: czw lip 11, 2013 10:35
oto moje wyniki pierwszego podłączenia kabelka
proszę o interpretacje
Thursday,11,July,2013,09:37:25:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 18 19 25 3D 42 44 46 52 56 62 72 76
77
VIN: WVGZZZ1TZ5W037214
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Sporadic communication error 1000
3D-Special Function -- Status: OK 0000
44-Steering Assist -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Part No: 1K0 820 047 CE
Component: Climatic PQ35 050 0303
Shop #: WSC 00000 000 00000
VCID: 69D3A37D4062C31
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K1 937 049 HW: 1K1 937 049 *
Component: Bordnetz-SG 1.0 H30 0201
Revision: 00H30000 Serial number: 00000000890364
Coding: 018B8F0000041000001200000000000000
VCID: EDDB576DF48A5F1
Coding: 00065493
Shop #: WSC 00000
4 Faults Found:
00380 - Special Vehicle Control Module (J608)
00985 - Right Tail Light (M2)
01519 - Bulb for Back-Up Lights; Right (M17)
Address 15: Airbags
Cannot be reached
Component: Lenksäulenmodul 012 0030
Coding: 0010042
Shop #: WSC 01324 785 00200
VCID: 30650E19A338729
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
015 - Cannot Be Tested at this Time - MIL ON
Address 17: Instruments
Cannot be reached
Part No: 1K0 815 007 BG
Component: Standheizer 021 3803
Revision: 00021000 Serial number: 09011559000000
Coding: 0001112
Shop #: WSC 34614 142 86913
VCID: 6AD1DC714564C89
4 Faults Found:
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
01410 - Heater Over-Temp
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 148.0°C
Temperature: 32.0°C
02251 - Heater Unit Locked
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 26001047220566
Coding: 3F3F17C1078002
VCID: 2757E54596F6351
1 Fault Found:
00474 - Control Module for Immobilizer
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 175
Time Indication: 0
Date: 2000.00.00
Time: 13:38:35
Part No: 1T0 920 871 A
Component: IMMO VDD 0812
Shop #: WSC 01942 161 63991
VCID: 31630B1DA8327B1
Address 3D: Special Function Labels: None
Part No SW: 1T0 907 427 HW: 1T0 907 427
Component: MFG 010 X411
Revision: M0010000 Serial number: 00000000001652
Coding: 0101010101
Shop #: WSC 40380 123 17214
VCID: F2E14411EDB4809
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 02 Einparkhilfe 0101
VCID: 2D5B176DB40A1F1
2 Faults Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
009 - Open or Short to Ground
006 - Short to Plus
Address 77: Telephone
Cannot be reached
a to po skasowaniu błędów
Thursday,11,July,2013,09:48:01:32264
Chassis Type: 1K0
77
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 00065493
Shop #: WSC 00000
Address 15: Airbags
Cannot be reached
Coding: 0010042
Cannot be reached
Coding: 0001112
4 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 32.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Coding: 0101010101
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Chassis Type: 1K0
77
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 00065493
Shop #: WSC 00000
4 Faults Found:
Address 15: Airbags
Cannot be reached
Coding: 0010042
1 Fault Found:
Cannot be reached
Coding: 0001112
4 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 32.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 175
Time Indication: 0
Date: 2000.00.00
Time: 13:38:35
Coding: 0101010101
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
2 Faults Found:
006 - Short to Plus
Cannot be reached
Chassis Type: 1K0
77
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 00065493
Shop #: WSC 00000
Address 15: Airbags
Cannot be reached
Coding: 0010042
Cannot be reached
Coding: 0001112
4 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 32.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Coding: 0101010101
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
