spacewalker pisze:jeżu pisze:Jak nie masz fabrycznego alarmu to nie uruchomisz tej funkcji...
autoscan trzeba wkleic ....................i bedzie wiadomo czy jest syrena czy nie
Saturday,01,February,2020,17:12:53:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVGZZZ1TZCW003199 License Plate:
Mileage: 157480km-97853mi Repair Order:
Chassis Type: 1T (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 52 56 61 62 69 72
VIN: WVGZZZ1TZCW003199 Mileage: 157480km-97853miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (J623-CFHC) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 NN HW: 03L 907 309 R
Component: R4 2.0l TDI H23 9977
Revision: 42H23--- Serial number: 00000000000000
Coding: 0019001A042500080000
Shop #: WSC 00738 210 00000
ASAM Dataset: EV_ECM20TDI01103L906018NN 003004
ROD: EV_ECM20TDI01103L906018NN.rod
VCID: 030E27E08A151959F4-8056
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 333B6016092206FDCC0C06ED90226082310150
Shop #: WSC 01324 020 00200
VCID: 7BFE5F00FAE56199BC-802E
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004002
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 7F06AB10E6FD7DB990-802A
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 F HW: 5K0 937 084 F
Component: BCM PQ35 B 011 0048
Revision: BA011001
Coding: 4C180A388025F1E0400800C0140000E449518E08526DA160648042000040
VCID: 356A89389C4177E90A-8060
Subsystem 1 - Part No: 1T2 955 119 A
Component: Wischer 27041 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 300511 05 54 0403
Coding: 0230ED
Subsystem 3 - Part No: 7N0 951 171
Component: DWA-Sensor 00 002 0205
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56231111101543
Coding: 059001
Shop #: WSC 05595 210 01865
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000_VW41.rod
VCID: 448CE4FCCF9BDE618D-8010
Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
Component: 02 AIRBAG VW8 022 0100
Revision: 02022000 Serial number: 003K4D037K8Z
Coding: 0012338
VCID: 37768330464D85F918-8062
Subsystem 1 - Serial number: 6332QSME720050582
Subsystem 2 - Serial number: 6342QSME5B1E474CY
Subsystem 3 - Serial number: 6352QSME28243A62E
Subsystem 4 - Serial number: 6362QSME781E5174P
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KEI0002L
Coding: 1082140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_VW32.rod
VCID: 72E07224A5AF20D1EF-8026
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Serial number: 0198052
Coding: 820000
Part No SW: 1T0 920 975 A HW: 1T0 920 975 A
Component: KOMBI H03 0607
Coding: 181B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 36688E3489477CF103-8062
Part No: 7N0 963 271 C
Component: Zuheizer 051 2730
Revision: 00051000 Serial number: 09022126000000
Coding: 0000011
VCID: 346CB43C573B6EE13D-8060
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 280511F2001888
Coding: 358003
VCID: 37768330864D85F918-8062
2 Faults Found:
01304 - Radio
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 124
Reset counter: 29
Mileage: 156591 km
Time Indication: 0
Date: 2014.06.01
Time: 19:22:32
000 - - - Intermittent
Fault Priority: 2
Reset counter: 29
Mileage: 156591 km
Time Indication: 0
Date: 2014.06.01
Time: 19:22:32
Component: IMMO H03 0607
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6AD06A448D7FE81157-803E
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2122
Coding: 0000693
VCID: 4894F0CC3BB3FA0161-801C
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
Shop #: WSC 01324 785 00200
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000693
VCID: 4796F3F036ADF57968-8012
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: E100085A
VCID: 71E27D28A8A91BC916-8024
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2104
Coding: 0000144
Shop #: WSC 01324 020 1012552
VCID: 3260B224AD2F60D12F-8066
Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000153462790
Coding: 0100000100000000
VCID: 3064B82C632352C159-8064
1 Fault Found:
00526 - Brake Light Switch (F)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 241
Mileage: 156591 km
Time Indication: 0
Date: 2014.06.02
Time: 05:26:23
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 336EB720523569D924-8066
