w trasie wyskoczyla mi kontrolka swiec migala. samochod stracil ducha zatrzymalem sie zgasilem po chwili uruchomilem i bylo ok. po jakims czasie byla powtorka. Wrocilem do domu i scan wykazal takie cos.
VIN: WVGZZZ1TZBW084064 License Plate:
Chassis Type: 1T (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 52 55 56 61 62 72
VIN: WVGZZZ1TZBW084064 Mileage: 119390km-74185miles
09-Cent. Elect. -- Status: Malfunction 0000
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-CFHC) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 DQ HW: 03L 907 309 R
Component: R4 2,0L EDC X23 9438
Revision: 42X23--- Serial number: 00000000000000
Coding: 0019001A042400080000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20TDI01103L906018DQ 003004
ROD: EV_ECM20TDI01103L906018DQ_VW36.rod
VCID: 7CEEE443A6EB9E6243B8825-8028
3 Faults Found:
9120 - EGR Sensor 1
P046C 00 [096] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 119382 km
Date: 2017.04.27
Time: 19:11:54
4891 - EGR Valve (N18)
P0403 00 [104] - Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 3
Mileage: 119353 km
Date: 2017.04.27
Time: 15:59:06
4892 - EGR Valve (N18)
P0403 00 [096] - Malfunction
Fault Priority: 2
Fault Frequency: 1
Mileage: 119357 km
Date: 2017.04.27
Time: 18:49:01
Readiness: 0 1 0 0 0
prosba o analize bledow
Re: prosba o analize bledow
Jest problem z recyrkulacja spalin. Trzeba wszystko posprawdzac.
