Re: KODY BLEDOW
: ndz paź 22, 2017 09:45
Witam, potrzebna pomocy:
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 EH HW: 03G 906 018 EH
Component: R4 2.0l PPD1.2 G 4355
Revision: --H32--- Serial number: VWX7Z0FN3NE1NT
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 6FEA1FF77E99ED3A55-803A
1 Fault Found:
004705 - PD Unit Injector: Cylinder 1 (N240)
P1261 - 006 - Regulation Range Exceeded - Intermittent
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 3
Reset counter: 16
Mileage: 265283 km
Time Indication: 0
Date: 2000.00.00
Time: 22:50:53
RPM: 2016 /min
Torque: 208.0 Nm
Speed: 57.0 km/h
77.22 %
Text: 5.375 uF
Text: 13.75 mJ
Text: 12 mJ
T.B. Angle: 0.0°
Readiness: N/A
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000005947487
Coding: E38B8F2110040F0007120C0000000000000B7F0F5C0001
Shop #: WSC 01324 785 00200
VCID: 6CD008FB4F8F162270-8038
Subsystem 1 - Part No: 1T0 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 091106 020 0501
Coding: 00038805
Shop #: WSC 01324
Subsystem 2 - Part No: 1K0 955 559 AD Labels: 1K0-955-559-AF.CLB
Component: RLS 271006 014 1201
Coding: 06762533
Shop #: WSC 01324
3 Faults Found:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 25
Reset counter: 230
Mileage: 265357 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
ON
Voltage: 14.00 V
ON
OFF
OFF
OFF
OFF
02399 - Control Circuit for Terminal 30 for Interior Illumination
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 265062 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.75 V
OFF
OFF
OFF
OFF
OFF
00059 - Terminal 30 for Interior Lighting
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 265020 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.20 V
OFF
OFF
OFF
OFF
OFF
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 1K0 815 007 BC
Component: Standheizer 041 4303
Revision: 00041000 Serial number: 09011075000000
Coding: 0001012
Shop #: WSC 02750 175 04575
VCID: 66C47AD351632C7226-8032
1 Fault Found:
02245 - Connection; RF Remote Control
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 206
Mileage: 258415 km
Time Indication: 0
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 271009F2000569
Coding: ED817F0E400A02009002
Shop #: WSC 70250 259 136509
VCID: 69DE71EF407D030A0B-803C
2 Faults Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 195
Mileage: 264760 km
Time Indication: 0
Date: 2000.00.00
Time: 15:49:02
000 - -
Fault Status: 01100000
Fault Priority: 1
Reset counter: 255
Mileage: 264760 km
Time Indication: 0
Date: 2000.00.00
Time: 15:49:02
Part No SW: 1T0 959 702 E HW: 1T0 959 702 E
Component: Tuer-SG 005 0927
Coding: 0000180
VCID: 3A7CFEA3755B7892B2-806E
3 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00097 - Front Passengers Central Locking (Safe) Motor (V162)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0906
Coding: 0000144
Shop #: WSC 00000 000 00000
VCID: 377AE797464965FA4D-8062
2 Faults Found:
00098 - Rear Left Central Locking (Safe) Motor (V163)
00930 - Locking Module for Central Locking; Rear Left (F222)
Coding: 0000078
1 Fault Found:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 16
Mileage: 265283 km
Time Indication: 0
Date: 2000.00.00
Time: 22:50:53
RPM: 2016 /min
Torque: 208.0 Nm
Speed: 57.0 km/h
77.22 %
Text: 5.375 uF
Text: 13.75 mJ
Text: 12 mJ
T.B. Angle: 0.0°
Readiness: N/A
Coding: 00038805
Shop #: WSC 01324
Coding: 06762533
Shop #: WSC 01324
3 Faults Found:
Fault Priority: 4
Fault Frequency: 25
Reset counter: 230
Mileage: 265357 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
ON
Voltage: 14.00 V
ON
OFF
OFF
OFF
OFF
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 265062 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.75 V
OFF
OFF
OFF
OFF
OFF
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 265020 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.20 V
OFF
OFF
OFF
OFF
OFF
Coding: 0001012
1 Fault Found:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 206
Mileage: 258415 km
Time Indication: 0
2 Faults Found:
011 - Open Circuit
Fault Priority: 3
Reset counter: 195
Mileage: 264760 km
Time Indication: 0
Date: 2000.00.00
Time: 15:49:02
000 - -
Fault Priority: 1
Reset counter: 255
Mileage: 264760 km
Time Indication: 0
Date: 2000.00.00
Time: 15:49:02
Coding: 0000180
3 Faults Found:
Coding: 0000144
2 Faults Found:
