Błędy z Autoscanu
A co powiecie o moich błędach? :|
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 Q HW: 02E 927 770 AD
Component: GSG DSG 041 0803
Revision: 00004010 Serial number: 00000409150454
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 204BE4B38A53
1 Fault Found:
18201 - Transmission Output Speed Sensor 2 (G196): No Signal
P1793 - 000 - - - Intermittent
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023238
VCID: 3A7F36DB0CCF
1 Fault Found:
00668 - Supply Voltage Terminal 30
gabi10
Auto:: 2.0TDI AZV 170KM 2003
Imię:: Gabi
Bledy z autoscanu
Post autor: gabi10 »
Witam prosze o pomoc w odczytaniu bledow
Tuesday,25,June,2013,17:21:52:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 55 56 62 69 72
15-Airbags -- Status: Malfunction 0010
18-Aux. Heat -- Status: Cannot be reached 1100
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Part No SW: 03G 906 016 AL HW: 028 101 145 0
Component: R4 2,0L EDC G000SG 5249
Revision: 12345678 Serial number: VWZ7Z0C8337690
Coding: 0000072
VCID: 6DDBD76D748ADF1
6 Faults Found:
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 -
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001000
Temperature: 60.3°C
(no units): 144.0
18263 - Powertrain Data Bus
P1855 - 000 - Software Version Monitoring
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001000
Bin. Bits: 11100000
(no units): 0.0
16785 - EGR System
P0401 - 000 - Insufficient Flow - Intermittent
RPM: 1911 /min
Torque: 68.0 Nm
Speed: 45.0 km/h
Load: 23.1 %
Duty Cycle: 14.7 %
Bin. Bits: 00001000
Mass Air / Rev.: 355.0 mg/str
Mass Air / Rev.: 605.0 mg/str
16619 - Boost Pressure
P0235 - 000 - Regulation Range not Reached
RPM: 3024 /min
Torque: 186.0 Nm
Speed: 97.0 km/h
Load: 100.0 %
Voltage: 14.14 V
Bin. Bits: 00101000
Absolute Pres.: 2223.6 mbar
Absolute Pres.: 1774.8 mbar
16486 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low
RPM: 672 /min
Torque: 124.0 Nm
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00101000
Mass Air / Rev.: 850.0 mg/str
Mass Air / Rev.: 0.0 mg/str
16688 - Cylinder 4
P0304 - 000 - Misfire Detected
RPM: 819 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Inj. Quantity: 2.96 mg/str
Temperature: 29.7°C
(no units): 0.0
Readiness: 1 2 0 0 0
Part No: 1K0 907 379 D
Coding: 0056006
VCID: 336F0115522E491
1 Fault Found:
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 CC
Component: Climatic PQ35 060 0201
Shop #: WSC 00000 000 00000
VCID: 67D7A5455676F51
1 Fault Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Part No SW: 1K0 937 049 G HW: 1K0 937 049 G*
Component: PQ35 BordnetzSG 1.0 0501
Revision: 12345678 Serial number: 00000000184045
Coding: 038B8F000004100000120C000000000000
Coding: 00065493
Shop #: WSC 00000
7 Faults Found:
004 - No Signal/Communication
00153 - Windshield Wiper Motor; Driver Side (V216)
00154 - Windshield Wiper Motor; Passenger Side (V217)
01314 - Engine Control Module
02395 - Parking Light Right Front (M3)
02394 - Parking Light Left Front (M1)
Part No SW: 1T0 909 605 HW: 1T0 909 605
Component: 04 AIRBAG VW62 0102 2112
Coding: 0012340
VCID: F2E14411EDB4809
1 Fault Found:
00532 - Supply Voltage B+
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 009 0030
Coding: 0000042
VCID: 30650E19A338729
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Part No: 1T0 920 860 C
Component: KOMBIINSTRUMENT VDD 1714
Coding: 0007101
Shop #: WSC 00011 888 96745
VCID: 31630B1DA8327B1
No fault code found.
Address 18: Aux. Heat
Cannot be reached
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 2100103820078E
Coding: 7D3F5340078002
VCID: 2757E54596F6351
1 Fault Found:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 123
Mileage: 151026 km
Time Indication: 0
Date: 2000.00.00
Time: 10:04:08
Component: IMMO 1714
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0111
Coding: 0000116
VCID: F4ED420997A08E9
Part No: 1K1 909 143 L
Component: EPS_ZFLS Kl.0 0402
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 00E802087F2D8404084F0100
Part No: 1T0 959 702
Coding: 0000116
VCID: F5EB7F0D9CDA971
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0001
Coding: 0000001
2 Faults Found:
00070 - Starting Battery Voltage
00496 - Sensor for Vehicle Leveling; Front
010 - Open or Short to Plus
Part No: 1K0 035 186 D
Component: Radio BNO 0218
Coding: 0040400
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 05 0107
Coding: 0000048
VCID: 2F670D65BE066D1
Address 69: Trailer
Cannot be reached
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
Post autor: LYJO »
Panowie, mam prośbę. Zrobiłem koledze scana. Może ktoś "rozszyfrować" błędy?
To był moje drugie dopiero w życiu podpięcie kabelka więc proszę o wyrozumiałość :mrgreen:
Wednesday,26,June,2013,18:14:23:10074
VCDS Version: Beta 11.3.0
Data version: Unknown
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ4P011291 Mileage: 165800km/103023miles
25-Immobilizer -- Status: Sporadic communication error 1000
Address 01: Engine Labels: None
Part No SW: 036 906 032 AA HW: xxxxxxxxxxx
Component: BOSCH ME7.5.10 5442
Revision: 00000000 Serial number: VWZ7Z0C8569553
Coding: 0000071
Shop #: WSC 00028 028 00001
VCID: 4FA9770FA2F9
1 Fault Found:
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 004 - No Signal/Communication - Intermittent - MIL ON
Readiness: 0000 0000
Address 09: Cent. Elect. Labels: None
Part No SW: 1K0 937 049 L HW: 1K0 937 049 L*
Component: Bordnetz-SG 1.0 H29 0701
Revision: 00029000 Serial number: 00000000223671
Coding: 098D0F06000418003C1400001400000000
VCID: 387B2CD33777
Subsystem 1 - Part No: 1K1 955 119 A
Component: Wischer VW350 011 0301
Coding: 00065493
Shop #: WSC 00000
2 Faults Found:
01117 - Generator Terminal DF Load Signal
Address 15: Airbags Labels: None
Part No SW: 1K0 909 605 A HW: 1K0 909 605 A
Component: 06 AIRBAG VW8 022 0500
Revision: 04022000 Serial number: 0033FD04BRND
Coding: 0012342
VCID: 2A5F069BF9DB
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 17: Instruments Labels: None
Part No: 1K0 920 850 P
Component: KOMBIINSTRUMENT VDD 3550
Coding: 0001101
Shop #: WSC 00011 000 00000
VCID: 346318E32B1F
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Address 19: CAN Gateway Labels: None
Revision: 08 Serial number: 2100103921A057
Coding: 3D0F0340070000
VCID: 2759FFAFEAC9
1 Fault Found:
00474 - Control Module for Immobilizer
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 7
Reset counter: 72
Time Indication: 0
Date: 2000.00.00
Time: 20:07:57
Address 52: Door Elect, Pass. Labels: None
Part No: 1K0 959 702 E
Component: Tuersteuergeraet 09 0103
Coding: 0000052
VCID: 316D11F7D40D
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 56: Radio Labels: None
Part No: 1K0 035 186 G
Component: Radio GR0 0011
Revision: 0000903S Serial number: VWZ2Z2C1239350
Coding: 0020200
VCID: 2A5F069BF9DB
7 Faults Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
00821 - Antenna 2 for Radio (R93)
00870 - Bass Speaker Front Left (R21)
00871 - Bass Speaker Front Right (R23)
00878 - Connection to Speaker Front Left
00879 - Connection to Speaker Front Right
A teraz już błędy z mojego (wkur... mnie coraz bardziej) auta :> :
Monday,24,June,2013,19:21:27:10074
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 18 19 25 37 42 44 46 47 52 55 56 62
72 76 77
VIN: WVGZZZ1TZ5W078775 Mileage: 192630km/119694miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Malfunction 0010
Address 02: Auto Trans Labels: None
Part No SW: 02E 300 050 E HW: 02E 927 770 AD
Component: GSG DSG 041 1404
Revision: 00004010 Serial number: 00000410020068
Coding: 0000020
VCID: 1423B8634B5F
2 Faults Found:
18149 - Clutch Pressure Adaptation: Limit Reached
P1741 - 002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 0
Reset counter: 2
Mileage: 190174 km
Time Indication: 0
P1741 - 001 - Upper Limit Exceeded
Fault Status: 01100001
Fault Priority: 0
Reset counter: 2
Mileage: 190201 km
Time Indication: 0
Address 08: Auto HVAC Labels: None
Part No: 1K0 907 044 AC
Component: ClimatronicPQ35 066 0404
VCID: 68DBBC932757
1 Fault Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - -
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 040708F1001961
Coding: ED817F0E500E028002
Shop #: WSC 01324 020 00200
VCID: 356525E72065
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 226
Mileage: 189362 km
Time Indication: 0
Date: 2000.00.00
Time: 13:41:56
01304 - Radio
Fault Priority: 2
Fault Frequency: 13
Reset counter: 226
Mileage: 189362 km
Time Indication: 0
Date: 2000.00.00
Time: 13:41:56
Address 37: Navigation Labels: None
Part No SW: 1K0 035 191 D HW: 1K0 035 191 D
Component: J401 0206
Revision: 00017000 Serial number: VWZ1Z2F6519699
Coding: 0043400
VCID: 2341EBBF9EF1
6 Faults Found:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Mileage: 162578 km
Time Indication: 0
Date: 2000.00.00
Time: 18:07:38
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 52
Reset counter: 219
Mileage: 192118 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:02
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 52
Reset counter: 219
Mileage: 192118 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:02
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 186
Mileage: 192118 km
Time Indication: 0
Date: 2000.00.00
Time: 20:49:13
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 186
Mileage: 192118 km
Time Indication: 0
Date: 2000.00.00
Time: 20:49:13
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 2
Reset counter: 216
Mileage: 192118 km
Time Indication: 0
Date: 2000.00.00
Time: 19:44:04
Address 46: Central Conv. Labels: None
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 99E802487F2D8505480FC67011
VCID: 7BF1F3DF46C1
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Component: R 0206
Coding: 0043400
VCID: 2341EBBF9EF1
6 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Mileage: 162578 km
Time Indication: 0
Date: 2000.00.00
Time: 18:07:38
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 52
Reset counter: 219
Mileage: 192118 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:02
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 52
Reset counter: 219
Mileage: 192118 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:02
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 186
Mileage: 192118 km
Time Indication: 0
Date: 2000.00.00
Time: 20:49:13
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 186
Mileage: 192118 km
Time Indication: 0
Date: 2000.00.00
Time: 20:49:13
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 2
Reset counter: 216
Mileage: 192118 km
Time Indication: 0
Date: 2000.00.00
Time: 19:44:04
Address 72: Door, Rear Right Labels: None
Component: Tuersteuergeraet 06 0214
Coding: 0000048
VCID: 306B14F3DF07
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 77: Telephone Labels: None
Part No: 1K0 035 729 E
Component: CIB PAH HW 202 SW 0308
Coding: 0000364
VCID: 2B51039FF621
1 Fault Found:
01523 - Microphone for Telephone (R38)
Za pomoc oczywiście :piwo:
Miki76
Podziękował: 89 razy
Post autor: Miki76 »
wykasuj je i zeskanuj jeszcze raz i zobacz jakie powrócą chyba że to już zrobiłeś i te wyszły po ponownym skanowaniu ;)
Post autor: LYJO »
Wyszły po ponownym skanowaniu. Nic sie nie usuneło.
admin
Imię:: Maciek
Post autor: admin »
LYJO, nie pokasowałeś błędów. W navi zapisany jest jakiś z przebiegiem 162kkm, jakby się skasował to by wyskoczył ponownie z aktualnym przebiegiem.
Kliknij opcję clear all codes i wtedy wrzuć skana.
Większość powinna się skasować, problem może być z P1741, jakiś problem ze skrzynią/sprzęgłem.
Radio/navi musisz zakodować, tzn. albo masz z tyłu głośniki, a w radiu są 2 zakodowane albo na odwrót, radio zakodowane na 4 a nie masz z tyłu.
To jest RNS300?
VW Radio Navigation System (RNS300)
Coding
00?xxxx: Treble Speaker Monitoring
1 = Monitoring inactive
2 = Front Monitoring active / Rear Monitoring inactive
3 = Front Monitoring inactive / Rear Monitoring active
4 = Front and Rear Monitoring active
00x?xxx: Configuration I
+1 = Destination Input above 6 km/h or 4 mph possible
+2 = CAN-Telephone Control
00xx?xx: Speaker Channels
0 = Sound System (active Speakers)
2 = 2 passive Speakers Front
4 = 4 passive Speakers
00xxx?x: Sound System Correction
0 = No Sound System (No Correction)
1 = Sound System with Cloth Interior (with Open Circuit Recognition)
2 = Sound System with Leather Interior (with Open Circuit Recognition)
3 = Sound System with Cloth Interior (without Open Circuit Recognition)
00xxxx?: Configuration II
+2 = CD-Changer
Post autor: LYJO »
Klikałem clear all codes :) ale zrobię to dziś jeszcze raz z ciekawości.
Radio to RNS 300 i mam głośniki z tyłu. Nie działa ją mi tez guziki na kierownicy "przewijania" po włożeniu tego radia.
162kkm to te auto miało w 2011 roku jak je kupowałem ;)
Ja zauważyłem że clear all codes nie kasuje błędów skutecznie, dlatego wchodzę w poszczególne zespoły tam gdzie błąd wyskoczył np 09 central electric, fault codes 02 i tam kasuje błędy.
Miki76
Tomas pisze:Ja zauważyłem że clear all codes nie kasuje błędów skutecznie, dlatego wchodzę w poszczególne zespoły tam gdzie błąd wyskoczył np 09 central electric, fault codes 02 i tam kasuje błędy.
też o tym pisałem LYJO i myślę że tak zrobi
U mnie nigdy ten problem nie wystąpił zawsze całość kasowało, ale odruchowo przed usunięciem każdego sprawdzam i usuwam indywidualnie...
admin
Imię:: Maciek
Post autor: admin »
Dziwne, u mnie clear codes działa OK i kasuje wszystkie błędy dające się skasować.
Ale jak jest inaczej to pokasuj po kolei jak Tomas pisze.
Post autor: LYJO »
Jakie info powinno się pojawić po skasowaniu ręcznym błędów ?
wczorajsze błędy:
dzisiejsze błędy:
37-Navigation -- Status: Malfunction 0010
Oby dwa zestawienia z pierwszego skanowania.
Dziś po ręcznym kasowaniu i tak wszystkie zostały.
1 6 D
Auto:: Scirocco VAN
Post autor: 1 6 D »
W 46 masz padniętą syrenkę lub bezpiecznik/wiązkę do niego. W 77 mikrofon masz wypięty lub zwarcie w nim.
Miki76
pierwszy błąd tak jak ci wczoraj pisałem jest związany ze sprzęgłem (skrzynią)
01134 - Alarm Horn (H12) - wskazuje to na brak zasilania "trąbki" alarmu. Sprawdź, czy po wzbudzeniu alarmu słychać sygnał dźwiękowy.
a reszta wydaje mi się że to jest związane z radiem robiłeś coś na przykład wyjmowałeś je czy wymieniałeś??
Post autor: LYJO »
Miki76 pisze:Sprawdź, czy po wzbudzeniu alarmu słychać sygnał dźwiękowy.
"alarm" działa normalnie tzn, słychac go :)
Miki76 pisze:a reszta wydaje mi się że to jest związane z radiem robiłeś coś na przykład wyjmowałeś je czy wymieniałeś??
radio jest zmienione z chinczyka na rns300 i dlatego takie "syfy" sa
nawet FADER nie jest aktywny a mam wszystkie glosniki w aucie.
Najbardziej mnie ta skrzynia martwi :(
looknijcie prosze na błedy od kumpla:
Chassis Type: 1K0
Coding: 0000071
VCID: 4FA9770FA2F9
1 Fault Found:
VCID: 387B2CD33777
Coding: 00065493
Shop #: WSC 00000
2 Faults Found:
Coding: 0012342
VCID: 2A5F069BF9DB
1 Fault Found:
Coding: 0001101
VCID: 346318E32B1F
1 Fault Found:
VCID: 2759FFAFEAC9
1 Fault Found:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 72
Time Indication: 0
Date: 2000.00.00
Time: 20:07:57
Coding: 0000052
VCID: 316D11F7D40D
1 Fault Found:
Coding: 0020200
VCID: 2A5F069BF9DB
7 Faults Found:
