błędy z autoscanu wycieraczki,
: czw sie 08, 2013 06:24
autor: gabi10
Witam po przeskanowaniu takie błędy
co to za błędy zwiazane z silnikami wycieraczek oraz maglownica
prosze sznowne grono o zuceniem okiem na te błedy
Pomijam bład pozycjonowania świateł xenonów gdyż brak z przodu czujnika pozycjonowania
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
55-Xenon Range -- Status: Not registered 0011
56-Radio -- Status: OK 0000
69-Trailer -- Status: Not registered 0001
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 EH HW: 028 101 178 6
Component: R4 2,0L EDC G000SG 5687
Revision: 12345678 Serial number: VWZ7Z0D9347876
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 6DDBD76D748ADF1
No fault code found.
Readiness: 0 0 0 0 1
Part No: 1K0 907 379 D
Coding: 0056006
Shop #: WSC 01324 785 00200
VCID: 336F0115522E491
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 70E5CE1963B8329
Part No SW: 1K0 937 049 G HW: 1K0 937 049 G*
Component: PQ35 BordnetzSG 1.0 0501
Revision: 12345678 Serial number: 00000000184045
Coding: 038B8F000004100000120C000000000000
Coding: 00065493
Shop #: WSC 00000
3 Faults Found:
00153 - Windshield Wiper Motor; Driver Side (V216)
00154 - Windshield Wiper Motor; Passenger Side (V217)
Component: 04 AIRBAG VW62 0102 2112
Coding: 0012340
VCID: F2E14411EDB4809
Component: Lenksäulenmodul 009 0030
Coding: 0000042
VCID: 30650E19A338729
Part No: 1T0 920 871 A
Component: KOMBIINSTRUMENT VDD 0812
Coding: 0007101
Shop #: WSC 52370 124 64500
VCID: 31630B1DA8327B1
Part No: 1K0 815 071 P
Component: Zuheizer 031 1312
Coding: 0000011
Shop #: WSC 00580 210 54986
VCID: 32610411AD34409
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 21001042100730
Coding: 3D3F1740078002
VCID: 2757E54596F6351
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 5
Reset counter: 5
Mileage: 125041 km
Time Indication: 0
Date: 2000.00.00
Time: 17:34:06
Component: IMMO VDD 0812
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0111
Coding: 0000116
VCID: F4ED420997A08E9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
Part No: 1K1 909 143 L
Component: EPS_ZFLS Kl.0 0402
1 Fault Found:
00750 - Warning Lamp
013 - Check DTC Memory - Intermittent
Mileage: 5040 km
Temperature: 35.0°C
Voltage: 12.90 V
Voltage: 12.70 V
Address 46: Central Conv. Labels: 1K0-959-433-MIN.lbl
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 81E802087F2D8505480FC61001
Shop #: WSC 00439 210 71691
VCID: 7BFFE9353AFE411
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4804
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Part No: 1T0 959 702
Coding: 0000116
VCID: F5EB7F0D9CDA971
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0001
Coding: 0000001
1 Fault Found:
00496 - Sensor for Vehicle Leveling; Front
010 - Open or Short to Plus
Part No: 1K0 035 186 G
Component: Radio GR0 0011
Revision: 0000903S Serial number: VWZ2Z2D2200298
Coding: 0040400
VCID: 2A511C7185E4089
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 05 0107
Coding: 0000048
VCID: 2F670D65BE066D1
Address 69: Trailer
Cannot be reached
Part No: 1K0 959 704 B
Coding: 0000048
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 02 Einparkhilfe 0101
VCID: 2D5B176DB40A1F1
: czw sie 08, 2013 12:15
autor: 1 6 D
A próbowałeś kasować te błędy?
Poza tym w CAN Gateway dokoduj w bajcie 0 sterownik Xenonów czyli 55 oraz w bajcie 2 sterownik o numerze 69 do przyczepki.
