Pomoc w odczycie błędów
: pt mar 18, 2011 22:15
wczoraj zrobiłem mój pierwszy AUTO-SCAN:
Thursday,17,March,2011,20:19:45:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ4W044493 Mileage: 183720km/114158miles
01-Engine -- Status: Malfunction 1010
15-Airbags -- Status: OK 0000
Part No SW: 03G 906 016 A HW: 028 101 073 1
Component: R4 1,9L EDC G000SG 5185
Revision: 12345678 Serial number: VWZ7Z0C8083849
Coding: 0000072
Shop #: WSC 01324 785 00200
1 Fault Found:
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 000 - - - Intermittent
RPM: 882 /min
Torque: 42.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00001100
Temperature: 13.5°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Part No: 1K0 907 379 D
Coding: 0053958
No fault code found.
Part No: 1K0 907 044 K
Component: ClimatronicPQ35 061 0201
Shop #: WSC 00000 000 00000
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
000 - -
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 F HW: 1K0 937 049 F*
Component: PQ35 BordnetzSG 1.0 0501
Revision: 12345678 Serial number: 00000000149560
Coding: 08890F000004100000120C000000000000
Part No: 1T0 955 119 A
Component: Wischer WWS A-MPV 0101
Coding: 16711700
Shop #: WSC 00000
1 Fault Found:
01314 - Engine Control Module
Component: 04 AIRBAG VW62 0102 2112
Coding: 0012340
Component: Lenksäulenmodul 009 0030
Coding: 0000042
Part No: 1T0 920 860 C
Component: KOMBIINSTRUMENT VDD 1714
Coding: 0003101
Shop #: WSC 01230 048 52084
1 Fault Found:
Part No: 1K0 815 071 C
Component: Zuheizer 0707
Revision: C Serial number: 09006207
Coding: 0000011
5 Faults Found:
02085 - Incorrect Control Module Installed
(no units): 118.4
Temperature: -1115.2°C
Raw, Form. N/A: 000 003 046
Temperature: -799.1°C
Load: 10.3 %
(no units): 0.0
Raw, Form. N/A: 000 000 000
(no units): 118.4
Load: 10.3 %
(no units): 0.0
00003 - Control Module
014 - Defective - Intermittent
(no units): 118.4
Load: 10.3 %
(no units): 0.0
01411 - Temperature Sensor (G18)
Error Code: 52628
Text: 00.00.00
Clock: 17:05
Malfunction
Temperature: 205.0°C
Temperature: 72.0°C
00664 - Fuel gauge
Error Code: 52590
Text: 00.00.00
Clock: 14:46
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 2100103729988F
Coding: 3D3F1340078002
1 Fault Found:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 212
Mileage: 183581 km
Time Indication: 0
Date: 2000.00.00
Time: 19:36:47
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 1714
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0111
Coding: 0000116
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 42617 146 87400
1 Fault Found:
Mileage: 183560 km
Temperature: 10.0°C
Voltage: 12.80 V
Voltage: 12.60 V
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 00E802087F2D8404084F0100
Part No: 1T0 959 702
Coding: 0000116
Part No: 1K0 035 186 D
Component: Radio BNO 0216
Coding: 0040200
Shop #: WSC 01480 048 02708
1 Fault Found:
014 - Defective
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 05 0107
Coding: 0000048
Part No: 1K0 959 704 B
Coding: 0000048
Czy możecie mi pomóc odszyfrować te błędy? oraz jak uporać się z usunięciem tych błędów?
pozdrawiam Robert
Chassis Type: 1K0
Coding: 0000072
1 Fault Found:
RPM: 882 /min
Torque: 42.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00001100
Temperature: 13.5°C
Bin. Bits: 10110000
Coding: 0053958
1 Fault Found:
000 - -
Coding: 16711700
Shop #: WSC 00000
1 Fault Found:
Coding: 0012340
Coding: 0000042
Coding: 0003101
1 Fault Found:
Coding: 0000011
5 Faults Found:
(no units): 118.4
Load: 10.3 %
(no units): 0.0
(no units): 118.4
Load: 10.3 %
(no units): 0.0
(no units): 118.4
Load: 10.3 %
(no units): 0.0
Error Code: 52628
Text: 00.00.00
Clock: 17:05
Malfunction
Temperature: 72.0°C
00664 - Fuel gauge
Error Code: 52590
Text: 00.00.00
Clock: 14:46
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 212
Mileage: 183581 km
Time Indication: 0
Date: 2000.00.00
Time: 19:36:47
Coding: 0000116
1 Fault Found:
Mileage: 183560 km
Temperature: 10.0°C
Voltage: 12.80 V
Voltage: 12.60 V
Component: KSG 0201
Coding: 0000116
Coding: 0040200
1 Fault Found:
014 - Defective
Coding: 0000048
Coding: 0000048
pozdrawiam Robert
