Strona 2 z 2
: śr wrz 25, 2013 23:19
autor: Cesarz
stach, nie wieze w przypadki a moja żona nie jest blondynka :mrgreen:
[ Dodano: Czw Wrz 26, 2013 20:31 ]
A skan (wykonany dzięki koledze pencilpl ) wygląda tak.... jeżeli chodzi komfort to nic tam nie ma... Wyglada tylko ze STOP się kończy...
Thursday,26,September,2013,17:04:34:32264
VCDS Version: Release 11.11.3
Data version: 20130531
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72 76 77
VIN: Mileage: 238960km/148482miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 HK HW: 028 101 184 4
Component: R4 2,0L EDC G210AG 7000
Revision: 12345678 Serial number: VWZ7Z0D0741332
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 73EFC11512AE091
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 Q HW: 02E 927 770 AD
Component: GSG DSG 041 0803
Revision: 00004010 Serial number: 00000409150454
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 2045FE59F3D8C29
Part No: 1K0 907 379 K
Coding: 0021190
VCID: 3A712C317544B89
Part No: 1K0 907 044 AC
Component: ClimatronicPQ35 066 0404
Shop #: WSC 00000 000 00000
VCID: 68D5A6795B68FA9
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000000781073
Coding: A18A8F2810070F00570F0C006400000032097F0F3250012C000000000000
Shop #: WSC 00066 000 00000
VCID: 336F0115522E491
Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.LBL
Coding: 00065493
Shop #: WSC 00066
2 Faults Found:
00887 - Switch for Emergency Flasher (E229)
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 194
Mileage: 238946 km
Time Indication: 0
OFF
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
00526 - Brake Light Switch-F
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 190
Mileage: 238367 km
Time Indication: 0
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
ON
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD09KUJR
Coding: 0012338
VCID: 356B3F0D5C5A571
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0012042
VCID: 31630B1DA8327B1
Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0030
Part No: 1T0 920 871 A
Component: KOMBIINSTRUMENT VDD 0812
Coding: 0007103
Shop #: WSC 00001 001 00001
Address 18: Aux. Heat Labels: 1K0-815-071.lbl
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Coding: 0000011
VCID: 2A511C7185E4089
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.lbl
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 300112F1002690
Coding: 358002
Shop #: WSC 01357 011 00200
VCID: 3A712C31B544B89
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VDD 0812
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0157
Coding: 0000116
VCID: F4ED420997A08E9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.6 1401
VCID: 2F670D65BE066D1
Address 46: Central Conv. Labels: 1K0-959-433-MAX.lbl
Part No SW: 1K0 959 433 AR HW: 1K0 959 433 AR
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 989002085103487F3F04840470080F0160A140
Shop #: WSC 00580 210 14094
VCID: 80051ED9D318A29
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Part No: 1T0 959 702
Coding: 0000116
VCID: F5EB7F0D9CDA971
Part No: 1K0 035 186 L
Component: Radio BVX 010 0022
Coding: 0042400
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 30650E19A338729
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 02 Einparkhilfe 0101
VCID: 2D5B176DB40A1F1
Address 77: Telephone Labels: 1K0-035-729-UNI.lbl
Part No: 1K0 035 729 E
Component: CIB PAH HW 202 SW 0308
Coding: 0000364
VCID: 2B5F19758A1E111
: czw wrz 26, 2013 23:49
autor: Turanek
Włącznik świateł awaryjnych i włącznik świateł stopu.
Czy masz zakodowaną obsługę szyb pomimo wyciągniętego kluczyka i otwartych drzwi?
Sterowniki szyb mają zasilanie bezpośrednio z aku. Przy odłączonym zapłonie przyciski sterownia nie działają, więc tylko sygnał po CANie może je zmusić do pracy. CANem zarządza Gateway, co nie znaczy, ze on musi być walnięty, np. czujnik deszczu poprzez Bordentza podaje sygnał do zamknięcia szyb.
Często spotykam sporadyczne błędy komunikacji pomiędzy sterownikami.
Ja bym próbował na początek odłączenie CAN przy Gatewayu.
: pt wrz 27, 2013 01:50
autor: Cesarz
Dobre pytanie... niestety nie pamiętam. Reszte sugestii sprawdze jak zjade do domu :piwo:
[ Dodano: Pią Wrz 27, 2013 01:53 ]
Turanek pisze:Ja bym próbował na początek odłączenie CAN przy Gatewayu.
eee... znaczy jak?
: pt wrz 27, 2013 07:26
autor: Turanek
marynarz75 pisze:eee... znaczy jak?
Odłączyć wtyczkę ?? :>
: pt wrz 27, 2013 08:47
autor: Cesarz
Turanek pisze:Odłączyć wtyczkę ??
Tak to każdy potrafi :P Spodziewałem się jakiś supertajnych operacji z VCDS-em, połączonych ze wsparciem logistycznym całego forum i ściąganiem kodów z Wolfsburga :haha:
Re: Problem z samootwieraniem sie szyb
: pn sty 13, 2014 21:57
autor: Marko_77_
Witam chciałbym odświeżyć temat. Jakiś czas temu zdążyło mi sie otwarcie jednego okna tylnego ale ostatni w sobotę to juz masakra! Powrót z zakupów a tu wszystkie cztery okna otwarte na jakieś 10-15 cm. Moze ktoś mi podpowiedziec co i jak sprawdzić VCDSem.
Z góry dzieki
: pn sty 13, 2014 22:14
autor: Cesarz
Marko_77 na pocieszenie powiem Ci że u mnie się skończyło na tych 2 razach, bez jakiejkolwiek ingerencji, wiec tajemnica pozostała tajemnicą... :>
: pn sty 13, 2014 22:18
autor: Marko_77_
Dzieki za pocieszenie :) postaram sie przeskanowac autko niebawem, bo dodatkowo od jakiegoś czasu nie otwierają mi wieczorami częściej tylne drzwi za pasażerem. Jakieś fatum:)
