Prosba o interpretacje scanu
marcelid
Auto:: BASIC, 1.9 TDi-BKC, 2004
Imię:: Marceli
Post autor: marcelid »
Moj new wywalil takowe bledy ...
Monday,18,November,2013,18:42:59:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 18 19 25 3D 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ5W082665 Mileage: 331300km/205860miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
3D-Special Function -- Status: OK 0000
Part No SW: 03G 906 016 HK HW: 028 101 184 4
Component: R4 2,0L EDC G000AG 9971
Revision: 12345678 Serial number: VWZ7Z0D0790649
Coding: 0000078
Shop #: WSC 27553 123 85418
VCID: 73EFC11512AE091
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 050 E HW: 02E 927 770 AE
Component: GSG DSG 070 1404
Revision: 04507000 Serial number: 00000604190048
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 142DA2893760AE9
1 Fault Found:
17252 - Transmission Fluid Pressure Adaptation at Limit
P0868 - 001 -
Fault Status: 01100001
Fault Priority: 0
Reset counter: 2
Mileage: 331300 km
Time Indication: 0
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023238
Shop #: WSC 01324 785 00200
VCID: 3A712C317544B89
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 CR
Component: Climatic PQ35 081 0404
Shop #: WSC 00000 000 00000
VCID: 76E9F80101DC1C9
Address 09: Cent. Elect. Labels: User\3C0-937-049-23-M.lbl
Part No SW: 1K1 937 049 HW: 1K1 937 049 *
Component: Bordnetz-SG 1.0 H30 0201
Revision: 00H30000 Serial number: 00000001144131
Coding: 00890F020004100000120C000000000000
VCID: EDDB576DF48A5F1
Subsystem 1 - Part No: 1T0 955 119 C Labels: USER\1KX-955-119.LBL
Coding: 00065493
Shop #: WSC 00000
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD09XR3L
Coding: 0012338
VCID: 356B3F0D5C5A571
Address 16: Steering wheel Labels: User\1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 500 0030
Coding: 0010042
VCID: 30650E19A338729
Part No: 1T0 920 861 A
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0003103
Shop #: WSC 11111 111 11111
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Coding: 0000011
Shop #: WSC 54321 023 00001
VCID: 2A511C7185E4089
5 Faults Found:
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 116
Reset counter: 32
Mileage: 330972 km
Time Indication: 0
Date: 2000.00.00
Time: 17:17:34
000 - - - Intermittent
Fault Priority: 0
Reset counter: 32
Mileage: 330972 km
Time Indication: 0
Date: 2000.00.00
Time: 17:17:34
01410 - Heater Over-Temp
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 228
Mileage: 328206 km
Time Indication: 0
Date: 2000.00.00
Time: 08:15:06
Ctrl. Pause
Temperature: 148.0°C
Temperature: 59.0°C
02251 - Heater Unit Locked
Fault Priority: 0
Fault Frequency: 1
Reset counter: 228
Mileage: 328206 km
Time Indication: 0
Date: 2000.00.00
Time: 08:15:06
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 45
Reset counter: 26
Mileage: 330427 km
Time Indication: 0
Date: 2000.00.00
Time: 23:29:49
Malfunction
Temperature: 205.0°C
Temperature: 3.0°C
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104A1504B2
Coding: 3F3F1341078002
VCID: 2953E37D80E2031
Component: IMMO VDD 0814
Shop #: WSC 01942 161 63991
Address 3D: Special Function Labels: None
Part No SW: 1T0 907 427 HW: 1T0 907 427
Component: MFG 010 X413
Revision: M0010000 Serial number: 00000000003427
Coding: 0101010101
Shop #: WSC 40380 123 61904
VCID: F2E14411EDB4809
Address 42: Door Elect, Driver Labels: User\1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0157
Coding: 0000116
VCID: F4ED420997A08E9
Address 44: Steering Assist Labels: User\1Kx-909-14x-44.lbl
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.0 1401
VCID: 2F670D65BE066D1
Address 46: Central Conv. Labels: User\1K0-959-433-MIN.lbl
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 80E802087F2D8404084F016011
VCID: 7BFFE9353AFE411
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: User\1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000116
VCID: F5EB7F0D9CDA971
Part No: 1K0 035 186 L
Component: Radio BVX 010 0022
Coding: 0020200
1 Fault Found:
00003 - Control Module
014 - Defective
Address 62: Door, Rear Left Labels: User\1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
Address 72: Door, Rear Right Labels: User\1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
z estetyki autka mam duzo do zrobienia takze chcialbym uniknac innych potkniec i niepotrzebnych napraw :D
161GD030, SQ6KBO
Mój MAJONEZIK ... a to JA
Re: Prosba o interpretacje scanu
O dsg pisałem w innym wątku, ale reszta to problemy z dogrzewaczem, prawdopodobnie do wymiany czujnik temperatury g18. Przede wszystkim odblokuj dogrzewacz i sprawdź czy pracuje. (i na jak długo)...
