Logi Touran 2005
: pt lis 27, 2015 21:59
Witam ! czy ktos mogl by sprawdzic logi z mojego Tourana ? co dopiero kupilem interfejs i zrobilem autoscan ale nie rozumiem nic
byl bym bardzo wdzieczny
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ5W113145 Mileage: 229490km/142598miles
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L EDC G000SG 6246
Revision: 12345678 Serial number: VWZ7Z0D1215170
Coding: 0000072
Shop #: WSC 00066 001 57865
VCID: 67DBCDC756EF06263A7-8032
2 Faults Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
RPM: 0 /min
Torque: 204.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 00001100
Temperature: -3.6°C
Bin. Bits: 00110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault - Intermittent
RPM: 0 /min
Torque: 188.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 00001100
Temperature: 0.0°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 1
Part No: 1K0 907 379 K
Coding: 0021190
Shop #: WSC 01324 785 00200
VCID: 3A7D44B375DD4BCE959-806F
No fault code found.
Part No: 1K0 907 044 AC
Component: ClimatronicPQ35 066 0404
Shop #: WSC 00000 000 00000
VCID: 68D9CEFB5BF1095E33D-803D
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001289410
Coding: 088B8F020004100000120C000000000000087B075C
VCID: 397F5BBF70DB40D69C3-806C
Coding: 00065493
Shop #: WSC 00000
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0ATJ4B
Coding: 0012338
VCID: 3567578F5CC3A4B678B-8060
Part No SW: 1K0 953 549 AK HW: 1K0 953 549 AK
Component: J0527 036 0070
Coding: 0000042
Shop #: WSC 00835 218 89116
VCID: 7BF381B73A67B2C6CEF-802E
Part No: 1T0 920 861 A
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0007103
Shop #: WSC 80093 222 71269
VCID: 3069669BA3A1819E2BD-8065
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Coding: 0000011
Shop #: WSC 00835 218 102890
VCID: 2A5D74F3857DFB4EE59-807F
5 Faults Found:
01489 - Over-Temp Sensor (G189)
Fault Status: 00101010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 165
Mileage: 166685 km
Time Indication: 0
Date: 2000.00.00
Time: 21:52:13
Start
Temperature: 37.0°C
Temperature: 38.0°C
02251 - Heater Unit Locked
000 - - - Intermittent
Fault Priority: 0
Fault Frequency: 1
Reset counter: 165
Mileage: 166685 km
Time Indication: 0
Date: 2000.00.00
Time: 21:52:13
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 156
Reset counter: 66
Mileage: 229369 km
Time Indication: 0
Date: 2000.00.00
Time: 19:38:06
00003 - Control Module
014 - Defective - Intermittent
Fault Priority: 0
Reset counter: 66
Mileage: 229369 km
Time Indication: 0
Date: 2000.00.00
Time: 19:38:06
Fault Priority: 0
Reset counter: 66
Mileage: 229369 km
Time Indication: 0
Date: 2000.00.00
Time: 19:38:06
Component: IMMO VDD 0814
Shop #: WSC 00835 218 79982
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0157
Coding: 0000116
VCID: F4E12A8B97397DBE0F5-80A1
1 Fault Found:
00120 - Outside Warning Light/Door exit Light Driver Side
Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.6 1502
Address 46: Central Conv. Labels: 1K0-959-433-MIN.lbl
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 80E802087F2D8404084F016011
Part No: 1T0 959 702
Coding: 0000116
VCID: F5E7178F9C4364B638B-80A0
Part No: 1K0 035 186 L
Component: Radio GR0 012 0018
Revision: 0001201S Serial number: VWZ2Z2D1841273
Coding: 0040400
VCID: 2F6B65E7BE9F9E66327-807A
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
Part No: 1K0 959 704 B
Coding: 0000048
Friday,27,November,2015,20:18:27:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
Coding: 0000072
2 Faults Found:
RPM: 0 /min
Torque: 204.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 00001100
Temperature: -3.6°C
Bin. Bits: 00110000
RPM: 0 /min
Torque: 188.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 00001100
Temperature: 0.0°C
Bin. Bits: 00110000
Coding: 0021190
Coding: 00065493
Shop #: WSC 00000
Coding: 0012338
Coding: 0000042
Coding: 0007103
Coding: 0000011
5 Faults Found:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 165
Mileage: 166685 km
Time Indication: 0
Date: 2000.00.00
Time: 21:52:13
Start
Temperature: 37.0°C
Temperature: 38.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 165
Mileage: 166685 km
Time Indication: 0
Date: 2000.00.00
Time: 21:52:13
00664 - Fuel gauge
Fault Priority: 0
Reset counter: 66
Mileage: 229369 km
Time Indication: 0
Date: 2000.00.00
Time: 19:38:06
Fault Priority: 0
Reset counter: 66
Mileage: 229369 km
Time Indication: 0
Date: 2000.00.00
Time: 19:38:06
Fault Priority: 0
Reset counter: 66
Mileage: 229369 km
Time Indication: 0
Date: 2000.00.00
Time: 19:38:06
Coding: 0000116
1 Fault Found:
Coding: 0000116
Coding: 0040400
Coding: 0000048
Coding: 0000048
