Problemów z montażem PLA 2 ciąg dalszy.
Przycisk park assista po naciśnięciu w ogóle nie reaguje choć jest nowy, chyba że jest źle podpięty. Jedyne co to działa w nim podświetlanie.
Scan dosłownie z przed chwil.
Tuesday,20,December,2016,21:43:05:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 15.7.1.0
Data version: 20150904
http://www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: WVWZZZ1KZ9W077311 License Plate:
Mileage: 114730km-71289mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 56 62 72
VIN: WVWZZZ1KZ9W077311 Mileage: 114730km-71289miles
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 QJ HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 1984
Revision: --H08--- Serial number: VWX7Z0H63NS8GH
Coding: 0000071
Shop #: WSC 01279 785 00200
VCID: 77FA73F306DEE3866C-8022
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 113B200D09290001880E04E5901A0041350C50
Shop #: WSC 12345 123 12345
VCID: 7BF26FC3FAF6C7E608-802E
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6DD6519B7482595686-8038
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008669003
Coding: 758B8FA700041500471400001400000080097F072300000C000000000000
VCID: 336287E35226CFA690-8066
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 180708 021 0501
Coding: 00038805
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 250708 054 0402
Coding: 00209069
Shop #: WSC 12345
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261206501537
Coding: 148001
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000_SE36.rod
VCID: 4480D43FCF88781E39-8010
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC1TFDBV
Coding: 0013111
Shop #: WSC 01357 011 00200
VCID: 3D76A1DB646209D676-8068
Subsystem 1 - Serial number: 6332MSME3F2358029
Subsystem 2 - Serial number: 6342MSME3F23403CE
Subsystem 3 - Serial number: 6352QSME7741417BJ
Subsystem 4 - Serial number: 6362QSME7F27413FW
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000132
VCID: 7AFC6AC735CCFEEE13-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
5 Faults Found:
000 - -
00576 - Terminal 15
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Part No SW: 5M0 920 873 D HW: 5M0 920 873 D
Component: KOMBI H04 0809
Coding: 170F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 336287E39A26CFA690-8066
1 Fault Found:
12671232 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 114739 km
Date: 2016.12.20
Time: 00:00:54
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 110708F2000933
Coding: E9B07F060002020002
VCID: 3566B9FB5C52D196BE-8060
Component: IMMO H04 0809
Coding: 000000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADC5A878D6C4E6EE3-803E
Part No SW: 1K0 959 701 AL HW: 1K0 959 701 AL
Component: Tuer-SG 006 1203
Coding: 0000244
VCID: 78F870CF0BC0ECFE65-802C
1 Fault Found:
00109 - Left Mirror Turn Signal Lamp (L131)
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Component: KSG PQ35 G2 020 0204
Coding: 809008005103487F2D04840560088F03E0FC00
VCID: 030217234206BF2640-8056
Address 4C: Tire Pressure II
Cannot be reached
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Component: Tuer-SG 006 1219
Coding: 0000500
VCID: 3A7CAAC7754C3EEE53-806E
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 041 0166
Revision: 00000001 Serial number: VWZ1Z3K6416593
Coding: 0900040102
VCID: 65C629BB6C726116CE-8030
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 211
Mileage: 113866 km
Time Indication: 0
Date: 2016.12.02
Time: 10:45:04
01327 - Control Module for Parking Aid (J446)
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 114739 km
Time Indication: 0
Date: 2016.12.20
Time: 00:00:56
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1305
Coding: 0000208
Shop #: WSC 12345 123 1012569
VCID: 3878B0CF4B402CFEA5-806C
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000208
VCID: 397EB5CB704A35F65A-806C
End-------------------------(Elapsed Time: 0
