Saturday,13,July,2019,12:46:30:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
www.Ross-Tech.com
Workshop Code: 031 73430 000063
VIN: WVWZZZ1KZ8W255215 License Plate:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 69 72
VIN: WVWZZZ1KZ8W255215 Mileage: 247710km-153919miles
15-Airbags -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 PM HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 1136
Revision: --H07--- Serial number: VWXBZ0H0756164
Coding: 0000072
Shop #: WSC 01392 785 00200
VCID: 79F8D57830D9538ED6-802C
2 Faults Found:
005716 - Please check DTC Memory of Instrument Cluster
P1654 - 000 -
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 247673 km
Time Indication: 0
Date: 2000.00.00
Time: 16:19:23
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Temperature: 49.5°C
Temperature: 80.1°C
Temperature: 17.1°C
005696 - Internal Control Module
P1640 - 000 - EEPROM Error - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 247673 km
Time Indication: 0
Date: 2000.00.00
Time: 15:39:19
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Bin. Bits: 00000000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 12345 000 00000
VCID: 76E2DE44C1C73CF6BB-8022
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Time Indication: 0
Count: 3
Count: 0
Count: 20992
Count: 195
Count: 43520
Count: 65280
Count: 0
Count: 0
Part No SW: 1K0 907 044 DD HW: 1K0 907 044 DD
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6CD6FC2C4F8BF6265D-8038
No fault code found.
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005443182
Coding: 01890F2700041500471400001400000000097E056400010C000000000000
Shop #: WSC 73430 031 00063
VCID: 71E8ED5868A91BCE6E-8024
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 310108 021 0501
Coding: 00038805
Shop #: WSC 73430
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1TEMPB
Coding: 0013111
Shop #: WSC 01373 785 00200
VCID: 3D7001686471AFAEBA-8068
Subsystem 1 - Serial number: 6332MSME2F70302DD
Subsystem 2 - Serial number: 6342MSME3672530CA
Subsystem 3 - Serial number: 6352QSME51504F0DK
Subsystem 4 - Serial number: 6362QSME503417176
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 752 0100
Coding: 0000042
VCID: 7F0C3B602EFD7DBEE8-802A
Part No SW: 1K0 920 864 B HW: 1K0 920 864 B
Component: KOMBIINSTRUMENT VN4 4005
Revision: V0010000 Serial number: VWXBZ0H0756164
Coding: 0003103
VCID: 2B543F308A05311E14-807E
2 Faults Found:
00003 - Control Module
014 - Defective
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 87
Mileage: 211854 km
Time Indication: 0
Date: 2000.00.00
Time: 15:33:28
00560 - Exhaust Gas Recirculation System
007 - Short to Ground
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 0
Reset counter: 162
Mileage: 247655 km
Time Indication: 0
Date: 2000.00.00
Time: 00:19:58
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BE HW: 7N0 907 530 AL
Component: J533 Gateway H58 1674
Revision: H58 Serial number: 110915F1002728
Coding: 350002
VCID: 74E6E44CD7BB2EE685-8020
Component: IMMO VN4 4005
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 F HW: 3C8 035 279 F
Component: RNS315-EU H77 0410
Serial number: VWZAZ2P0049392
Coding: 000004110400110400010001
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 2E5236247117443633-807A
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V5 0055
2 Faults Found:
1048595 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 162
Mileage: 247711 km
Date: 2000.00.00
Time: 12:35:59
1048633 - Antenna 1 for Radio
B1119 11 [009] - Short to Ground
Fault Priority: 5
Fault Frequency: 1
Reset counter: 162
Mileage: 247711 km
Date: 2000.00.00
Time: 12:35:56
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1203
Coding: 0000180
VCID: 387E107C4B538A8669-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 356019485C4177EE72-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Component: KSG PQ35 G2 020 0204
Coding: 80980A005103087F2D04840560084F03E0FCA0
VCID: 0304B7904215195E8C-8056
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000180
VCID: 397815787059938E96-806C
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1305
Coding: 0000144
Shop #: WSC 01392 785 1012552
Address 69: Trailer
Cannot be reached
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
End-------------------------(Elapsed Time: 01:50)--------------------------
