Kod: Zaznacz cały
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Sporadic communication error 1000
15-Airbags -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
69-Trailer -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 FH
Component: Climatic PQ35 120 0606
Shop #: WSC 00000 000 00000
VCID: 6FED66BB7E9D053770-803A
3 Faults Found:
00457 - Central Electronics Control Module / BCM (J519)
013 - Check DTC Memory
01316 - ABS Control Module
004 - No Signal/Communication
01314 - Engine Control Module
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007781962
Coding: A1890F2110041500C70F0C006400000080097F075550012C000000000000
Shop #: WSC 01367 785 00200
VCID: 71E960C368A913C766-8024
Subsystem 1 - Part No: 1T0 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 050706 020 0501
Coding: 00038805
Shop #: WSC 01367
6 Faults Found:
01800 - Light Switch (E1)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 219
Mileage: 264287 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 219
Mileage: 264287 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 33
Reset counter: 219
Mileage: 264281 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
ON
Voltage: 13.85 V
ON
ON
OFF
OFF
OFF
Fault Status: 01111000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 219
Mileage: 264286 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
ON
Voltage: 13.00 V
ON
ON
OFF
OFF
OFF
Fault Priority: 2
Fault Frequency: 52
Reset counter: 219
Mileage: 264281 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
ON
Voltage: 13.85 V
ON
ON
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Fault Priority: 2
Fault Frequency: 31
Reset counter: 219
Mileage: 264281 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
ON
Voltage: 13.85 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags
Cannot be reached
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
Shop #: WSC 01324 785 00200
VCID: 74E769D717BB26EF8D-8020
No fault code found.
Part No: 1T0 920 862 F
Component: KOMBIINSTRUMENT VDD 4512
Coding: 0003101
Shop #: WSC 49158 133 187808
VCID: 366393DF414774FF73-8062
5 Faults Found:
Part No: 1K0 815 071 R
Component: Zuheizer 050 2302
Coding: 0000011
VCID: 3467A9D7573B66EF4D-8060
2 Faults Found:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 56
Reset counter: 203
Mileage: 264287 km
Time Indication: 0
02085 - Incorrect Control Module Installed
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 2
Reset counter: 203
Mileage: 264287 km
Time Indication: 0
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001067110E3D
Coding: 3D3F57C007008002
VCID: 2C57B1B78F0B3E2F15-8078
8 Faults Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 257419 km
Time Indication: 0
Date: 2000.00.00
Time: 20:26:20
Fault Priority: 1
Fault Frequency: 1
Reset counter: 3
Mileage: 257451 km
Time Indication: 0
Date: 2000.00.00
Time: 16:01:32
Fault Priority: 2
Fault Frequency: 7
Reset counter: 219
Mileage: 264287 km
Time Indication: 0
Date: 2000.00.00
Time: 01:32:08
Fault Priority: 2
Fault Frequency: 2
Reset counter: 3
Mileage: 264287 km
Time Indication: 0
Date: 2000.00.00
Time: 01:32:08
Fault Priority: 2
Fault Frequency: 2
Reset counter: 3
Mileage: 264287 km
Time Indication: 0
Date: 2000.00.00
Time: 01:32:08
Fault Priority: 2
Fault Frequency: 2
Reset counter: 3
Mileage: 264287 km
Time Indication: 0
Date: 2000.00.00
Time: 01:32:08
Fault Priority: 2
Fault Frequency: 2
Reset counter: 3
Mileage: 264287 km
Time Indication: 0
Date: 2000.00.00
Time: 01:32:08
01312 - Powertrain Data Bus
014 - Defective - Intermittent
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 6
Reset counter: 3
Mileage: 264287 km
Time Indication: 0
Date: 2000.00.00
Time: 01:35:48
Component: IMMO VDD 4512
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2301
Coding: 0000181
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00C802087F2D8405484F016010CC
VCID: 79F958E330D95B87DE-802C
3 Faults Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000181
VCID: 377D9EDB464D8DF768-8062
1 Fault Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0130
Revision: 00000001 Serial number: VWZ1Z3I4252675
Coding: 0100040004
Shop #: WSC 00020 790 00000
VCID: 65C104936C61CF670A-8030
5 Faults Found:
00625 - Vehicle Speed Signal
Fault Priority: 6
Fault Frequency: 2
Reset counter: 219
Mileage: 264287 km
Time Indication: 0
Date: 2000.00.00
Time: 01:32:14
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 53
Mileage: 257493 km
Time Indication: 0
Date: 2000.00.00
Time: 11:09:48
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 53
Mileage: 257493 km
Time Indication: 0
Date: 2000.00.00
Time: 11:09:48
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 53
Mileage: 257493 km
Time Indication: 0
Date: 2000.00.00
Time: 11:09:08
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 53
Mileage: 257493 km
Time Indication: 0
Date: 2000.00.00
Time: 11:09:08
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2428
Coding: 0000144
VCID: 326BAFCFAD2F68DF5F-8066
Address 69: Trailer Labels: 8P0-907-383.clb
Part No SW: 8P0 907 383 HW: 8P0 907 383
Component: ANHAENGERELEKTR H01 0010
Coding: 0000001
VCID: 76E353DF01C734FFB3-8022
1 Fault Found:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 219
Mileage: 262140 km
Time Indication: 0
Date: 2001.09.15
Time: 12:15:00
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
VCID: 3365AACB523561D754-8066
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 02 Einparkhilfe 0101
Shop #: WSC 65535 145 04465
VCID: 2D51BCB3B411372702-8078
3 Faults Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
006 - Short to Plus - Intermittent
00437 - Rear Right Inner Parking Aid Sensor (G335)
01299 - Diagnostic Interface for Data Bus (J533)
Address 77: Telephone Labels: 1K0-035-729-UNI.lbl
Part No: 1K0 035 729 E
Component: CIB PAH HW 203 SW 0308
Coding: 0000364
VCID: 2B55B2AB8A0539171C-807E
1 Fault Found:
01530 - Radio Mute Switch
