Wczoraj nabylem, dzis podlaczylem VAG.
lelo
Auto:: 1T2 BLS MY08
Post autor: lelo »
Witam wszystkich, nabylem wczoraj Tourana, podpialem dzis kompa i po wykasowaniu bledow zwiazanych z wymiana aku zostalo to:
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Coding: 0000011
Shop #: WSC 01324 785 00200
VCID: 366722EB38D7
4 Faults Found:
01406 - No Flame
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 10
Reset counter: 194
Mileage: 126848 km
Time Indication: 0
Start
Temperature: 70.0°C
Temperature: 69.0°C
Voltage: 14.60 V
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 4
Reset counter: 173
Mileage: 126985 km
Time Indication: 0
01407 - Flame Extinguished
Fault Priority: 3
Fault Frequency: 2
Reset counter: 194
Mileage: 127180 km
Time Indication: 0
Start
Temperature: 68.0°C
Temperature: 66.0°C
Voltage: 14.53 V
02251 - Heater Unit Locked
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 154
Time Indication: 0
Revision: H07 01 Serial number: 070507F2000551
Coding: E9A07F46400A028002
Shop #: WSC 12345 141 62156
VCID: 306B14F3DAB3
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 161
Mileage: 127562 km
Time Indication: 0
Date: 2000.00.00
Time: 22:00:10
Address 37: Navigation
Cannot be reached
Part No: 5M0 035 186 C
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2G3169831
Coding: 0020200
Shop #: WSC 01287 785 00200
VCID: 2C530083F69B
1 Fault Found:
000 - -
Address 10: Park/Steer Assist Labels: 1T0-919-475.clb
Control Module Part Number: 1T0 919 475 HW: 1T0 919 475
Component and/or Version: PARKHILFE PLA H07 0002
Software Coding: 010001
Work Shop Code: WSC 12345 141 62156
VCID: F8FB6CD3F243
1 Fault Found:
02069 - Front Parking Aid Sensors
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 161
Mileage: 127562 km
Time Indication: 0
Date: 2000.00.00
Time: 22:25:50
Temperature: 10.0°C
Pierwszy blad - odblokowalem za pomoca manuala z forum i skasowalem. Rozumiem, ze musze poczekac na temperature ponizej 5 stopni, zeby sprawdzic czy blad wraca? Nie da sie tej farelki jakos recznie zalaczyc.. albo przynajmniej sprobowac zalaczyc?
Nastepne 3 bledy - najwyrazniej sprzedajacy albo komis wyjeli nawige dla siebie albo sprzedali osobno.... wystarczy, ze kupie RNS albo MFD2 i bedzie navi dzialac czy jestem w bledzie?
I ostatni - w przednim zderzaku nie ma sensorow... tez zabrane i zderzak wymieniony? Jest to dosc uciazliwe bo przez to nie dziala rowniez tyl. Da sie jakos VAGiem wylaczyc przod?
Dzieki za wszelkie komentarze... jesli temat nie jest tam gdzie ma byc to przepraszam, dopiero sie wdrazam na forum.
Pozdrawiam.
Marcin
Vagiem da się wyłączyć.
Jeżeli chcesz przetestować piec, to wejdź w 18 - AUX HEAT -> BASIC SETTINGS -> kanał 11 i wymuś odpalenie webasto.
Z navi albo wyłączysz w kodowaniu albo kupisz sobie takie, jak piszesz i poprawnie zakodujesz.
lelo
Auto:: 1T2 BLS MY08
Post autor: lelo »
Dzieki za info, jutro w pracy posprawdzam, tylko jedna rzecz. W kodowaniu bordnetz'a (mam 3C0 937 049 AH) byte 4 bit 0 - Aux. Heater installed odznaczone - zaznaczyc wczesniej czy bez znaczenia?
A wiesz moze jak wylaczyc PDC przod VAGiem?
Marcin
1 6 D
Auto:: Scirocco VAN
Post autor: 1 6 D »
Tobie to nawet 6 czujników brakuje z przodu w sumie bo masz sterownik pod Park Assist.
Co do błędu nawigacji to możesz z CAN Gateway wykodować na razie moduł 37.
Samo radio ma też prawdopodobnie ilość głośników czy inne funkcje źle zakodowane.
lelo
Auto:: 1T2 BLS MY08
Post autor: lelo »
Racja, radio dzis wywalilo kod, ze zle zakodowane... poki co gra, wiec chwilowo mi ten kod nie przeszkadza.. walcze z PDC przod.. wie ktos jak wylaczyc to badziewie VAGiem, tak, zeby dzialal tylko PDC tyl? Z gory dzieki i pozdrawiam.
Marcin
1 6 D
Auto:: Scirocco VAN
Post autor: 1 6 D »
Chyba tylko zmiana sterownika PDC na taki z 4 kanałami zamiast z 10
lelo pisze:W kodowaniu bordnetz'a (mam 3C0 937 049 AH) byte 4 bit 0 - Aux. Heater installed odznaczone - zaznaczyc wczesniej czy bez znaczenia?
Nie zaznaczaj,bo to jest bit do elektrycznej nagrzewnicy :)
lelo
Auto:: 1T2 BLS MY08
Post autor: lelo »
Ok dzieki za info. Co do PDC to widze, ze VAGiem nic na nawojuje a sterownik PDC ten co mam ze steer assist wolalbym zostawic. Moze kiedys doloze przod chociaz z tego co widze to koszta spore. Pojade w przyszlym tyg do mojego speca moze jakis opornik zamiast tych przednich czujek da sie zalozyc chociaz marnie to widze. Jakby sie porwac na dolozenie przodu to trzebaby wymienic zderzak i nabyc 6 gwizdkow czy obecny zderzak plus otwornica dzwignie temat?
[ Dodano: Sob Lut 09, 2013 22:46 ]
Temat do zamkniecia. Radio ogarnalem. Zuheizer tez. Navi poki co nie mam, wiec wylacozne. Steer assist nie da sie wylaczyc przodu PDC VAGiem, wiec bede rzezbil inaczej. Dzieki za pomoc.
Marcin
