KODY BLEDOW
- SeeSoon
- Auto:: Touran, 1.9 BKC, 2004
- Imię:: Dawid
- Podziękował: 8 razy
Re: KODY BLEDOW
Witam, potrzebna pomocy:
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 EH HW: 03G 906 018 EH
Component: R4 2.0l PPD1.2 G 4355
Revision: --H32--- Serial number: VWX7Z0FN3NE1NT
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 6FEA1FF77E99ED3A55-803A
1 Fault Found:
004705 - PD Unit Injector: Cylinder 1 (N240)
P1261 - 006 - Regulation Range Exceeded - Intermittent
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 3
Reset counter: 16
Mileage: 265283 km
Time Indication: 0
Date: 2000.00.00
Time: 22:50:53
RPM: 2016 /min
Torque: 208.0 Nm
Speed: 57.0 km/h
77.22 %
Text: 5.375 uF
Text: 13.75 mJ
Text: 12 mJ
T.B. Angle: 0.0°
Readiness: N/A
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000005947487
Coding: E38B8F2110040F0007120C0000000000000B7F0F5C0001
Shop #: WSC 01324 785 00200
VCID: 6CD008FB4F8F162270-8038
Subsystem 1 - Part No: 1T0 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 091106 020 0501
Coding: 00038805
Shop #: WSC 01324
Subsystem 2 - Part No: 1K0 955 559 AD Labels: 1K0-955-559-AF.CLB
Component: RLS 271006 014 1201
Coding: 06762533
Shop #: WSC 01324
3 Faults Found:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 25
Reset counter: 230
Mileage: 265357 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
ON
Voltage: 14.00 V
ON
OFF
OFF
OFF
OFF
02399 - Control Circuit for Terminal 30 for Interior Illumination
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 265062 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.75 V
OFF
OFF
OFF
OFF
OFF
00059 - Terminal 30 for Interior Lighting
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 265020 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.20 V
OFF
OFF
OFF
OFF
OFF
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 1K0 815 007 BC
Component: Standheizer 041 4303
Revision: 00041000 Serial number: 09011075000000
Coding: 0001012
Shop #: WSC 02750 175 04575
VCID: 66C47AD351632C7226-8032
1 Fault Found:
02245 - Connection; RF Remote Control
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 206
Mileage: 258415 km
Time Indication: 0
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 271009F2000569
Coding: ED817F0E400A02009002
Shop #: WSC 70250 259 136509
VCID: 69DE71EF407D030A0B-803C
2 Faults Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 195
Mileage: 264760 km
Time Indication: 0
Date: 2000.00.00
Time: 15:49:02
000 - -
Fault Status: 01100000
Fault Priority: 1
Reset counter: 255
Mileage: 264760 km
Time Indication: 0
Date: 2000.00.00
Time: 15:49:02
Part No SW: 1T0 959 702 E HW: 1T0 959 702 E
Component: Tuer-SG 005 0927
Coding: 0000180
VCID: 3A7CFEA3755B7892B2-806E
3 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00097 - Front Passengers Central Locking (Safe) Motor (V162)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Component: Tuer-SG 005 0906
Coding: 0000144
Shop #: WSC 00000 000 00000
VCID: 377AE797464965FA4D-8062
2 Faults Found:
00098 - Rear Left Central Locking (Safe) Motor (V163)
00930 - Locking Module for Central Locking; Rear Left (F222)
Coding: 0000078
1 Fault Found:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 16
Mileage: 265283 km
Time Indication: 0
Date: 2000.00.00
Time: 22:50:53
RPM: 2016 /min
Torque: 208.0 Nm
Speed: 57.0 km/h
77.22 %
Text: 5.375 uF
Text: 13.75 mJ
Text: 12 mJ
T.B. Angle: 0.0°
Readiness: N/A
Coding: 00038805
Shop #: WSC 01324
Coding: 06762533
Shop #: WSC 01324
3 Faults Found:
Fault Priority: 4
Fault Frequency: 25
Reset counter: 230
Mileage: 265357 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
ON
Voltage: 14.00 V
ON
OFF
OFF
OFF
OFF
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 265062 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.75 V
OFF
OFF
OFF
OFF
OFF
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 265020 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.20 V
OFF
OFF
OFF
OFF
OFF
Coding: 0001012
1 Fault Found:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 206
Mileage: 258415 km
Time Indication: 0
2 Faults Found:
011 - Open Circuit
Fault Priority: 3
Reset counter: 195
Mileage: 264760 km
Time Indication: 0
Date: 2000.00.00
Time: 15:49:02
000 - -
Fault Priority: 1
Reset counter: 255
Mileage: 264760 km
Time Indication: 0
Date: 2000.00.00
Time: 15:49:02
Coding: 0000180
3 Faults Found:
Coding: 0000144
2 Faults Found:
- Letis
- Auto:: Touran 2.0 AZV 2003
- Otrzymał podziękowań: 32 razy
Re: KODY BLEDOW
To twoje auto ? Coś dużo tego ostatnio nie było aż tyle.SeeSoon pisze:Witam, potrzebna pomocy:
Coding: 0000078
1 Fault Found:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 16
Mileage: 265283 km
Time Indication: 0
Date: 2000.00.00
Time: 22:50:53
RPM: 2016 /min
Torque: 208.0 Nm
Speed: 57.0 km/h
77.22 %
Text: 5.375 uF
Text: 13.75 mJ
Text: 12 mJ
T.B. Angle: 0.0°
Readiness: N/A
Coding: 00038805
Shop #: WSC 01324
Coding: 06762533
Shop #: WSC 01324
3 Faults Found:
Fault Priority: 4
Fault Frequency: 25
Reset counter: 230
Mileage: 265357 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
ON
Voltage: 14.00 V
ON
OFF
OFF
OFF
OFF
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 265062 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.75 V
OFF
OFF
OFF
OFF
OFF
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 265020 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.20 V
OFF
OFF
OFF
OFF
OFF
Coding: 0001012
1 Fault Found:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 206
Mileage: 258415 km
Time Indication: 0
2 Faults Found:
011 - Open Circuit
Fault Priority: 3
Reset counter: 195
Mileage: 264760 km
Time Indication: 0
Date: 2000.00.00
Time: 15:49:02
000 - -
Fault Priority: 1
Reset counter: 255
Mileage: 264760 km
Time Indication: 0
Date: 2000.00.00
Time: 15:49:02
Coding: 0000180
3 Faults Found:
Coding: 0000144
2 Faults Found:
Wysłane z mojego Redmi 3 przy użyciu Tapatalka
- SeeSoon
- Imię:: Dawid
Re: KODY BLEDOW
Nie nie @Letis nie moje, wczoraj na spocie miałem kompa i chłopaka scany robiłem
Wysłane z mojego Redmi Note 3 przy użyciu Tapatalka
- krankor
- Auto:: Touran 1T1, 1.9 AVQ 2004
- Imię:: Grzegorz
- Podziękował: 22 razy
- Otrzymał podziękowań: 52 razy
Re: KODY BLEDOW
Ja tez potrzebuje pomocy.
Z rok temu wyskakiwał komunikat " ABGAS WERKSTATT ! " i żółta kontrolka silnika. Po skanowaniu wychodziło, że to czujnik temperatury na bloku w tym przypadku. Wymieniłem (wyrywając gwint z bloku przy okazji i powodując powolny wyciek chłodziwa, naprawiłem to) czujnik i jak ręką odjął.
Dwa miesiące był spokój, aż znowu wyskoczył ten sam komunikat ABGAS WERKSTATT i kontrolka silnika. Sądziłem, że to znów ten sam czujnik. Po kilku dniach zniknął komunikat przy każdym odpaleniu i zgasła kontrolka. Na dwa dni. Zaczął piszczeć akurat na przeglądzie w diagnostyce.
Skanowanie pokazało coś innego
_____________
Monday,06,November,2017,22:11:09:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 3D 42 44 46 52 56 62 72
VIN: xxxxxxxxxxxxxxxxxxxxxx Mileage: 282370km/175456miles
15-Airbags -- Status: OK 0000
3D-Special Function -- Status: OK 0000
56-Radio -- Status: OK 0000
Part No SW: 03G 906 016 BT HW: 028 101 176 1
Component: R4 1,9L EDC G010SG 7210
Revision: 12345678 Serial number: VWZ7Z0D9768753
Coding: 0000072
Shop #: WSC 40711 150 82544
VCID: 76E7E2EB7A07
3 Faults Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 000 - -
RPM: 882 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 11.7°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 - 000 - -
RPM: 882 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 11.7°C
Bin. Bits: 10110000
16785 - EGR System: Insufficient Flow
P0401 - 000 - -
RPM: 1428 /min
Torque: 44.0 Nm
Speed: 52.0 km/h
Load: 13.7 %
Duty Cycle: 14.7 %
Bin. Bits: 00001000
Mass Air / Rev.: 235.0 mg/str
Mass Air / Rev.: 515.0 mg/str
Readiness: 1 1 0 0 0
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021190
VCID: 3A7F36DB0E9F
No fault code found.
dalej uszkodzony zamek w drzwiach kierowcy.
O ile świece ciągle pokazują uszkodzenie-podejrzewam wiązkę. Bo wymiana świec nic nie daje. A sprawdzić 5V świecę 12V to chyba wyjdzie jak sprawdzanie zapałek przez zapalenie. A tak w ogóle to ile taka świeca amper ciągnie, może jakimś zasilaczem by dało radę.
Ważniejszy jest ten błąd EGRu, przejmować się nim? Zaglądać tam? Auto chodzi normalnie. Skasowałem błędy i niby jest spokój. Ale czy z tego powodu komputer nie zgasi mi silnika na amen w pewnym pięknym momencie.
_____________
Chassis Type: 1K0
Coding: 0000072
VCID: 76E7E2EB7A07
3 Faults Found:
P0673 - 000 - -
RPM: 882 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 11.7°C
Bin. Bits: 10110000
P0674 - 000 - -
RPM: 882 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 11.7°C
Bin. Bits: 10110000
P0401 - 000 - -
RPM: 1428 /min
Torque: 44.0 Nm
Speed: 52.0 km/h
Load: 13.7 %
Duty Cycle: 14.7 %
Bin. Bits: 00001000
Coding: 0021190
VCID: 3A7F36DB0E9F
pozdrawiam Grzegorz
- GioW
- Auto:: 2.0 TDI BKD HL '04
- Imię:: Janek
- Podziękował: 27 razy
Re: KODY BLEDOW
Ktoś potrafi powiedzieć od czego ten błąd
Kod: Zaznacz cały
Adres 19: CAN Gateway (J533) Plik etykiet: Brak
Oznaczenie elementu SW: 7N0 907 530 BG HW: 7N0 907 530 AN
Komponent: J533 Gateway X56 1671
Weryfikacja: X56 Numer seryjny: 240812F2001848
Kodowanie: 350002
Kod serwisu: WSC 85046 004 02308
VCID: 76E99D49C19949A80B0
Znaleziono 1 błąd:
03981 - Nieznany kod błędu
000 - -
Ramka zamrożona:
Stan błędu: 01110000
Priorytet błędu: 6
Częstość błędu: 1
Wew.licznik błędów: 189
Przebieg: 263019 km
Wskaźnik czasu: 0
Data: 2000.00.00
Czas: 21:40:04-
borcio83
- Auto:: Touran 1,6 tdi CAYC 2014
- Podziękował: 70 razy
Re: KODY BLEDOW
Bylem sprawdzilem tourana
https://www.otomoto.pl/oferta/volkswage ... zUnDL.html
i wyszlo tak:
wszystkie szyby 2006 a przednia 2007 r.
Na liczniku o trzy tysiace wiecej km niz w sterowniku silnika.Ogolnie najechane okolo 280 tys a w ogloszeniu troooche mniej.
VIN: WVGZZZ1TZ7W019334
Ksiazki nie bylo,pidobno wlasciciel ma w domu.
Autko wizualnie nie zmeczone,srodek zadbany.
Jazdy probnej nie bylo bo wlasciciela nie bylo tylko jakis mlody ktory nie zezwalal na jazde probna.
Odp o co chodzi z ta roznica w przebiegu....
Oto skan błędów:
Revision: 00H52000 Serial number: 00000005950543
Coding: E10B8E2100040F1407120C000000000000097F075C0001
VCID: 6CD01FF24F10B72125-8038
Coding: 00038805
Shop #: WSC 01324
Subsystem 2 - Part No: 1K0 955 559 AC Labels: 1K0-955-559-AF.CLB
Component: RLS 041007 047 0204
Coding: 06500389
Shop #: WSC 01324
1 Fault Found:
00924 - Relay for Headlamp Cleaning System (J39)
Fault Priority: 4
Fault Frequency: 1
Reset counter: 213
Mileage: 286386 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
ON
Voltage: 14.20 V
ON
ON
OFF
OFF
OFF
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0012022
VCID: 010E5E4658924A49E6-8054
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
Part No: 1K0 815 071 R
Component: Zuheizer 050 2302
Coding: 0000011
Shop #: WSC 47236 123 179606
VCID: 3460C79257A02FE13D-8060
2 Faults Found:
007 - Short to Ground
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 5
Reset counter: 76
Mileage: 139729 km
Time Indication: 0
Malfunction
Temperature: 48.0°C
Temperature: 48.0°C
Voltage: 14.74 V
02251 - Heater Unit Locked
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 139849 km
Time Indication: 0
Part No SW: 1T0 959 701 E HW: 1T0 959 701 E
Coding: 0000181
VCID: 397EF6A670C2D289EE-806C
2 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Address 46: Central Conv. Labels: 1K0-959-433-MAX.lbl
Coding: 809002085103087F2D06840560084F03E0FC00
VCID: 0302544E428E5859F4-8056
Coding: 0000180
VCID: 3A7CE9AA75C4D991E7-806E
2 Faults Found:
Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
Component: Radio BVX 034 0045
Revision: 00034000 Serial number: VWZ1Z2F2747879
Coding: 0042402
VCID: 68D863E25BE89B0141-803C
1 Fault Found:
00857 - CD Changer Unit (R41)
Address 69: Trailer Labels: RETROFIT69.lbl
Part No SW: 30/ 1V2 .01 HW: 30/ 1V2 .01
Component: ANHAENGER_MODULE UN 0030
Coding: 0000001
VCID: 5ABC492A95843991C7-800E
5 Faults Found:
02562 - Trailer; Brake Lamps
011 - Open Circuit
02563 - Trailer; Right Tail Lamps (M61)
011 - Open Circuit
02564 - Trailer; Left Tail Lamps (M60)
011 - Open Circuit
02565 - Trailer; Right Turn Signals (M63)
011 - Open Circuit
02566 - Trailer; Left Turn Signals (M62)
011 - Open Circuit
Coding: 0000144
Shop #: WSC 01324 785 1012552
VCID: 3878F3A24BC8CB8111-806C
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
Proszę o interpretacje błędów
i wyszlo tak:
Oto skan błędów:
Coding: 00038805
Shop #: WSC 01324
Coding: 06500389
Shop #: WSC 01324
1 Fault Found:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 213
Mileage: 286386 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
ON
Voltage: 14.20 V
ON
ON
OFF
OFF
OFF
Coding: 0012022
1 Fault Found:
Coding: 0000011
2 Faults Found:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 76
Mileage: 139729 km
Time Indication: 0
Malfunction
Temperature: 48.0°C
Temperature: 48.0°C
Voltage: 14.74 V
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 139849 km
Time Indication: 0
Coding: 0000181
2 Faults Found:
Coding: 0000180
2 Faults Found:
Coding: 0042402
1 Fault Found:
Coding: 0000001
5 Faults Found:
011 - Open Circuit
011 - Open Circuit
011 - Open Circuit
011 - Open Circuit
011 - Open Circuit
Coding: 0000144
1 Fault Found:
Pozdro borcio83
- Wojol
- Auto:: 1T2, 2.0 BMM, 2007
- Imię:: Krzysiek
- Podziękował: 14 razy
Re: KODY BLEDOW
Mam kilka błędów, błąd z silnika ciagnie się już za mną rok, często wyskakuje check engine przy odpaleniu auta na benzynie, na gazie nic, w czym może tkwić problem?
Błąd klimy mimo, że wszystko działa.
Błąd zamków mimo, że wymienione dopiero na nowe i wszystkie drzwi i szyby elegancko się zamykają jak i otwierają.
Kod: Zaznacz cały
VIN: WVGZZZ1TZ6W017296 Numer rejestracyjny:
Przebieg: 234120km Numer naprawy:
Typ podwozia: 1T (1K0)
Skanowanie: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVGZZZ1TZ6W017296 Przebieg: 234120km
Adres 01: Silnik Plik etykiet: 06A-906-033-BGU.lbl
Oznaczenie elementu: 06A 906 033 ET
Komponent: SIMOS71 1.6l 2VG 9208
Weryfikacja: --H01--- Numer seryjny: VWZ7Z0E2242467
Kodowanie: 0000071
Kod serwisu: WSC 48186 141 93507
VCID: 75E0D9481CC137E9CA-8020
Znaleziono 1 błąd:
16555 - Zespół 1; system pomiaru paliwa
P0171 - 006 - system za ubogi - Sporadyczny
Ramka zamrożona:
Prędkość: 0.0 km/h
Wspł.Lambda: 0.992
Napięcie: 0.420 V
Lambda: 18.0 %
Kody gotowości: 0110 1101
Adres 08: Klimatyzacja Plik etykiet: 1K0-907-044.lbl
Oznaczenie elementu: 1K0 907 044 AT
Komponent: ClimatronicPQ35 066 0606
VCID: 79F8D57830D95389AE-802C
Znaleziono 1 błąd:
01274 - Silnik nastawczy klapy spiętrzania powietrza (V71)
000 - -
Adres 42: Elektr.drzwi kier. Plik etykiet: AKP\1K0-959-701-MAX1.clb
Oznaczenie elementu: 1T0 959 701 A
Komponent: Tuersteuergeraet 09 0157
Kodowanie: 0000052
VCID: 356019485C4177E90A-8060
00100 - Przycisk zamykania od wewnątrz po stronie kierowcy (E308)
008 - Niezrozumiały sygnał
00928 - Jednostka zamykająca zamka centralnego po stronie kierowcy (F220)
Adres 52: Elektr.drzwi pas. Plik etykiet: AKP\1K0-959-702-MAX1.clb
Oznaczenie elementu: 1T0 959 702 A
Kodowanie: 0000052
VCID: 36621E4441477CF103-8062
Znaleziono 1 błąd:
00929 - Jednostka zamykająca zamka centralnego po stronie pasażera (F221)
no010
- Auto:: VW T1 1.9 BLS '07
- Imię:: Radek
- Podziękował: 4 razy
diagnoza błędów
W rodzinie pojawił się drugi VW, tym razem Passat B7.
Proszę o pomoc w diagnozie błędów oraz pomoc w ich usunięciu.
Wydaje mi się że błędy powiązane są z modułem bluetooth którego nie wykrywam.
VCDS wysypuje takie faulty
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 P HW: 3AA 937 087 P
Component: BCM PQ47 H 422 0474
Revision: BB422001
Coding: 0008000000000000009800805400816403510088426D85606480C7200041
Shop #: WSC 05311 000 00000
VCID: 479A805EF636B47968-8012
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 25071 10 0603
Coding: 00B795
Component: RLS 310713 05 54 0403
Coding: 02302A
1 Fault Found:
03789 - Terminal 75 Limp Mode Active
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 186
Mileage: 203515 km
Time Indication: 0
Date: 2018.07.13
Time: 18:07:01
Term 15 On
Voltage: 11.50 V
ON
ON
ON
ON
OFF
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3AA 920 870 P HW: 3AA 920 870 P
Component: KOMBI H04 0811
Coding: 161F00
Shop #: WSC 63606 181 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 3F8A98BEA6E6FCB9D0-806A
1 Fault Found:
13654544 - Databus
U1121 00 [009] - Missing Message
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 120
Reset counter: 175
Mileage: 203861 km
Date: 2018.10.08
Time: 15:07:20
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 300713F1000645
Coding: 462006
Shop #: WSC 05314 000 00000
VCID: 7BF22CAEFA7E2099BC-802E
1 Fault Found:
01303 - Telephone Transceiver (R36)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 203452 km
Time Indication: 0
Date: 2018.07.10
Time: 15:58:32
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 00000008
VCID: 6FEA08FEBE064C3900-803A
1 Fault Found:
02174 - Analog/Digital clock
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 203452 km
Time Indication: 0
Date: 2018.07.10
Time: 15:59:09
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 042 0082
Revision: 00000001 Serial number: VWZ1Z2M4262059
Coding: 05000200010013
Shop #: WSC 40330 222 180052
VCID: 72EC018AAD3461D1EF-8026
3 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 143
Mileage: 203452 km
Time Indication: 0
Date: 2018.07.10
Time: 15:59:20
00856 - Radio Antenna
011 - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 143
Mileage: 203452 km
Time Indication: 0
Date: 2018.07.10
Time: 15:59:20
03138 - Input AUX IN
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 143
Mileage: 203452 km
Time Indication: 0
Date: 2018.07.10
Time: 15:59:25
Proszę o pomoc kolegów maniakóVW
Revision: BB422001
Coding: 00B795
Coding: 02302A
1 Fault Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 186
Mileage: 203515 km
Time Indication: 0
Date: 2018.07.13
Time: 18:07:01
Term 15 On
Voltage: 11.50 V
ON
ON
ON
ON
OFF
Coding: 161F00
1 Fault Found:
13654544 - Databus
Fault Priority: 6
Reset counter: 175
Mileage: 203861 km
Date: 2018.10.08
Time: 15:07:20
Coding: 462006
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 203452 km
Time Indication: 0
Date: 2018.07.10
Time: 15:58:32
Coding: 00000008
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 203452 km
Time Indication: 0
Date: 2018.07.10
Time: 15:59:09
3 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 143
Mileage: 203452 km
Time Indication: 0
Date: 2018.07.10
Time: 15:59:20
011 - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 143
Mileage: 203452 km
Time Indication: 0
Date: 2018.07.10
Time: 15:59:20
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 143
Mileage: 203452 km
Time Indication: 0
Date: 2018.07.10
Time: 15:59:25
dziechu
- Auto:: Touran 1T 2.0 FSi 2006
- Imię:: Alek
Kody błędów.
Witam. Nie potrafię znaleźć kodów błędów. Wszędzie gdzie szukałem są albo czterocyfrowe, albo nie zaczynają się od 0. Wyskoczyły mi 3 błędy. 017441, 016396 i 017700. Czy może ktoś pomóc? Opisać, albo podpowiedzieć gdzie szukać listy?
- yox
- Podziękował: 240 razy
Re: KODY BLEDOW
???dziechu pisze:Witam. Nie potrafię znaleźć kodów błędów. Wszędzie gdzie szukałem są albo czterocyfrowe, albo nie zaczynają się od 0. Wyskoczyły mi 3 błędy. 017441, 016396 i 017700. Czy może ktoś pomóc? Opisać, albo podpowiedzieć gdzie szukać listy?
Mapet
- Auto:: Touran 1.9 TDI 105 KM AVQ
- Imię:: Rafał
Re: KODY BLEDOW
Ostatnio zakupiłem kable do diagnostyki na Viakenie i zainstalowałem program VAG-COM i zrobiłem odczyt błędów.
Oto treść:
VAG-COM Version: Release 311.2-N
Chassis Type: 9K - VW Caddy
Scan: 01,03,15,25,46,56
Address 01 -------------------------------------------------------
Controller: 03G 906 016 A
Component: R4 1,9L EDC G000SG 5185
Coding: 0000072
Shop #: WSC 00066
2 Znalezione:
17056 - Cylinder 2 Glow Plug Circuit (Q11) Electrical Fault
P0672 - 000 - -
P0401 - 000 - -
Readiness: N/A
End -------------------------------------------------------
AAaaa i w wyborze modelu samochodu nie ma opcji "Touran", ktoś wie jak rozwiązać problem czy coś robię źle ?
Proszę o interpretację błędów. Nadmienie, że pierwszy błąd jest związany z opisem na blacie "Emissions Workshop" więc domyślam się, że chodzi o EGR i jego czyszczenie albo zaślepienie - bo nie zamierzam wymieniać elementu na nowy.
Proszę o pomoc.
Oto treść:
Coding: 0000072
Shop #: WSC 00066
2 Znalezione:
P0672 - 000 - -
P0401 - 000 - -
Readiness: N/A
Proszę o pomoc.
- marcyb3
- Podziękował: 141 razy
Re: KODY BLEDOW
Pierwszy błąd to świeca żarowa (spalona do wymiany) drugi to EGR , sprawdź przewody pod filtrem powietrza w wiązce lubią się tam przecierać, jeśli jest ok to najprawdopodobniej EGR do wymiany lub usunięcia z kompa
Mapet
- Imię:: Rafał
Re: KODY BLEDOW
Dziwna sprawa z tymi świecami bo dopiero co je wymieniałem w tamtym roku wszystkie na nowe z BERU. Co do EGR-u to sprawdzę jak mówisz ale i tak czy tak zaślepię. Czy ta jedna spalona świeca może mieć wpływ na ciężkie odpalanie na ciepłym silniku czy to jest kwestia zmiany softa i dawki rozruchowej ?
Mam jeszcze jedno pytanie odnośnie VAG COM-a, dlaczego w polu wyboru marki samochodu z serii VW nie ma modelu Touran ? Co mam wtedy wybrać czy ma to jakieś znaczenie?
Bo kody błędów odczytywałem z marki Caddy.
- marlej
- Auto:: 1T3 TDI 1,6
- Imię:: Asott
Re: KODY BLEDOW
Rozwiązałeś problem ? mam to samo .. szukam informacjiturek pisze:Ktoś pomoże z błędem wspomagania,auto touran ale wszystko działa jak należy bynajmniej tak mi się wydajeAdres 03: ABS/hamulce Plik etykiet: 1K0-907-379-MK60-F.lbl
Oznaczenie elementu SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Komponent: ESP FRONT MK60 0102
Weryfikacja: 00T12001
Kodowanie: 0021190
VCID: 40853B9113DDB71861C
Znaleziono 1 błąd:
01309 - Sterownik układu wspomagania kierownicy (J500)
