Navigation Labels: 1K0-035-191.lbl
Part No SW: 1K0 919 887 K HW: 1K0 035 191 E
Component: J401 0111
Revision: 00013000 Serial number: VWZ1Z2F6097542
Coding: 0023200
VCID: 41835BDD1892EB1
1 Fault Found:
00003 - Control Module
014 - Defective
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 73
Mileage: 165373 km
Time Indication: 0
Date: 2000.00.00
Time: 11:10:38
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2301
Coding: 0000180
VCID: 36693801415C5C9
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 336F0115522E491
Part No SW: 1K0 959 433 AR HW: 1K0 959 433 AR
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 009002085103087F2D06840560084F01E0A400
VCID: 80051ED9D318A29
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
01331 - Door Control Module; Driver Side (J386)
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 194
Mileage: 170653 km
Time Indication: 0
Date: 2000.00.00
Time: 11:07:22
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000180
Address 56: Radio Labels: 1K0-035-191.lbl
Part No SW: 1K0 035 153 H HW: 1K0 035 191 E
Component: R 0111
Coding: 0023200
VCID: 254BEF4DECFA271
1 Fault Found:
014 - Defective
Fault Priority: 3
Fault Frequency: 1
Reset counter: 73
Mileage: 165373 km
Time Indication: 0
Date: 2000.00.00
Time: 11:10:38
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2428
Coding: 0000144
Address 69: Trailer
Cannot be reached
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
Address 77: Telephone Labels: 1K0-035-729-UNI.lbl
Part No: 1K0 035 729 E
Component: CIB PAH HW 202 SW 0308
Coding: 0000262
a tu całosc
Coding: 0000011
3 Faults Found:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 200083 km
Time Indication: 0
Date: 2000.00.00
Time: 21:47:59
Start
Temperature: 45.0°C
Temperature: 46.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 200083 km
Time Indication: 0
Date: 2000.00.00
Time: 21:47:59
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 2
Reset counter: 67
Mileage: 200216 km
Time Indication: 0
Date: 2000.00.00
Time: 07:06:36
Chassis Type: 1K0
Coding: 0000072
Revision: 00H13001
Coding: 0021190
Coding: 00063445
Shop #: WSC 01324
2 Faults Found:
Fault Priority: 3
Reset counter: 122
Mileage: 140526 km
Time Indication: 0
OFF
Voltage: 12.15 V
OFF
ON
OFF
OFF
OFF
Fault Priority: 2
Fault Frequency: 1
Reset counter: 108
Mileage: 0 km
Time Indication: 0
OFF
Voltage: 12.75 V
OFF
OFF
OFF
OFF
OFF
Coding: 0012338
Coding: 0000042
1 Fault Found:
Coding: 0001101
Coding: 0000011
3 Faults Found:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 200083 km
Time Indication: 0
Date: 2000.00.00
Time: 21:47:59
Start
Temperature: 45.0°C
Temperature: 46.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 200083 km
Time Indication: 0
Date: 2000.00.00
Time: 21:47:59
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 2
Reset counter: 67
Mileage: 200216 km
Time Indication: 0
Date: 2000.00.00
Time: 07:06:36
Coding: 0023200
1 Fault Found:
014 - Defective
Fault Priority: 3
Fault Frequency: 1
Reset counter: 73
Mileage: 165373 km
Time Indication: 0
Date: 2000.00.00
Time: 11:10:38
Coding: 0000180
1 Fault Found:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 194
Mileage: 170653 km
Time Indication: 0
Date: 2000.00.00
Time: 11:07:22
Coding: 0000180
Component: R 0111
Coding: 0023200
1 Fault Found:
014 - Defective
Fault Priority: 3
Fault Frequency: 1
Reset counter: 73
Mileage: 165373 km
Time Indication: 0
Date: 2000.00.00
Time: 11:10:38
Coding: 0000144
Address 69: Trailer
Cannot be reached
Coding: 0000144
Coding: 0000262
a tu całosc
- Auto:: 1T1
- Imię:: -
- Podziękował: 32 razy
odblokuj dogrzewacz za moca manuala http://touranklub.pl/forum/viewtopic.ph ... ht=webasto
,pozniej skasuj błedy, i powinno dzialac, pozniej sprawdz czy jakis bład powrócil
