Krzycho
- Auto:: Golf GT BMN '08
- Imię:: Krzysiek
Tak, prawdo podobnie uwaliles modul...
Sent from my iPad using Tapatalk
- hagio
- Imię:: BARTOSZ
- Podziękował: 276 razy
Tylko co mogło być przyczyną? złe kodowanie? brak adaptacji G200 G201 i G85?Krzycho pisze:Tak, prawdo podobnie uwaliles modul...
za każdym razem AKU odłączałem przy podmianach.
kilka krzaków z autoscanu
Part No SW: 03G 906 016 BQ HW: 028 101 190 6
Component: R4 2,0L EDC G010SG 9971
Revision: 12345678 Serial number: VWZ7Z0E1856795
Coding: 0000072
Shop #: WSC 67237 141 88061
VCID: 73E1DBFF6B25
1 Fault Found:
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 000 - -
RPM: 0 /min
Torque: 208.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 1.0
Readiness: 0 0 0 0 0
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023238
Shop #: WSC 01324 785 00200
VCID: 3A7F36DB0CCF
1 Fault Found:
004 - No Signal/Communication
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H37 0803
Revision: 00H37000 Serial number: 00000001604702
Coding: 008B8F0A0004100000120C000000000000097B075C
Shop #: WSC 00000 000 00000
VCID: 397D29D709C9
Part No: 1T0 955 119 C
Coding: 00062421
Shop #: WSC 00000
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
Address 16: Steering wheel
Cannot be reached
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 29001053050882
Coding: 3D3F0300078002
VCID: 295DF997F969
3 Faults Found:
000 - -
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 13
Reset counter: 12
Mileage: 819 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:38
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 9
Reset counter: 12
Mileage: 847 km
Time Indication: 0
Date: 2000.00.00
Time: 14:04:01
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 49
Mileage: 847 km
Time Indication: 0
Date: 2000.00.00
Time: 17:35:04
- jarry
- Imię:: Rołbert
- Podziękował: 584 razy
moim zdaniem mogłeś ukruszyć/odłamać pin/piny od płytki w sterowniku kierownicy, weź go na stół i rozbierz plastikową obudowę, sprawdź czy wszystkie piny są ładnie przylutowane czy też któryś zostanie ci w obudowie i będzie trzeba go wyjąć i dolutować
- hagio
- Imię:: BARTOSZ
Aprpo pinów zauważyłem że moduł Midline i Hihgline różnią się ,czy jest taka możliwość że ten High ma mniej pinów od tego Mid?jarry pisze:moim zdaniem mogłeś ukruszyć/odłamać pin/piny od płytki w sterowniku kierownicy, weź go na stół i rozbierz plastikową obudowę, sprawdź czy wszystkie piny są ładnie przylutowane czy też któryś zostanie ci w obudowie i będzie trzeba go wyjąć i dolutować
Ps.po zdjęciu modułu coś gruchało w środku,jednak przy otwieraniu mi spadło i nie wiem co to było.Co do pinów liczba i rozmieszczenie są różne!! zaznaczyłem na fotkach .Zdaje się że wszystkie są OK.Przyglądnę się im dokładniej i potraktuje "kontaktem"
kolejna różnica w czarnej wtyczce moduł Midline ma wszystkie piny od 1-20 a Highline od 10-20
Krzycho
- Imię:: Krzysiek
U mnie wszystkie moduly ktore mam maja wszystkie piny w czarnej 20 pinowej wtyczce...
Wyslane z Tapatalk
Wyslane z Tapatalk
- JEDARO
- Auto:: Touran 1.9 TDI BLS
- Imię:: Darek
- Podziękował: 214 razy
ten po lewej stronie na pierwszym zdjęciu to który jest? bo wygląda jakby miał obudowę gniazda wtyki podsmażoną troszkę
- hagio
- Imię:: BARTOSZ
To akurat tak światło pada na obudowę,jedynie styki tam gdzie 9 sztuk jest są zaśniedziałe i widać na płytce jakąś plamę.Krzycho pisze:U mnie wszystkie moduly ktore mam maja wszystkie piny w czarnej 20 pinowej wtyczce...
sory, za określenie ale mi już " ŁAPY LETĄ " tylko jak wytłumaczyć działanie przez jakiś czas sterowania z kierownicy multifunkcyjnej? ja wymiękam.
-- 2 mar 2014, o 13:39 --
JEDARO pisze:ten po lewej stronie na pierwszym zdjęciu to który jest? bo wygląda jakby miał obudowę gniazda wtyki podsmażoną troszkę
- jarry
- Imię:: Rołbert
to co ci wypadło to mógł być pin, oderwał się do końca już po zamontowaniu, dlatego ileś tam podziałał, to prawdopodobny scenariusz, szkoda że nie masz tego czegoś co wyleciało, bylibyśmy mądrzejsi
- hagio
- Imię:: BARTOSZ
To coś było koloru czarnego,pin odpada bo przejrzałem dokładnie wszystkie pod lupą z dwóch stron, brak jakichkolwiek śladów po lucie od pinu.Również nie zauważyłem żadnego ubytku w elektronice,która też by była widoczna.wszystkie luty fabryczne ;-) szukam dalej...spot za chwilę a ja w powijakachjarry pisze:to co ci wypadło to mógł być pin, oderwał się do końca już po zamontowaniu, dlatego ileś tam podziałał, to prawdopodobny scenariusz, szkoda że nie masz tego czegoś co wyleciało, bylibyśmy mądrzejsi
a tu ładnie widać ile pinów i gdzie http://www.easyautoparts.eu/en/sparepar ... 49aq-relae
u mnie tak samo są
Krzycho
- Imię:: Krzysiek
Przegladnij jeszcze raz wszystkie elementy na plytce i to dokladnie
Wyslane z Tapatalk
Wyslane z Tapatalk
- jarry
- Imię:: Rołbert
no to ogólnie mnie się pomysły skończyły...
Ten sterownik AQ jest po zalaniu cieczą / woda. Widzisz sniedz przy pinach do tempomatu ? Bo widać jak na dłoni.
- hagio
- Imię:: BARTOSZ
Tak zauważyłem to od razu,na szczęście sprzedający jest na tyle uczciwy i wymieni na inny High.Co nie zmienia faktu że przez 20 km działał.Zastanawia mnie jeszcze jedno..co powinienem mieć w MENU na FIS"ie zdaje mi się że było mało ustawień..temperatura F lub C/zegar/KM lub MILE/RESET/JĘZYK/I JAK MA POKAZYWAĆ SPALANIE.Na moje coś okrojone to MENU było.spacewalker pisze:Ten sterownik AQ jest po zalaniu cieczą / woda. Widzisz sniedz przy pinach do tempomatu ? Bo widać jak na dłoni.
- Tomasz_W-wa
- Podziękował: 285 razy
A jaki masz moduł komfortu, bardzo możliwe że trzeba będzie wymienić na np. AR żeby było więcej na fis-e.
- Muti
- Auto:: MK7.5 R 2.O TSI DJHA
To o czym pisze hagio nie są zależne od komfortu
