Powitanie jest w temacie
http://touranklub.pl/forum/viewtopic.ph ... ead#unread
Wyniki z autoscan
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 021 HS HW: 028 101 315 7
Component: R4 1,9L EDC G000SG 2261
Revision: --H01--- Serial number: VWZ7Z0F3309177
Coding: 0000071
Shop #: WSC 80093 222 69422
VCID: 77F7F50506D6651
No fault code found.
Part No: 1K0 907 379 K
Coding: 0021206
Shop #: WSC 35110 377 00159
VCID: 3A712C317544B89
Part No: 1K0 820 047 DQ
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 76E9F80101DC1C9
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005362803
Coding: B188CF030004100000000000000000000019FF073C
Shop #: WSC 35110 377 08192
VCID: 2B5F19758A1E111
Subsystem 1 - Part No: 2K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW357 012 0402
Coding: 00065493
Shop #: WSC 35110
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 0A AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD09B7LE
Coding: 0012353
VCID: 7DFBE72D24EA4F1
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000022
Shop #: WSC 00028 028 00001
VCID: 74EDC20917A00E9
Part No: 2K0 920 842 E
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0017101
Shop #: WSC 48992 141 83610
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0191
Revision: H16 Serial number: 2000K07C200787
Coding: E9801F0E0002028002
Shop #: WSC 73430 790 12345
VCID: 346D020957204E9
Component: IMMO VDD 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2315
Coding: 0000048
VCID: 36693801415C5C9
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 336F0115522E491
Address 46: Central Conv. Labels: 1K0-959-433-MIN.lbl
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 008B04087F2D8405484A016010C0
VCID: 79F3F33D30C2731
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000048
VCID: 377735054656A51
Part No: 1K0 035 153 D
Component: Radio BNO 0011
Coding: 0020200
VCID: 2143FB5DF8D2CB1
Sprawdzałem po kolei i nie wiem czy nie pomieszałem kodowania modułu kierownicy... jakie powinno być poprawne dla bez taxi/manualna skrzynia/3 ramienna kiera bez multi/bez tiptronic/CCS bez Board Comp./tylna wycieraczka zamontowana ?
