Niestety zmiana polaryzacji nic nie dała. A oto skany:
Zaraz po zakodowaniu:
Tuesday,02,June,2015,18:57:25:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: VSSZZZ7NZEV508595 License Plate:
Chassis Type: 7N (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 20 25 2E 37 42 44 46 4C 4F 52
53 56 61 62 6C 72
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HL HW: 03L 906 018 M
Component: R4 2,0L EDC H28 9959
Revision: 44H28--- Serial number:
Coding: 0019001A042501080000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01103L906018HL 003008
ROD: EV_ECM20TDI01103L906018F.rod
VCID: 7BFFEFACF21BA1C6C11-802E
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 P HW: 7N0 614 109 P
Component: J104 C3 450M VD6D 0030
Revision: --H07--- Serial number: 00000007505706
Coding: 0020091
Shop #: WSC 00020 790 00000
VCID: 3A712AA875A158CE9A7-806F
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 7N0 907 044 Q HW: 7N0 907 044 Q
Component: Clima-Sharan H02 0404
Revision: 00001K02
Coding: 021010C549
ASAM Dataset: EV_ClimatronicSharan A01005
ROD: EV_ClimaAutoSharaBasis_VW36.rod
VCID: 3E7926B8A18974EEA6F-806B
Subsystem 1 - Part No SW: 7N0 907 049 C HW: 7N0 907 049 C
Component: KBT-H 004 0103
Serial number: 20131009000000134094
1 Fault Found:
9481200 - Coolant Pressure
B10AB F0 [009] - Too Low
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 85
Mileage: 17684 km
Date: 2016.14.29
Time: 14:23:38
Address 09: Cent. Elect. (J519) Labels: User\1K0-937-08x-09.lbl
Part No SW: 5K0 937 087 AB HW: 5K0 937 087 AB
Component: BCM PQ35 H 122 0173
Revision: BE122001
Coding: 40180A3B8925F1C0408800C81400816443719288426D29626480C72000C1
Shop #: WSC 12030 123 104857
VCID: 75EBF994DC3FF7B6B75-8020
Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119 Labels: USER\1KX-955-119.LBL
Component: WWS 130831 31 0032
Coding: 004DBD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547
Component: RLFS 024 0042
Coding: 0228DD
Subsystem 3 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
2 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 2
Reset counter: 139
Mileage: 17844 km
Time Indication: 0
Date: 2017.14.12
Time: 18:49:11
Term 15 On
Voltage: 11.70 V
ON
ON
ON
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Fault Priority: 4
Fault Frequency: 1
Reset counter: 139
Mileage: 17844 km
Time Indication: 0
Date: 2017.14.12
Time: 18:49:11
Term 15 On
Voltage: 11.70 V
ON
ON
ON
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 7N0 919 475 A HW: 7N0 919 475
Component: PARKHILFE 8K H06 0012
Revision: -------- Serial number: 28231329104139
Coding: 308002
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 397335A4B8A753D693D-806C
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag00F H12 0014
Serial number: 003LGPLWMC2P
Coding: 003046
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428_VW36.rod
VCID: 3F875BBCA6837DE6AD9-806A
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60001BDD18DD/
Coding: 000000
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS60CBFBBD18DDO
Coding: 000000
Crash sensor for side airbag; rear driver side:
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60651ADD189D$
Coding: 000000
Crash sensor for side airbag; rear passenger side:
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS6083B3B3189DV
Coding: 000000
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS60F677BC189D/
Coding: 000000
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BD HW: 5K0 953 569 B
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130926101447
Coding: 108A240000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 6FE7CBFCB663CD667D9-803A
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D
Component: E221__MFL-TAP H02 0103
Coding: E20000
Part No SW: 7N5 920 970 J HW: 7N5 920 970 J
Component: KOMBI H04 0811
Serial number: 00000000000000
Coding: 441F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
Part No: 7N0 963 271 E
Component: Zuheizer 051 2940
Revision: 00051000 Serial number: 09024297000000
Coding: 0000041
VCID: 36693E9841B9BCAE7EF-8063
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 241113F1002449
Coding: 468203
Shop #: WSC 12030 000 1048576
VCID: 7CFDECB0FF15A6FEC8B-8029
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 7N0 857 511 P HW: 8P0 857 511 C
Component: FLA H04 0012
Revision: AA001002
Coding: 0102816B74745D545420363E01
VCID: 40855840D37D021ED43-8015
Component: IMMO H04 0811
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EAD15AE80D81A84EAA7-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7665361452
Coding: 020100
VCID: 2B5F1FEC4AFBF146111-807E
Address 37: Navigation (J794) Labels: None
Part No SW: 5P0 035 191 S HW: 5P0 035 191 S
Component: RNS315-EU H73 0407
Serial number: SEZAZ2N0549894
Coding: 040004010400240000061002
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3B7F2FACB29B61C6811-806E
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V4 0050
Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb
Part No SW: 7N0 959 793 G HW: 7N0 959 793 G
Component: TSG FA H03 0553
Revision: Serial number: 0000076868155
Coding: 011106209001411011
VCID: 46894E58F1592C2EEEF-8013
Address 44: Steering Assist Labels: None
Part No: 7N0 909 144 R
Component: EPS_ZFLS Kl. 275 3501
Revision: 00H21000
VCID: 428152481D71100EC27-8017
Address 46: Central Conv.
Cannot be reached
Address 4C: Tire Pressure II
Cannot be reached
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1642
Coding: 050B0500
VCID: EFE74BFC3E634D66FD9-80BA
Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 2 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000001499584
Coding: 0024167
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1642
Coding: 030F7859
VCID: F1E34D8428575B96EBD-80A4
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Address 62: Door, Rear Left (J388) Labels: 7N0-959-794.clb
Part No SW: 7N0 959 794 G HW: 7N0 959 794 G
Component: TSG HL H04 0553
Revision: Serial number: 0000077148235
Coding: 010004200001411001
VCID: 4797435CF6533526159-8012
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7N0 907 441 HW: 7N0 907 441
Component: J772__Rearview 0020
Revision: 00H13000 Serial number: 525 PA8J392335
Coding: 0020011
VCID: EED956F8F969446EF6F-80BB
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 75
Mileage: 17512 km
Time Indication: 0
Date: 2016.14.19
Time: 18:00:36
Term 15 On
Reverse OFF
Count: 3
Address 72: Door, Rear Right (J389) Labels: 7N0-959-794.clb
Component: TSG HR H04 0553
Revision: Serial number: 0000077154201
A ten po skasowaniu błędów:
Tuesday,02,June,2015,19:04:07:65217
53 56 61 62 6C 72
Readiness: 0 0 0 0 1
Coding: 0020091
Revision: 00001K02
Coding: 021010C549
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 109
Mileage: 17936 km
Date: 2017.14.27
Time: 18:56:37
Revision: BE122001
Coding: 004DBD
Coding: 0228DD
Coding: 000000
Coding: 000000
Coding: 308002
Coding: 003046
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 108A240000
Coding: E20000
Coding: 441F01
Coding: 0000041
Coding: 468203
Revision: AA001002
Serial number:
Coding: 000000
Coding: 020100
Data medium:
Revision: 00H21000
Cannot be reached
Cannot be reached
Coding: 050B0500
Address 52: Door Elect, Pass. (J387) Labels: 7N0-959-792.clb
Part No SW: 7N0 959 792 G HW: 7N0 959 792 G
Component: TSG BF H03 0553
Revision: Serial number: 0000077793363
Coding: 011504209E01411011
VCID: 458B4954CC5F2736E75-8010
Coding: 0024167
Address 56: Radio
Cannot be reached
Coding: 030F7859
Coding: 0020011
1 Fault Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 109
Mileage: 17936 km
Time Indication: 0
Date: 2017.14.27
Time: 18:56:37
Term 15 On
Reverse OFF
Count: 3
-- Wt cze 02, 2015 22:06 --
Miki76 pisze:mirek1967 pisze:Dzięki za pomoc zaraz zamienię kabelki i powiem czy pomogło
na przyszłość zmniejszaj wielkość zdjęć przed wstawieniem na forum bo się całe rozjeżdża
Sorry już zmniejszone
