Błędy z Autoscanu
nowy13
Post autor: nowy13 »
Możecie mi podpowiedzieć o co chodzi ?
Dzisiaj otrzymałem kabelek od kolegi jerrego i od razu poszedłem zrobić autoscan
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 18 19 25 37 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ6W206064 Mileage: 191420km/118942miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Cannot be reached 1100
37-Navigation -- Status: Not registered 0001
56-Radio -- Status: OK 0000
ddress 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005930112
Coding: 018B8F2100040F0000120C000000000000097F075C
Shop #: WSC 01324 785 00200
VCID: 2B5F19758A1E111
Subsystem 1 - Part No: 1T0 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 160606 020 0501
Coding: 00038805
Shop #: WSC 01324
1 Fault Found:
02395 - Parking Light Right Front (M3)
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 190777 km
Time Indication: 0
ON
Voltage: 14.15 V
ON
ON
OFF
OFF
OFF
Address 18: Aux. Heat
Cannot be reached
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 310010661204BA
Coding: 3F3F134007008002
VCID: 2C5D1A698F10169
2 Faults Found:
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 190777 km
Time Indication: 0
Date: 2000.00.00
Time: 11:11:13
000 - -
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 22
Mileage: 190777 km
Time Indication: 0
Date: 2000.00.00
Time: 11:11:17
Address 37: Navigation Labels: 1T0-919-887.lbl
Part No: 1T0 919 887 E
Component: Navigation 0525
Coding: 0000002
Shop #: WSC 46884 133 86098
VCID: 448D52C90780FE9
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Address 56: Radio Labels: 1T0-035-095.lbl
Part No: 1T0 035 095 A
Component: Radio 0525
Coding: 0001440
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Dziwna sprawa bo wg błędu:
012 - Electrical Fault in Circuit m żarówka
Mam przepaloną prawą przednią żarówkę.
Jak sprawdziłem okazało się że wszystkie żarówki w lampie świecą.
Dodatkowo dowiedziałem się od poprzedniego właściciel, że radio zostało zmienione na MFD2 DX. Oryginalnie było inne. Do tego jest antena w schowku którą dokupił ale nie podłączył. Pewnie któryś z w/w błędów dotyczy anteny.
Zakładam że ten:
Coding: 0000002
1 Fault Found:
011 - Open Circuit
Niestety reszty nie kumam. :/
[ Dodano: Pon Gru 10, 2012 19:52 ]
Nawigacje zakodowałem i błąd zginął.
Lampa z przodu też już nie pokazuje błędu.
Został dogrzewacz :/ - brak komunikacji.
[ Dodano: Sro Gru 12, 2012 23:22 ]
Po wymianie bezpiecznika i podłączeniu kompa komunikacja się pojawiła. Okazało się że zablokowało urządzenie -> resztę zrobiłem wg info z forum.
[ Dodano: Pią Gru 21, 2012 22:13 ]
temat rozwiązany metodą prób i błędów
Dodatkowo przypróbie wejścia w Aux. Heat wyskakuje taki błąd.
darek8677
Auto:: Touran'06BXE 105KM
Post autor: darek8677 »
witam.Właśnie dostalem kabelek od e-service i probowałem sam zrobic diagnostykę. Mógłby sie ktoś co do tego wypowiedzieć? cos takiego:
Saturday,29,December,2012,14:27:40:10074
VCDS Version: Beta 11.3.0
Data version: 20110801
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 52 56 62 72 76
VIN: WVGZZZ1TZ6W166468 Mileage: 194810km/121049miles
37-Navigation -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
Part No SW: 03G 906 021 KC HW:
Component: R4 1,9L EDC G000SG 9243
Revision: --H03--- Serial number: VWZ7Z0F3756503
Coding: 0000072
Shop #: WSC 04330 995 88871
VCID: 6ADFC69B395B
4 Faults Found:
005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
P161B - 000 - -
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 13
Mileage: 186737 km
Time Indication: 0
Date: 2000.00.00
Time: 06:38:40
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 00001100
Temperature: 11.7°C
Bin. Bits: 10110000
005658 - Glowplug for Cylinder 1 (Q10): Open Circuit
P161A - 000 - - - Intermittent
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 192204 km
Time Indication: 0
Date: 2000.00.00
Time: 18:04:54
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001100
Temperature: 9.0°C
Bin. Bits: 00110000
005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
P161C - 000 - - - Intermittent
Fault Priority: 0
Fault Frequency: 1
Mileage: 192204 km
Time Indication: 0
Date: 2000.00.00
Time: 18:04:54
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001100
Temperature: 9.0°C
Bin. Bits: 00110000
005661 - Glowplug for Cylinder 4 (Q13): Open Circuit
P161D - 000 - - - Intermittent
Fault Priority: 0
Fault Frequency: 1
Mileage: 192204 km
Time Indication: 0
Date: 2000.00.00
Time: 18:04:54
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001100
Temperature: 9.0°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 0
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Revision: 00H13001
Coding: 0021190
VCID: 71EDD1F7148D
No fault code found.
Part No: 1K0 907 044 BD
Component: ClimatronicPQ35 090 0808
Shop #: WSC 00000 000 00000
VCID: 6ADFC69B395B
Revision: 00H37000 Serial number: 00000005673008
Coding: 00890F2100040F0000120C000000000000097B075C
VCID: 2B51039FF621
Subsystem 1 - Part No: 2K1 955 119 B
Component: Wischer VW357 012 0402
Coding: 00063445
Shop #: WSC 01324
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0J6GMC
Coding: 0012338
VCID: 356525E72065
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 634 0070
Coding: 0002022
VCID: 77F9EFEF7AE9
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Part No: 1T0 920 872 F
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0003101
Shop #: WSC 98760 987 45725
VCID: 37792FEF3A69
Part No: 1K0 815 071 R
Component: Zuheizer 050 2302
Coding: 0000011
VCID: 346318E32B1F
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001064070D6E
Coding: 3D3F1748078002
VCID: 2A5F069BF9DB
Component: IMMO VDD 4312
VCID: 37792FEF3A69
Address 37: Navigation Labels: Redir Fail!
Part No SW: 1K0 919 887 K HW: 1K0 035 191 E
Component: J401 0111
Revision: 00014000 Serial number: VWZ1Z2F6173366
Coding: 0041402
VCID: 418D413764AD
2 Faults Found:
00003 - Control Module
014 - Defective
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 116323 km
Time Indication: 0
Date: 2000.00.00
Time: 12:16:02
00857 - CD Changer Unit (R41)
Fault Priority: 3
Fault Frequency: 136
Reset counter: 65
Mileage: 186339 km
Time Indication: 0
Date: 2000.00.00
Time: 14:22:55
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2301
Coding: 0000180
VCID: 366722EB3D63
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 33611BFF2E11
Part No SW: 1K0 959 433 AR HW: 1K0 959 433 AR
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 199002085103287F2D06840560084F01E0A400
Shop #: WSC 04330 995 01997
VCID: 800B0433AF27
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000180
VCID: 37792FEF3A69
Address 56: Radio Labels: Redir Fail!
Part No SW: 1K0 035 153 H HW: 1K0 035 191 E
Component: R 0111
Coding: 0041402
VCID: 2545F5A790C5
2 Faults Found:
014 - Defective
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 116323 km
Time Indication: 0
Date: 2000.00.00
Time: 12:16:02
Fault Priority: 3
Reset counter: 65
Mileage: 186339 km
Time Indication: 0
Date: 2000.00.00
Time: 14:22:55
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2428
Coding: 0000144
VCID: 326F1EFBD10B
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
VCID: 33611BFF2E11
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 02 Einparkhilfe 0101
VCID: 2D550D87C835
[ Dodano: Sob Gru 29, 2012 17:02 ]
i coś takiego:
Saturday,29,December,2012,14:33:39:10074
Address 01: Engine Labels: 03G-906-016-BKC.LBL
Control Module Part Number: 03G 906 021 KC HW:
Component and/or Version: R4 1,9L EDC G000SG 9243
Software Coding: 0000072
Work Shop Code: WSC 04330 995 88871
VCID: 6ADFC69B395B
4 Faults Found:
P161B - 000 - -
Fault Priority: 0
Fault Frequency: 13
Mileage: 186737 km
Time Indication: 0
Date: 2000.00.00
Time: 06:38:40
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 00001100
Temperature: 11.7°C
Bin. Bits: 10110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 192204 km
Time Indication: 0
Date: 2000.00.00
Time: 18:04:54
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001100
Temperature: 9.0°C
Bin. Bits: 00110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 192204 km
Time Indication: 0
Date: 2000.00.00
Time: 18:04:54
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001100
Temperature: 9.0°C
Bin. Bits: 00110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 192204 km
Time Indication: 0
Date: 2000.00.00
Time: 18:04:54
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001100
Temperature: 9.0°C
Bin. Bits: 00110000
Saturday,29,December,2012,14:35:25:10074
Address 01: Engine (03G 906 021 KC)
14:35:22 Group 013: Idle Stabilization (Injection Quantity Deviation)
0.00 mg/str Injection Quantity Deviation Cyl. 1
-0.28 mg/str Injection Quantity Deviation Cyl. 2
-0.14 mg/str Injection Quantity Deviation Cyl. 3
0.40 mg/str Injection Quantity Deviation Cyl. 4
14:35:22 Group 018: Injector Status
0.0 Injector Status Cylinder 1
0.0 Injector Status Cylinder 2
0.0 Injector Status Cylinder 3
0.0 Injector Status Cylinder 4
14:35:22 Group 023: Injector Switch Time Deviation
-23.0 Switch Time Deviat. Cylinder 1
-24.0 Switch Time Deviat. Cylinder 2
-20.0 Switch Time Deviat. Cylinder 3
-13.0 Switch Time Deviat. Cylinder 4
[ Dodano: Sob Gru 29, 2012 17:33 ]
aha. i zauważyłem ze w grupie 004 w polu : Torsion Value, mam na -2.0... , niewiem nie znam sie ale moze dla tego bipy na kanale 023 są blisko granicy +30,-30???
1 6 D
Auto:: Scirocco VAN
Post autor: 1 6 D »
darek8677, prawdopodobnie masz świece żarowe spalone.
Lewe tylne drzwi masz do zrobienia adaptację końców podnośnika szyby:
-opuść szybę na sam dół i przytrzymaj guzik kilka sekund wciśnięty na 2 stopień
-podnieś szybę do samej góry i przytrzymaj guzik kilka sekund jak wcześniej, tyle że pociągnięty na 2 stopień.
-adaptacja powinna być zrobiona.
Masz w aucie zmieniarkę płyt CD w ogóle?
darek8677
tak mam zmieniarke dziala bez zarzutu.A co do swiec to dokladnie rok temu wymienialem kpl na beru i w maju gosc robil mi skan i mowil ze swieca spalona na drugim cylindrze...wymienilem. Niemozliwe zeby tak szybko padly wszystkie.Aha opowiem pewna ciekawostke ale niewiem czy to ma znaczenie: jakies 2tyg. temu zdjalem listwe ze swiec bo sprawdzalem je miernikiem wszystkie mialy 0.08 Ohm. zapomnialem zalozyc ja spowrotem i jezdzilem tak jakies 30km az sie kapnalem. moze to przez to?sprobuje odpiac aku i zrobie nowy skan. Pozdrawiam
[ Dodano: Sob Gru 29, 2012 20:11 ]
koledzy wie ktoś jak sprawdzie mostek stykowy ten cojest na świecach?
darek8677, najpierw wykasuj błędy wszystkie,przejedź się i zrób jeszcze raz scan. Błędy 3 świec masz o tej samej porze,czyli to co piszesz,że jezdziłeś ze zdjętą wiązką.. Jest błąd 2 świecy,ale wygląda na nie wykasowany po wymianie.
darek8677
ok. Dzieki tak zrobie. a co myslicie o bipach,kanal 023? zauwazylem tez ze mam rozrzad na -2.0 moze to byc przyczyna?dodam ze teraz jak jest chlodniej przy porannym odpalaniu przez chwile kuleje po czym pracuje normalnie. Aku nowe (zakladajac ze swiece mam dobre)Pozdrawiam
[ Dodano: Sro Sty 02, 2013 16:18 ]
koledzy moze mo ktos doradzić z tym kątem synchronizacji wałka rozrządu? tok jak pisalem wyżej mam go na -2.0 , i niewiem czy zostawic go tak czy przestawic na 0.0 , zmieni to coś? zależy mi bo w piątek wracam do francji.Pozdrawiam ;) Dosiego roku :bry:
[ Dodano: Nie Sty 06, 2013 19:45 ]
błędy skasowane.Po jeżdzie i ponownym skanie świece są ok,wiec bylo to co pisalem wyżej,natomiast lewe tylne drzwi mimo adaptacji (tak jak pisał wyżej 16D) powracają, noi zmieniarka i navi tez choć wszystko działa ok. A co myslicie o kącie synch. walka -2,0? zrobic korekte na 0,0??? oto skan:
http://vaglog.rtnet.pl/darek8677_110293.html
i jeszcze tak:
http://vaglog.rtnet.pl/darek8677_110294.html
no i ten Torsion Value:
http://vaglog.rtnet.pl/darek8677_110295.html
WJ
Auto:: 1,9 BXE, model 2009
Imię:: Waldek
Błędy po autoscanie
Post autor: WJ »
Po wczorajszym Vagowaniu Touranka pokazało mi się kilka błędów w sterowniku kierownicy. Błędy skasowałem i dzisiaj zrobiłem ponowny scan po powrocie z Kościółka.
Wypluł ponownie takie info:
Control Module Part Number: 1K0 953 549 BN HW: 1K0 953 549 BN
Component and/or Version: J0527 757 0101
Software Coding: 0000042
VCID: 7F0907CF576D
4 Faults Found:
00576 - Terminal 15
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Możecie mi pomóc rozszyfrować tą (dla mnie) zagadkę?
pawel07777
Auto:: Touran 2.0 2011
Post autor: pawel07777 »
Proszę wyjaśnienie tych błędów:
kod błędu : 01744
Ten kod błędu dotyczy tylko pojazdów z grupy VAG.
pl D Wyłącznik zapłonu (zacisk P)
du ZĂźndanlassschalter (D) (Klemme P)
i Ignition / Starter Switch (D) (Terminal P)
Dodatkowe informacje na temat kodów błędów. Intermittent
Usterka elektryczna w obwodzie ↔ (usterka elektryczna w obwodzie)
Możliwe objawy:
Zamek centralny włącza się i wyłącza w losowych porach w czasie jazdy
Radio nie wyłącza się, gdy kluczyk zapłonu jest usuwany
Akumulator jest pusty
Syrena od alarmu nie działa, gdy alarm zmusza
W Eos: okna są w niewielkiej odległości w dół do góry, gdy są one zamknięte
Możliwe przyczyny:
Przełącznik zapłonu (część elektryczna) jest uszkodzony
Okablowanie i / lub wadliwe połączenia
Możliwe rozwiązania:
Wymienić wyłącznik zapłonu
Sprawdzić / naprawić okablowanie i połączenia
Dodatkowe info:
Ten kod błędu jest często w połączeniu z następujących kodów błędów:
00576 : Terminal 15, usterka elektryczna w obwodzie
00883 : Stacyjka D (terminal S), usterka elektryczna w obwodzie
00884 : Stacyjka D (X terminal), usterka elektryczna w obwodzie
Najczęstszą przyczyną tych błędów jest elektryczna część stacyjki
WITAM [you]
WJ
Imię:: Waldek
Post autor: WJ »
Czy to oznacza że do wymiany może być kostka w stacyjce (takową wymieniałem w poprzedniku Tourana - Passku B5) czy jeszcze inny element?
Nie orientuję się jak jest tutaj skonstruowana stacyjka..
darek8677
koledzy moze mo ktos doradzić z tym kątem synchronizacji wałka rozrządu? tok jak pisalem wyżej mam go na -2.0 , i niewiem czy zostawic go tak czy przestawic na 0.0 , zmieni to coś? zależy mi bo w piątek wracam do francji.Pozdrawiam Dosiego roku
i jeszcze tak:
darek8677, możesz delikatnie opóźnić wtrysk :) Może zacząć mniej palić,lepiej się zbierać.. -0,7-0,0 będzie dobrze :)
1 6 D
Auto:: Scirocco VAN
Post autor: 1 6 D »
pawel07777 pisze:Proszę wyjaśnienie tych błędów:
kod błędu : 01744
Możliwe objawy:
Możliwe przyczyny:
Dodatkowe info:
Grzebane było w okablowaniu idącym do sterownika kolumny lub przy samym sterowniku?
WJ
Imię:: Waldek
Post autor: WJ »
1 6 D pisze:Grzebane było w okablowaniu idącym do sterownika kolumny lub przy samym sterowniku?
Nigdy.
Zastanawiam się czy może mieć to coś wspólnego z faktem że przy ostatnich mrozach zajechalem zupełnie stary aku próbując odpalic auto. Wiem że padniety aku może być przyczyną różnych błedów a wtedy świeciła się kontrolna kierownicy ale po przejechaniu krótkiego odcinka zgasła.
Tyle tylko że ten błąd obecnie wywala nawet po skasowaniu VAGiem.
WJ pisze: Wiem że padniety aku może być przyczyną różnych błedów a wtedy świeciła się kontrolna kierownicy ale po przejechaniu krótkiego odcinka zgasła.
To nie z tego powodu, po odłączeniu aku zawsze pali sie żólta kontrola kierownicy, po przejechaniu parę metrów robi się adaptacja i kontrolka gaśnie.
WJ
Imię:: Waldek
Post autor: WJ »
I dokładnie tak było. Po adaptacji zgasła.
Jest jeszcze jedna kwestia na którą zwróciłem uwagę po Twoim poście - teraz przy włączeniu zapłonu kontrolka od kierownicy pali się na czerwono i wydaje mi się (choć już nie mam pewności) że dzieje się tak od momentu tego incydentu z odpalaniem kiedy po kilku próbach startu po mroźnej nocy aku umarł zupełnie i posiłkowałem się rozruchem z kabli.
Nie wiem teraz gdzie zacząć szukać, rozbebeszać stacyjkę? :/
