Re: KODY BLEDOW
: ndz wrz 25, 2016 20:25
Witam, proszę o analizę błędów auto to passat b6 2.0TDI dziś przestały świecić doświetlanie zakrętów i mruga kontrolka spalonej żarówki, nie idzie skasować błędów..
Sunday,05,February,2017,16:52:09:62939
VCDS Version: Release 12.12.0
Address 01: Engine Labels: 03G-906-021-BMM.clb
Control Module Part Number: 03G 906 021 NK HW: 03G 906 021 AB
Component and/or Version: R4 2,0L EDC G000SG 9354
Software Coding: 0000072
Work Shop Code: WSC 66565 257 00032
VCID: 75E1075F1C34EDB6B75-8020
1 Fault Found:
005748 - Powertrain Data Bus
P1674 - 000 - Implausible Message from Instrument Cluster - Intermittent
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 188767 km
Time Indication: 0
Date: 2017.01.16
Time: 14:22:30
RPM: 4179 /min
Speed: 92.0 km/h
Load: 65.9 %
Voltage: 14.36 V
Bin. Bits: 00001000
Torque: 263.5 Nm
Bin. Bits: 0 00 0
Readiness: 0 0 0 0 0
Sunday,05,February,2017,16:53:15:62939
Control Module Part Number: 3C0 937 049 AE HW: 3C0 937 049 AE
Component and/or Version: Bordnetz-SG H52 2002
Software Coding: E38A8F4701041A00470A00000F000000000B5D435C0001
Work Shop Code: WSC 49085 136 51158
Additional Info: 3C1955119B Wischer 031106 022 0601 1K0955559AH RLS 050609 054 0402
VCID: 6CD7223B4F7E2C7E58B-8039
1 Fault Found:
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 107
Mileage: 184634 km
Time Indication: 0
Date: 2016.12.09
Time: 11:40:00
OFF
Voltage: 12.50 V
OFF
ON
OFF
OFF
OFF
Sunday,05,February,2017,16:57:37:62939
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Control Module Part Number: 5M0 907 357 A HW: 5M0 907 357 A
Component and/or Version: AFS-Steuergeraet X014
Software Coding: 2301953
Work Shop Code: WSC 05311 000 00000
Additional Info: ID-L fehlt AFS-Lst.-Modul l .... 7L6941330 AFS-Lst.-Modul r X018
VCID: 326BFC43ADDABA8E527-8067
5 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 216
Reset counter: 107
Mileage: 188083 km
Time Indication: 0
Date: 2017.01.10
Time: 12:41:05
Voltage: 14.06 V
Speed: 33.8 km/h
ABS 1
01042 - Control Module; Not Coded
000 - - - MIL ON
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
1 Fault Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 188767 km
Time Indication: 0
Date: 2017.01.16
Time: 14:22:30
RPM: 4179 /min
Speed: 92.0 km/h
Load: 65.9 %
Voltage: 14.36 V
Bin. Bits: 00001000
Torque: 263.5 Nm
Bin. Bits: 0 00 0
1 Fault Found:
Fault Priority: 2
Reset counter: 107
Mileage: 184634 km
Time Indication: 0
Date: 2016.12.09
Time: 11:40:00
OFF
Voltage: 12.50 V
OFF
ON
OFF
OFF
OFF
5 Faults Found:
Fault Priority: 2
Reset counter: 107
Mileage: 188083 km
Time Indication: 0
Date: 2017.01.10
Time: 12:41:05
Voltage: 14.06 V
Speed: 33.8 km/h
ABS 1
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
