Zachciało mi się zakładać haka do Alhambry .
Pierw wrzuciłem sterownik 7N0 907 383 .
tak jakoś trudno mu sie przyglądać : Poratuje ktoś pliczkem*.lbl do VCDSa ?
Po przeskanowaniu zostały takie błędy :
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Saturday,30,November,2019,21:44:26:65217
Chassis Type: 7N (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 20 25 2E 36 37 42 44 46 4C
4F 52 53 56 61 62 69 6C 6D 72 7D A5 B9 BE BF
15-Airbags -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: Not registered 0011
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
B9-Aux. Display -- Status: OK 0000
BE-Sliding Door Left -- Status: OK 0000
BF-Sliding Door Right -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HM HW: 03L 906 018 M
Component: R4 2,0L EDC H27 9229
Revision: 44H27--- Serial number:
Coding: 001D001A043401080000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01103L906018HM 003006
ROD: EV_ECM20TDI01103L906018G.rod
VCID: 7CFDECB0F715A6FEC8B-8029
2 Faults Found:
4113 - Camshaft Position Sensor (G40)
P0341 00 [096] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 248141 km
Date: 2088.14.03
Time: 17:44:47
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [096] - Incorrect Correlation
Fault Priority: 2
Fault Frequency: 5
Mileage: 249153 km
Date: 2088.14.15
Time: 19:26:33
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 057 L HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3101
Revision: 05551213 Serial number: 00001201252397
Coding: 0000020
Shop #: WSC 00020 790 00000
VCID: 2241F2C8FD31300EA27-8077
No fault code found.
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 N HW: 7N0 614 109 N
Component: J104 C3 450M VD3F 0021
Revision: --H07--- Serial number: 00000005330528
Coding: 0027262
VCID: 387530A04BAD4ADE6C3-806D
1 Fault Found:
02214 - Tire Pressure Warning
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 5
Reset counter: 99
Mileage: 249151 km
Time Indication: 0
Date: 2024.14.15
Time: 19:04:48
Speed: 54.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 13.25 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 FL HW: 5K0 907 044 FL
Component: Clima-Sharan H18 0204
Revision: 00001003
Coding: 0200104509
ASAM Dataset: EV_ClimatronicSharan A01005
ROD: EV_ClimaAutoSharaBasis_VW36.rod
VCID: 7AF1EAA8FD2198CEDA7-802F
Subsystem 1 - Part No SW: 7N0 907 049 B HW: 7N0 907 049 B
Component: KBT-H 004 0102
Serial number: 20120203000000059119
1 Fault Found:
9479443 - Control Circuit for Front Right Seat Heater
B10A5 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Fault Priority: 3
Fault Frequency: 2
Reset counter: 90
Mileage: 246912 km
Date: 2087.14.19
Time: 20:17:16
Address 09: Cent. Elect. (J519) Labels: User\1K0-937-08x-09.lbl
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0064
Revision: BC021001
Coding: 48590A3B89251AC0500800C8740081EC47599288737D2D626480C72200C1
Shop #: WSC 48030 123 104857
VCID: 3E7926B8A98974EEA6F-806B
Subsystem 1 - Part No SW: 7N1 955 119 A HW: 7N1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 120120 31 0032
Coding: 004DBD
Subsystem 2 - Part No SW: 7N0 955 559 HW: 7N0 955 559 Labels: USER\7N0-955-559.LBL
Component: RLFS 021 0024
Coding: 239597
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 7N0 919 475 A HW: 7N0 919 475
Component: PARKHILFE 8K H06 0012
Revision: -------- Serial number: 28261203002996
Coding: 308102
Shop #: WSC 01234 123 45725
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 397335A4B8A753D693D-806C
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag004 H10 0014
Serial number: 003LGP2BDW71
Coding: 003034
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428_VW36.rod
VCID: 3F875BBCA6837DE6AD9-806A
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60DBE000149DW
Coding: 000000
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS603A9BFE139D4
Coding: 000000
Crash sensor for side airbag; rear driver side:
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60118B0014DDC
Coding: 000000
Crash sensor for side airbag; rear passenger side:
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60118DFE13DD0
Coding: 000000
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS6005B8FF139DV
Coding: 000000
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 BA HW: 5K0 953 569 H
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20120208302054
Coding: 199A240000
VCID: 6AD1DAE88D81284E2A7-803F
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 1P0 959 538 B HW: 1P0 959 538 B
Component: E221__MFL-TAP H02 0102
Coding: E30000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 7N5 920 870 E HW: 7N5 920 870 E
Component: KOMBI H03 0609
Serial number: 00000000000000
Coding: 141F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
Part No: 7N0 963 271 C
Component: Zuheizer 051 2730
Revision: 00051000 Serial number: 09022126000000
Coding: 0000041
VCID: 346D049057C5AEBE40B-8061
1 Fault Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 4
Reset counter: 102
Mileage: 248845 km
Time Indication: 0
Date: 2024.14.09
Time: 17:09:25
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 050314F2002532
Coding: 468202
Shop #: WSC 12345 123 12345
VCID: 7CFDECB0FF15A6FEC8B-8029
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 5
Reset counter: 255
Mileage: 249200 km
Time Indication: 0
Date: 2024.14.17
Time: 14:43:04
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 7N0 857 511 F HW: 8P0 857 511 C
Component: FLA H04 0012
Revision: AA001002
Coding: 0101816B74745D545420363E01
VCID: 36693E9881B9BCAE7EF-8063
Component: IMMO H03 0609
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EAD15AE80D81A84EAA7-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661742162
Coding: 020000
VCID: 2953E5E44007E356E3D-807C
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 A HW: 3C8 959 760 A
Component: Sitzmemory H05 2601
Revision: 00H05000
Coding: 000018
Shop #: WSC 12336 024 394758
VCID: 336F078C92CBA986591-8066
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 5P0 035 191 G HW: 5P0 035 191 G
Component: RNS315-EU H36 0263
Serial number: SEZAZ2M9164826
Coding: 04000401040024001006100C
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 2F670BFC76E38D663D9-807A
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V9 0069
Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb
Part No SW: 7N0 959 793 E HW: 7N0 959 793 A
Component: TSG FA H04 0400
Revision: Serial number: 0000123759675
Coding: 01152E20DE00411001
Shop #: WSC 00020 790 12345
VCID: 448D5450C7651E3EF0B-8011
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.325 1002
Revision: 1AH03734 Serial number: 00120330040101
Coding: 0000258
VCID: 3C7D2CB07F9566FE88B-8069
Address 46: Central Conv.
Cannot be reached
Address 4C: Tire Pressure II
Cannot be reached
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1642
Coding: 05020100
VCID: EFE74BFC3E634D66FD9-80BA
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Address 52: Door Elect, Pass. (J387) Labels: 7N0-959-792.clb
Part No SW: 7N0 959 792 E HW: 7N0 959 792 A
Component: TSG BF H04 0400
Revision: Serial number: 0000123936226
Coding: 01152C20DE00411001
VCID: 438F574CC26B1906C91-8016
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000651754
Coding: 0024167
VCID: 356B39945CBFB7B6775-8060
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1642
Coding: 230F1859
VCID: F1E34D8428575B96EBD-80A4
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Address 62: Door, Rear Left (J388) Labels: 7N0-959-794.clb
Part No SW: 7N0 959 794 F HW: 7N0 959 795 B
Component: TSG HL H03 0403
Revision: Serial number: 0000124036800
Coding: 01006C200000411001
Shop #: WSC 64117 001 1048576
VCID: 46894E58F1592C2EEEF-8013
Address 69: Trailer (J345) Labels: None
Part No SW: 7N0 907 383 HW: 7N0 907 383
Component: Anhaenger H09 0120
Revision: 3I001003 Serial number: 00008160053433
Coding: 0200000000000000
Shop #: WSC 06745 128 28888
VCID: F3EF478C524B6986191-80A6
3 Faults Found:
01314 - Engine Control Module
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 103
Mileage: 25345 km
Time Indication: 0
Date: 2014.12.17
Time: 10:24:51
01316 - ABS Control Module
Fault Priority: 6
Fault Frequency: 1
Reset counter: 103
Mileage: 25345 km
Time Indication: 0
Date: 2014.12.17
Time: 10:24:51
00532 - Supply Voltage B+
Fault Priority: 3
Fault Frequency: 4
Reset counter: 143
Mileage: 25345 km
Time Indication: 0
Date: 2015.01.30
Time: 15:41:30
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7N0 907 441 A HW: 7N0 907 441 A
Component: J772__Rearview 0120
Revision: 00H10000 Serial number: 525 PA8J211639
Coding: 0000011
Shop #: WSC 00070 000 00000
VCID: 2F670BFCBEE38D663D9-807A
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 246394 km
Time Indication: 0
Date: 2023.14.14
Time: 23:09:12
Term 15 On
Reverse OFF
Count: 3
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7N0 959 107 C HW: 7N0 959 107 A
Component: HDSG-Modul H11 0804
Revision: 41011001 Serial number: 019200548
Coding: 0733334002
ASAM Dataset: EV_HDSGVW428 201133
ROD: EV_HDSGVW428.rod
VCID: 3777339C8EB345A6659-8062
Address 72: Door, Rear Right (J389) Labels: 7N0-959-794.clb
Component: TSG HR H03 0403
Revision: Serial number: 0000124036624
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5B11F4B4EFFF760F5-8078
Address A5: Frt Sens. Drv. Assist (R242) Labels: User\3AA-980-654.lbl
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H09 0300
Serial number: 0193839941
Coding: 01010000010202100000000000000000
Shop #: WSC 12343 765 23233
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
1 Fault Found:
5701632 - Control Module Incorrectly Coded
U1014 00 [009] - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 249200 km
Date: 2088.14.17
Time: 14:43:38
Address B9: Aux. Display (J285) Labels: None
Part No SW: 5C5 919 527 B HW: 5C5 919 527 B
Component: ZUSATZANZEIGE H15 0014
Coding: 05
ASAM Dataset: EV_Auxi_Disp_Unit 001007
ROD: N/A
VCID: 306508806BDD929E243-8065
No ASAM data for: "EV_Auxi_Disp_Unit" (VW36)
Address BE: Sliding Door Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 B HW: 7N0 959 244 B
Component: Schiebetuer_l 005 2414
Serial number: 11504237
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
VCID: 387530A083AD4ADE6C3-806D
Address BF: Sliding Door Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2414
Serial number: 11503364
ROD: EV_AST.rod
te błędy Gateway'a 19 i haka 69 zniknęły po ''zaptaszkowaniu'' modułu haka w Instalation list .
Trochę dziwne ,że zniknął błąd trzeci bo hak jeszcze nie jest podłączony .
I sterownik powinien ciągle widzieć przerwę w obwodzie .
Ale kij . Zmartwiła mnie kamerka
pojawił sie na stałe błąd :
U1014 00
niby co ma piernik do wiatraka - kamerka do haka , ale cóś ma
W kodowaniu kamerki znalazłem to:
I co by było weselej nie mogłem tego zmienić w kodowaniu
No i potem jeszcze się zdziwiłem .
Zniknął Lane assist :
w kodowaniu jest
na zegarach zniknęła możliwość jego włączania / wyłączania
a w miejscu pasów jest tylko komunikat :Lane assist wyłączony . I jak tu żyć ??
Towarzysze ... pomożecie ?
