Witam. Dziś zrobiłem pierwszy skan VCDSem i wyskoczyły mi błędy. Może ktoś mi pomóc w ich rozszyfrowaniu ?
Moja wiedza jest bardzo niewielka i na razie ciężko mi to ogarnąć.
Monday,25,March,2013,15:31:43:10074
VCDS Version: Beta 11.3.0
Data version: 20110801
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ8W069925 Mileage: 184020km/114344miles
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 021 RN HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 1397
Revision: --H07--- Serial number: VWX7Z0G83NO1EL
Coding: 0000072
Shop #: WSC 01324 758 00200
VCID: 7CF3F0C343CF
1 Fault Found:
005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
P161C - 000 - -
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 14
Mileage: 173605 km
Time Indication: 0
Date: 2000.00.00
Time: 05:37:58
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00101000
Temperature: 15.3°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 0
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021190
Shop #: WSC 01324 785 00200
VCID: 73E1DBFF6E91
No fault code found.
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 79FDE9D74CFD
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007585960
Coding: 008B8F2100040F0047120C000000000000097B075C000100000000000000
VCID: 6FE9D78F02B9
Subsystem 1 - Part No: 2K1 955 119 C
Component: Wischer 150102 021 0501
Coding: 00038805
Shop #: WSC 01324
Address 10: Park/Steer Assist (J446) Labels: 1K0-919-475.clb
Part No SW: 1K0 919 475 HW: 1K0 919 475
Component: PARKHILFE 005 1104
Revision: 00005000 Serial number: 0 263 004 193
Coding: 000001
VCID: EFE9578F82B9
4 Faults Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
014 - Defective - Intermittent
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 183802 km
Time Indication: 0
Date: 2000.00.00
Time: 20:36:45
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 183802 km
Time Indication: 0
Date: 2000.00.00
Time: 20:36:44
01545 - Sensor for Parking Aid; Rear Left (G203)
Fault Priority: 3
Fault Frequency: 12
Reset counter: 229
Mileage: 198065 km
Time Indication: 0
Date: 2000.00.00
Time: 06:39:13
01548 - Sensor for Parking Aid; Rear Right (G206)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 183802 km
Time Indication: 0
Date: 2000.00.00
Time: 20:36:08
Part No SW: 1T0 909 605 D HW: 1T0 909 605 D
Component: 04 AIRBAG VW8 021 0100
Revision: 02021000 Serial number: 003B9D063PK4
Coding: 0012340
VCID: 366722EB3D63
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
VCID: 74E3D8E36B9F
Part No SW: 1T0 920 864 A HW: 1T0 920 864 A
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0G83NO1EL
Coding: 0007101
Shop #: WSC 65536 645 577705
VCID: 33611BFF2E11
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Coding: 0000011
VCID: 366722EB3D63
2 Faults Found:
007 - Short to Ground
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 254
Reset counter: 120
Mileage: 139400 km
Time Indication: 0
Locked
Temperature: 21.0°C
Temperature: 22.0°C
Voltage: 14.53 V
02251 - Heater Unit Locked
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 152716 km
Time Indication: 0
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 220907F2001689
Coding: E9A07F06000A028002
VCID: 306B14F3DF07
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VDD 1212
VCID: 33611BFF2E11
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1201
Coding: 0000181
VCID: 387B2CD33777
2 Faults Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.071 H08 1901
VCID: 356525E72065
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Component: KSG PQ35 G2 020 0204
Coding: 809002085103087F2D06840560084F03E0FCA0
VCID: 83010B3FBE31
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000180
VCID: 397D29D70C7D
Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
Component: Radio BVX 035 0047
Revision: 00035000 Serial number: VWZ1Z2G6274257
Coding: 0020200
VCID: 68DBBC932757
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1202
Coding: 0000144
Shop #: WSC 01324 785 1012552
VCID: 37792FEF3A69
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
VCID: 387B2CD33777
2 Faults Found:
00099 - Right Rear Central Locking (Safe) Motor (V164)
00931 - Locking Module for Central Locking; Rear Right (F223)
