Bledy z VCDS - moze kos zerknac
: ndz wrz 28, 2014 19:51
autor: Jsxx
Przeskanowalem nowonabytego tourana niedawno i wyskoczylo pare bledow tylko nie za bardzo je rozumiem...
Bylbym wdzieczny jakby ktos zerknal
Thursday,25,September,2014,19:48:10:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVGZZZ1TZAW057944 License Plate: TOURAN
Mileage: 76050km-47255mi Repair Order: kody1
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 52 56
VIN: WVGZZZ1TZAW057944 Mileage: 76050km/47255miles
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 1010
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0011
56-Radio -- Status: Malfunction 1010
Part No SW: 03G 906 021 MM HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 0511
Revision: --H11--- Serial number: VWX7Z0I93NT0I8
Coding: 0000072
Shop #: WSC 01324 020 00200
VCID: 76E300530132E6AEBEF-8023
1 Fault Found:
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 255
Mileage: 64702 km
Time Indication: 0
Date: 2000.00.00
Time: 07:47:50
RPM: 1260 /min
Speed: 0.0 km/h
Load: 11.0 %
Voltage: 14.14 V
Bin. Bits: 00101100
Temperature: 4.5°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021190
VCID: 73E539471240F386991-8026
No fault code found.
Part No SW: 1K0 820 047 JN HW: 1K0 820 047 JN
Component: Climatic PQ35 143 1515
Revision: 00143034 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 79F90B6F302C89D6D3D-802C
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000003524636
Coding: 00890F2100040F1447120C000000000000087B075C000120000000000000
VCID: 326BFC43ADDABA8E527-8067
Subsystem 1 - Part No: 1T2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 091109 021 0512
Coding: 00038805
Shop #: WSC 01324
5 Faults Found:
01501 - Bulb for Blinkers; Rear Left (M6)
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 76051 km
Time Indication: 0
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
00987 - Lamp for Brake Light; Left (M9)
Fault Priority: 1
Fault Frequency: 1
Reset counter: 194
Mileage: 76051 km
Time Indication: 0
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
00984 - Left Tail Light (M4)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 76051 km
Time Indication: 0
ON
Voltage: 12.05 V
ON
ON
OFF
OFF
OFF
01502 - Bulb for Rear Fog; Left (L46)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 76051 km
Time Indication: 0
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
01518 - Bulb for Back-Up Lights; Left (M16)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 76051 km
Time Indication: 0
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
Part No SW: 1T0 909 605 D HW: 1T0 909 605 D
Component: 1D AIRBAG VW8 021 0100
Revision: 02021000 Serial number: 003B9D0ERD37
Coding: 0012612
VCID: 3663C05341B2A6AE7EF-8063
Subsystem 1 - Serial number: 6332QSME5A41390CJ
Subsystem 2 - Serial number: 6342QSME1D413E2ES
Subsystem 3 - Serial number: 6352QSME493E5710K
Subsystem 4 - Serial number: 6362QSME513E0F2EW
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 853 0111
Coding: 0000034
VCID: 8305E987C2E04306091-80D6
Part No SW: 1T0 920 964 A HW: 1T0 920 964 A
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0I93NT0I8
Coding: 0001401
Shop #: WSC 00000 067 57207
VCID: 3467FA5B57CEB4BE40B-8061
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Coding: 0000011
Shop #: WSC 01324 785 00200
4 Faults Found:
00664 - Fuel gauge
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 45
Reset counter: 249
Mileage: 21335 km
Time Indication: 0
01412 - Glow-Plug with Flame Monitoring (Q8)
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 34
Mileage: 22844 km
Time Indication: 0
Start
Temperature: 70.0°C
Temperature: 69.0°C
Voltage: 14.31 V
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 31
Mileage: 23178 km
Time Indication: 0
02251 - Heater Unit Locked
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 23409 km
Time Indication: 0
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 061109F2000839
Coding: E9801F06000A02008003
VCID: 69D95B2F408C395623D-803C
3 Faults Found:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 188
Mileage: 75979 km
Time Indication: 0
Date: 2000.00.00
Time: 10:28:56
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 76052 km
Time Indication: 0
Date: 2000.00.00
Time: 19:34:59
000 - -
Fault Priority: 1
Fault Frequency: 14
Reset counter: 255
Mileage: 76052 km
Time Indication: 0
Date: 2000.00.00
Time: 19:28:22
Component: IMMO VDD 1212
1 Fault Found:
01176 - Key
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 32319 km
Time Indication: 0
Date: 2000.00.00
Time: 16:11:08
Address 37: Navigation Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 Q HW: 1T0 035 680 Q
Component: RNS-MID H10 RNS-MID H10 52385238
Coding: 04000202040000A10000
Shop #: WSC 12345 123 12345
VCID: 3C77D27BBF9E7CFE88B-8069
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V11
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 M HW: 1T0 959 701 M
Component: Tuer-SG 008 2010
Coding: 0000565
VCID: 4189A38F187C1116DBD-8014
1 Fault Found:
00109 - Left Mirror Turn Signal Lamp (L131)
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 000 3001
Revision: 00H17000
VCID: 3169F34FA8DC81962BD-8064
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 98C8020C7F2D8405485B030010CC
VCID: 800FE68BD3F6581E143-80D5
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 M HW: 1T0 959 702 M
Coding: 0000565
VCID: 428BAC831D7A0A0EC27-8017
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Component: RNS-MID H10 5238
Revision: AB001001 Serial number: VWZ6Z7P0572665
Component: EU West V11 8117
10 Faults Found:
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 10
Reset counter: 156
Mileage: 76048 km
Time Indication: 0
Date: 2000.00.00
Time: 19:29:35
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 10
Reset counter: 156
Mileage: 76048 km
Time Indication: 0
Date: 2000.00.00
Time: 19:29:38
00856 - Radio Antenna
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 10
Reset counter: 156
Mileage: 76048 km
Time Indication: 0
Date: 2000.00.00
Time: 19:29:38
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 196
Mileage: 76048 km
Time Indication: 0
Date: 2000.00.00
Time: 19:29:38
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 5
Reset counter: 156
Mileage: 76048 km
Time Indication: 0
Date: 2000.00.00
Time: 19:24:43
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 5
Reset counter: 156
Mileage: 76048 km
Time Indication: 0
Date: 2000.00.00
Time: 19:24:44
03138 - Input AUX IN
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 3
Reset counter: 156
Mileage: 76053 km
Time Indication: 0
Date: 2000.00.00
Time: 19:33:14
01305 - Databus for Infotainment
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
Fault Priority: 5
Fault Frequency: 15
Reset counter: 196
Mileage: 0 km
Time Indication: 0
Re: Bledy z VCDS - moze kos zerknac
: ndz wrz 28, 2014 20:03
autor: TomTDI
Skasuj błędy i zobaczysz czy jakieś powrócą.
: ndz wrz 28, 2014 20:09
autor: Jsxx
to juz jest wlasnie po skasowaniu tym automatycznym w VCDS
: ndz wrz 28, 2014 20:29
autor: hagio
Jsxx pisze:to juz jest wlasnie po skasowaniu tym automatycznym w VCDS
tak na szybko
005661 - Glowplug for Cylinder 4 (Q13) świeca pada
Bulb for Blinkers; Rear Left (M6) żarówka do sprawdzenia kierunek tył lewy
00987 - Lamp for Brake Light; Left (M9) światło STOPU lewe-żarówka
00984 - Left Tail Light (M4) lewe chyba tablicy rejestracyjnej
01502 - Bulb for Rear Fog; Left (L46) przeciw-mgielne tylne
01518 - Bulb for Back-Up Lights; Left (M16) wsteczne lewe
02251 - Heater Unit Locked zablokowany piecyk -mała ilość paliwa
00109 - Left Mirror Turn Signal Lamp (L131) lewe lusterko kierunkowskaz
Reszta błędów związana z radiem RNS działa ci ono w ogóle?
: ndz wrz 28, 2014 20:35
autor: turek
[quote="Jsxx"]1 Fault Found:
P161D - 000 - Open Circuit ------- z tego co pamiętam to jest uszkodzona świeca ,a dogrzewacz wymień bezpiecznik pod maska, odblokuj VCDS,em i jeszcze raz przeskanuj
: ndz wrz 28, 2014 20:50
autor: Jsxx
hagio pisze:
tak na szybko
dzieki,
dziwne bo wszystkie zarowki swieca.. ?
Rns510 dolozone pare dni temu wiec nie wiem skad te bledy...
Turek a ktory to bezpiecznik ?
: ndz wrz 28, 2014 20:59
autor: hagio
Jsxx pisze:Turek a ktory to bezpiecznik ?
uprzedzę są dwie wersje skrzynek pod maską http://touranklub.pl/forum/viewtopic.php?f=18&t=3721
nie masz głośników w tylnych drzwiach i źle zakodowane radio-nawigacje(masz wpiętą antenę GPS)?
co do żarówek sprawdź wtyczki od lamp i same żarówki mogły zaśniedzieć gniazda
: ndz wrz 28, 2014 21:05
autor: Jsxx
ok to juz wiem ktorych bezpiecznikow szukac.
tylnych glosnikow nie mam - antena gps wpieta i dziala.. ?
zmienialem cale lampy z tylu to moze dlatego te bledy.. jak to skasowac jakos lepiej niz ta automatyczna funkcja ?
: ndz wrz 28, 2014 21:12
autor: turek
wejdź w dany sterownik z błędami; odczytaj,skasuj,odczytaj błedy
: ndz wrz 28, 2014 21:27
autor: Jsxx
Bezpiecznik dobry
: śr gru 03, 2014 10:03
autor: 1 6 D
W CAN Gateway zakoduj jeszcze sterownik 37 by znikł błąd złego zakodowania CAN Gateway.
