Jakoś nie zauważyłem.aprinsr pisze:Dzięki
Błędy z Autoscanu
rossi2106
- Auto:: 1,9 TDI AVQ
- Podziękował: 13 razy
Kolega dzis podlaczyl mi VAG-a i wyszlo mi cos takiego.
ktos bylby uprzejmy mi zinterpretowac te bledy w odniesieniu do tourana.bo oczywiscie pogooglalem nieco ale w necie sa raczej uniwersalne wyjasnienia.glownie chodzi mi i blad ABS-u,EGR-u i swiec zarowych.czy mozna jakos wyodrebnic ktore bledy sa "stare"?
Monday,20,May,2013,09:35:52:59305
VCDS Version: Beta 12.10.3
Data version: 20130228
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ4W037274
Part No SW: 03G 906 016 A HW: 028 101 073 1
Component: R4 1,9L EDC 0000SG 5185
Revision: 12345678 Serial number: VWZ7Z0C7960624
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 21492379F82E4364765B71
8 Faults Found:
16785 - Can't Decode, CODE File Not Loaded!
P0401 -- 000 --
RPM: 1764 /min
Torque: 74.0 Nm
Speed: 77.0 km/h
Load: 26.3 %
Duty Cycle: 14.7 %
Bin. Bits: 00000000
Mass Air / Rev.: 260.0 mg/str
Mass Air / Rev.: 410.0 mg/str
17979 - Can't Decode, CODE File Not Loaded!
P1571 -- 000 -- - Intermittent
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00000000
Bin. Bits: 11100000
(no units): 1.0
17070 - Can't Decode, CODE File Not Loaded!
P0686 -- 000 --
RPM: 0 /min
Torque: 114.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00000000
Temperature: 6.3°C
Bin. Bits: 00110000
17062 - Can't Decode, CODE File Not Loaded!
P0678 -- 000 --
RPM: 882 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 00000000
Temperature: 8.1°C
Bin. Bits: 10110000
17069 - Can't Decode, CODE File Not Loaded!
P0685 -- 000 --
RPM: 966 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.59 V
Bin. Bits: 00000000
Temperature: -2.7°C
Bin. Bits: 10110000
18364 - Can't Decode, CODE File Not Loaded!
P1956 -- 000 -- - Intermittent
RPM: 1680 /min
Torque: 0.0 Nm
Speed: 63.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00000000
Temperature: 33.3°C
Duty Cycle: 15.5 %
18063 - Can't Decode, CODE File Not Loaded!
P1655 -- 000 --
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000000
Temperature: 28.8°C
(no units): 144.0
18050 - Can't Decode, CODE File Not Loaded!
P1642 -- 000 --
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Torque: 110.0 Nm
Readiness: 0 0 0 0 0
Part No: 1K0 907 379 D
Coding: 0053958
VCID: 3365D93152D2C1F494172B
1 Fault Found:
01435 - Can't Decode, CODE File Not Loaded!
012 -- Can't Decode, CODE File Not Loaded!
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 CB
Component: Climatic PQ35 050 0101
Shop #: WSC 00000 000 00000
VCID: 66C370655180645CC3E97A
No fault code found.
Chassis Type: 1K0
Coding: 0000072
8 Faults Found:
P0401 -- 000 --
RPM: 1764 /min
Torque: 74.0 Nm
Speed: 77.0 km/h
Load: 26.3 %
Duty Cycle: 14.7 %
Bin. Bits: 00000000
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00000000
Bin. Bits: 11100000
(no units): 1.0
P0686 -- 000 --
RPM: 0 /min
Torque: 114.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00000000
Temperature: 6.3°C
Bin. Bits: 00110000
P0678 -- 000 --
RPM: 882 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 00000000
Temperature: 8.1°C
Bin. Bits: 10110000
P0685 -- 000 --
RPM: 966 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.59 V
Bin. Bits: 00000000
Temperature: -2.7°C
Bin. Bits: 10110000
RPM: 1680 /min
Torque: 0.0 Nm
Speed: 63.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00000000
Temperature: 33.3°C
Duty Cycle: 15.5 %
P1655 -- 000 --
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000000
Temperature: 28.8°C
(no units): 144.0
P1642 -- 000 --
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Torque: 110.0 Nm
Coding: 0053958
1 Fault Found:
rossi2106
kolega jest jeszcze bardziej nieogarniety w tych sprawach niz ja.
po kodach bledow posprawdzalem w googlu ale nic wiecej nie wiem jak to sie ma do tourana.a drugi raz chyba sie juz nie uda sprawdzic bo przy probie skasowania inspekcji olejowej kabelek nie komunikowal sie juz z autem wiec pewnie sie zepsul
rossi2106
udalo sie dzis odczytac wiecej
Address 01: Engine Labels: 03G-906-016-BKC.LBL
Control Module Part Number: 03G 906 016 A HW: 028 101 073 1
Component and/or Version: R4 1,9L EDC 0000SG 5185
Software Coding: 0000072
8 Faults Found:
16785 - EGR System
P0401 -- 000 -- Insufficient Flow
RPM: 1764 /min
Torque: 74.0 Nm
Speed: 77.0 km/h
Load: 26.3 %
Duty Cycle: 14.7 %
Bin. Bits: 00000000
17979 - Left Engine Mount Solenoid Valve (N144)
P1571 -- 000 -- Short to Plus - Intermittent
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00000000
Bin. Bits: 11100000
(no units): 1.0
17070 - ECM Power Relay Control Circuit (J271)
P0686 -- 000 -- Short to GND
RPM: 0 /min
Torque: 114.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00000000
Temperature: 6.3°C
Bin. Bits: 00110000
17062 - Cylinder 8 Glow Plug Circuit (Q17)
P0678 -- 000 -- Electrical Fault
RPM: 882 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 00000000
Temperature: 8.1°C
Bin. Bits: 10110000
17069 - ECM Power Relay Control Circuit (J271)
P0685 -- 000 -- Open Circuit
RPM: 966 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.59 V
Bin. Bits: 00000000
Temperature: -2.7°C
Bin. Bits: 10110000
18364 - Exhaust Gas Temp Sensor 2 Bank 1 (G448)
P1956 -- 000 -- Electrical Malfunction - Intermittent
RPM: 1680 /min
Torque: 0.0 Nm
Speed: 63.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00000000
Temperature: 33.3°C
Duty Cycle: 15.5 %
18063 - Please check DTC Memory of Auto. Distance Controller
P1655 -- 000 --
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000000
Temperature: 28.8°C
(no units): 144.0
18050 - Please check DTC Memory of Airbag Controller
P1642 -- 000 --
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Torque: 110.0 Nm
ktos moglby zerknac
z gory dzieki.
8 Faults Found:
16785 - EGR System
RPM: 1764 /min
Torque: 74.0 Nm
Speed: 77.0 km/h
Load: 26.3 %
Duty Cycle: 14.7 %
Bin. Bits: 00000000
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00000000
Bin. Bits: 11100000
(no units): 1.0
RPM: 0 /min
Torque: 114.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00000000
Temperature: 6.3°C
Bin. Bits: 00110000
RPM: 882 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 00000000
Temperature: 8.1°C
Bin. Bits: 10110000
RPM: 966 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.59 V
Bin. Bits: 00000000
Temperature: -2.7°C
Bin. Bits: 10110000
RPM: 1680 /min
Torque: 0.0 Nm
Speed: 63.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00000000
Temperature: 33.3°C
Duty Cycle: 15.5 %
P1655 -- 000 --
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000000
Temperature: 28.8°C
(no units): 144.0
P1642 -- 000 --
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Torque: 110.0 Nm
ktos moglby zerknac
z gory dzieki.
- Cesarz
- Podziękował: 629 razy
rossi2106, to sa błędy już po wykasowaniu?
MadMax czy jaka cholera
[ Dodano: Sob Wrz 07, 2013 13:51 ]
rossi2106, a swoja droga w której części UK pomieszkujesz? Jest tu ma forum pare osób z UK może się okazac ze z niedaleka i ogarnieci w temacie...
8 cylindrówka?rossi2106 pisze:17062 - Cylinder 8 Glow Plug Circuit (Q17)
rossi2106
nic nie bylo kasowane,podejrzewan ze niektore bledy sa stare i moze juz nieaktualne.marynarz75 pisze:rossi2106, to sa błędy już po wykasowaniu?
8 cylindrówka?rossi2106 pisze:17062 - Cylinder 8 Glow Plug Circuit (Q17)MadMax czy jaka cholera
co do 8 cylindrow-nie wiem skad sie wziely
bledy byly odczytane zaraz po przetestowaniu kabla.
mam przy okazji pytanie-czy ten kabel bedzie chodzil normalnie na moim laptopie[jest aktywowany na lapku kolegi].bo jemu jest w sumie niepotrzebny i moglbym sobie troche sam wiedzy przyswoic.
mieszkam na poludniu,pomiedzy southampton a londynem.
- Cesarz
rossi2106, wiec pierwsze primo zróbcie skan i wykasujcie stare błędy (clear all DTC codes), to rozjasni trochę obraz...
po drugie primo kolega g_b mieszka w Bournemouth, nie wiem jak to daleko od Ciebie (z Southampton jakies 33 mile) ale można powiedzieć ze ogarnia to i owo... (g_b nie dziękuj
po trzecie primo, tak kabel będzie chodził na każdym lapku z odpowiednim oprogramowaniem...
- czesio19892404
- Auto:: szukam
- Imię:: Grzegorz
koledzy da radę może ktoś pomóc w rozszyfrowaniu błądów???
Part No SW: 03G 906 016 EH HW: 028 101 178 6
Component: R4 2,0L EDC G010SG 5687
Revision: 12345678 Serial number: VWZ7Z0D9147599
Coding: 0000072
VCID: 6DD5CD870F51
2 Faults Found:
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 000 - -
RPM: 0 /min
Torque: 58.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00101100
Temperature: 43.2°C
Duty Cycle: 9.6 %
18072 - Control Circuit for PD Injectors: Electrical Malfunction
P1664 - 000 - -
RPM: 252 /min
Torque: 100.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 00101100
Temperature: 40.5°C
Bin. Bits: 01010000
Readiness: 0 0 1 1 1
Part No: 1K0 907 044 L
Component: ClimatronicPQ35 063 0201
VCID: 306B14F3D8E3
1 Fault Found:
00229 - Refrigerant Pressure
001 - Upper Limit Exceeded - Intermittent
Part No: 1K0 815 071 N
Component: Zuheizer 030 1312
Coding: 0000011
Shop #: WSC 38661 123 60308
VCID: 306B14F3D8E3
5 Faults Found:
01412 - Glow-Plug with Flame Monitoring (Q8)
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 7
Reset counter: 22
Mileage: 204871 km
Time Indication: 0
Date: 2000.00.00
Time: 19:44:38
Start
Temperature: 89.0°C
Temperature: 84.0°C
00003 - Control Module
014 - Defective - Intermittent
Fault Priority: 0
Fault Frequency: 7
Reset counter: 22
Mileage: 204871 km
Time Indication: 0
Date: 2000.00.00
Time: 19:44:38
01406 - No Flame
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 23
Mileage: 204884 km
Time Indication: 0
Date: 2000.00.00
Time: 01:23:19
Start
Temperature: 77.0°C
Temperature: 73.0°C
02251 - Heater Unit Locked
Fault Priority: 0
Fault Frequency: 1
Reset counter: 23
Mileage: 204884 km
Time Indication: 0
Date: 2000.00.00
Time: 01:23:19
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 62
Reset counter: 249
Mileage: 214707 km
Time Indication: 0
Date: 2000.00.00
Time: 23:26:31
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0127
Coding: 0000116
VCID: F4E358E3EC7B
1 Fault Found:
00120 - Outside Warning Light/Door exit Light Driver Side
Part No: 1T0 959 702
Coding: 0000116
VCID: F5E565E7E701
1 Fault Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
Coding: 0000072
VCID: 6DD5CD870F51
2 Faults Found:
P1672 - 000 - -
RPM: 0 /min
Torque: 58.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00101100
Temperature: 43.2°C
Duty Cycle: 9.6 %
P1664 - 000 - -
RPM: 252 /min
Torque: 100.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 00101100
Temperature: 40.5°C
Bin. Bits: 01010000
VCID: 306B14F3D8E3
1 Fault Found:
Coding: 0000011
VCID: 306B14F3D8E3
5 Faults Found:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 22
Mileage: 204871 km
Time Indication: 0
Date: 2000.00.00
Time: 19:44:38
Start
Temperature: 89.0°C
Temperature: 84.0°C
Fault Priority: 0
Fault Frequency: 7
Reset counter: 22
Mileage: 204871 km
Time Indication: 0
Date: 2000.00.00
Time: 19:44:38
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 23
Mileage: 204884 km
Time Indication: 0
Date: 2000.00.00
Time: 01:23:19
Start
Temperature: 77.0°C
Temperature: 73.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 23
Mileage: 204884 km
Time Indication: 0
Date: 2000.00.00
Time: 01:23:19
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 62
Reset counter: 249
Mileage: 214707 km
Time Indication: 0
Date: 2000.00.00
Time: 23:26:31
Coding: 0000116
VCID: F4E358E3EC7B
1 Fault Found:
Coding: 0000116
VCID: F5E565E7E701
1 Fault Found:
- adamki
- Auto:: TOURAN 1.9 AVQ 74 KW 2003
- Imię:: ADAM
- Podziękował: 64 razy
- Otrzymał podziękowań: 41 razy
u mnie sie pojawiło coś takiego
9474161 - Silnik nastawczy klapy rozmra?ania
B1090 71 [008] - Nastawnik zablokowany
Sporadyczny - Potwierdzony - Testowany od skasowania kodów b3edów
Ramka zamro?ona:
Stan b3edu: 00000001
Priorytet b3edu: 2
Czestooa b3edu: 254
Wew.licznik b3edów: 124
Przebieg: 190971 km
Data: 2017.14.29
Czas: 14:36:23
błąd niestety wraca co jakiś czas
co to może być ???
Ramka zamro?ona:
Priorytet b3edu: 2
Czestooa b3edu: 254
Przebieg: 190971 km
Data: 2017.14.29
Czas: 14:36:23
co to może być ???
- zduno
Witam, może ktoś już przerabiał takie kody błedów ,sam nie wiem od czego zacząć.
18051 Odczytać kody błędów sterownika regulacji akumulatora / obciążenia
P1643-000
18048-błąd pamięci eeprom
Ten pierwszy skasowany a drugiego nie mogę usunąć , dodam ze miga kontrolka świec żarowych i świeci emmision workschop .Szukałem na innych forach ale nic konkretnego nie znalazłem orprócz problemów na stykach masy. Czy to moze byc główna przyczyna?czy poprostu sterownik silnika umarł?
P1643-000
Zduno Touran 1T1 << http://touranklub.pl/forum/viewtopic.php?t=790 >>
- rasta
- Auto:: Toyota Avensis T27
- Podziękował: 48 razy
- Otrzymał podziękowań: 110 razy
i ja bym był wdzięczny :
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Coding: 0000011
VCID: 2A511C7185E4089
5 Faults Found:
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 23
Reset counter: 254
Mileage: 493841 km
Time Indication: 0
Date: 2000.00.00
Time: 28:29:31
Malfunction
Temperature: 205.0°C
Temperature: 36.0°C
Fault Priority: 0
Reset counter: 24
Mileage: 418937 km
Time Indication: 0
Date: 2000.00.00
Time: 28:43:06
OFF
Temperature: 52.0°C
Temperature: 54.0°C
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 23
Reset counter: 183
Mileage: 492647 km
Time Indication: 0
Date: 2000.00.00
Time: 30:42:14
01320 - Control Module for Climatronic (J255)
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 41
Mileage: 475036 km
Time Indication: 0
Date: 2000.00.00
Time: 18:35:39
010 - Open or Short to Plus
Fault Priority: 0
Reset counter: 24
Mileage: 418937 km
Time Indication: 0
Date: 2000.00.00
Time: 28:43:06
OFF
Temperature: 52.0°C
Temperature: 54.0°C
Coding: 0000011
5 Faults Found:
Fault Priority: 0
Fault Frequency: 23
Reset counter: 254
Mileage: 493841 km
Time Indication: 0
Date: 2000.00.00
Time: 28:29:31
Malfunction
Temperature: 36.0°C
Fault Priority: 0
Reset counter: 24
Mileage: 418937 km
Time Indication: 0
Date: 2000.00.00
Time: 28:43:06
OFF
Temperature: 52.0°C
Temperature: 54.0°C
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 23
Reset counter: 183
Mileage: 492647 km
Time Indication: 0
Date: 2000.00.00
Time: 30:42:14
Fault Priority: 0
Fault Frequency: 2
Reset counter: 41
Mileage: 475036 km
Time Indication: 0
Date: 2000.00.00
Time: 18:35:39
Fault Priority: 0
Reset counter: 24
Mileage: 418937 km
Time Indication: 0
Date: 2000.00.00
Time: 28:43:06
OFF
Temperature: 52.0°C
Temperature: 54.0°C
