Zamykanie bagażnika przy użyciu przycisku
: ndz gru 13, 2020 18:49
autor: Lucas13
Szukam info jak zaprogramować lub magicznie ustawić przycisk otwierający klapę bagażnika z konsoli tak aby również ją zamykał. :)
Re: Zamykanie bagażnika przy użyciu przycisku
: ndz lip 31, 2022 08:29
autor: GASIOR997
Enabling boot closing from the keyfob and interior button on Combi models with the powered tailgate
Controller 6D - Trunk Electrics
16 - Security Access - enter 12345
10 - Adaptations
(4)-Activation using rear lid opening button in remote key-Tap function for closing - set to active
Attached File Trunk1.png 45.63KB 285 downloads
(4)-Activation using rear lid remote unlocking switch-Tap function for closing - set to active
Attached File Trunk2.png 45.74KB 256 downloads
The beeps can be disabled as below - just set the ones you want to 'not active' if you want to customise it and have some beeps - fairly self explanatory
Attached File Beep1.png 37.87KB 267 downloads
Attached File Beep2.png 38.1KB 244 downloads
Attached File Beep3.png 38.15KB 238 downloads
Attached File Beep4.png 38.09KB 232 downloads
Or if you just want to disable all beeps, courtesy of antera
Attached File Beep5.png 37.26KB 230 downloads
Original thread here
Enabling boot closing from keyfob and interior button using VCDS - Skoda Octavia Mk III (2013 - 2020) - BRISKODA
