Prośba o analizę loga
: sob kwie 01, 2017 23:37
autor: pavloroz
Proszę o analizę loga co prawda nie z tourana ale wiem że przynajmniej wskażecie mi drogę gdzie mam szukać rozwiązania problemu. Chodzi o ten bład
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Z góry dziękuję.
Saturday,01,April,2017,18:18:34:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 280270km/174151miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JT
Component: 1,9l R4 EDC G000SG 1572
Coding: 00002
Shop #: WSC 63351
VCID: 72E1C4113EB4009
WAUZZZ8E73A237873 AUZ6Z0B0309917
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
VCID: E5CB2F4D7F7A671
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 2A511C71D6E4089
4 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
41-00 - Blocked or No Voltage
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
30-10 - Open or Short to Plus - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
35-00 - -
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63351
VCID: 346D020904204E9
1 Fault Found:
35-00 - -
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 36693801425C5C9
2 Faults Found:
00474 - Control Module for Immobilizer
000 - - - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 02042
Shop #: WSC 63351
VCID: 3E7920213A6C949
2 Faults Found:
35-00 - -
01304 - Radio
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00000
Shop #: WSC 45390
VCID: 36693801125C5C9
Subsystem 1 - Part No: 37873
Component: AUZ6Z0B0309917
2 Faults Found:
01304 - Radio
01300 - Control Module for Navigation with CD-Rom (J401)
Address 37: Navigation Labels: 4B0-919-887-BNS4.lbl
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0008
VCID: 356B3F0D0F5A571
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
44-00 - Short Circuit
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BA
Component: Komfortgerát TA7 1310
Coding: 06976
Shop #: WSC 63351
VCID: 71E3CB1D3BB23B1
Subsystem 1 - Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 0002
8 Faults Found:
01562 - Right Rear Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
01559 - Drivers Door
59-10 - Can't Unlock - Intermittent
01331 - Door Control Module; Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
01801 - Door Warning Lamp; Drivers Side (W30)
57-10 - Electric Circuit Failure - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
01802 - Door Warning Lamp; Pass Side (W36)
01560 - Passenger Door
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 07777
VCID: 040D92C914003E9
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 C
Component: symphony II NP2 0151
Coding: 01015
Shop #: WSC 45390
VCID: 2757E545C5F6351
1 Fault Found:
00878 - Connection to Speaker Front Left
36-10 - Open Circuit - Intermittent
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00114
Shop #: WSC 63351
VCID: 438F51D5518EF91
1 Fault Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
31-00 - Open or Short to Ground
Re: Prośba o analizę loga
: sob kwie 01, 2017 23:58
autor: yox
... zobacz tu ;)
