Prozba O analizę logów błędów
: śr maja 24, 2017 21:55
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Coding: 0000011
Shop #: WSC 01324 785 00200
VCID: 3664EA9341439CF256-8062
3 Faults Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 133
Mileage: 71902 km
Time Indication: 0
01412 - Glow-Plug with Flame Monitoring (Q8)
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 6
Reset counter: 142
Mileage: 72501 km
Time Indication: 0
Start
Temperature: 64.0°C
Temperature: 64.0°C
Voltage: 14.53 V
02251 - Heater Unit Locked
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 102
Mileage: 72543 km
Time Indication: 0
Kod:
Address 3D: Special Function Labels: None
Part No SW: 1T0 907 427 A HW: 1T0 907 427 A
Component: MFG 011 0010
Revision: M0011000 Serial number: 00000000020263
Coding: 0101010101
Shop #: WSC 13240 620 57740
VCID: 3362D387523189DA71-8066
1 Fault Found:
02071 - Local Databus
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 351024 km
Time Indication: 0
Date: 2000.00.00
Time: 08:01:39
Kod:
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1201
Coding: 0000053
VCID: 3878E4AB4B576A8244-806C
1 Fault Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
Kod:
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000052
VCID: 397EE1AF705D738ABB-806C
1 Fault Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Coding: 0000011
3 Faults Found:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 133
Mileage: 71902 km
Time Indication: 0
Fault Priority: 3
Fault Frequency: 6
Reset counter: 142
Mileage: 72501 km
Time Indication: 0
Start
Temperature: 64.0°C
Temperature: 64.0°C
Voltage: 14.53 V
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 102
Mileage: 72543 km
Time Indication: 0
Kod:
Coding: 0101010101
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 351024 km
Time Indication: 0
Date: 2000.00.00
Time: 08:01:39
Kod:
Coding: 0000053
1 Fault Found:
Kod:
Coding: 0000052
1 Fault Found:
