Prośba o sprawdzenie logów
: pn kwie 14, 2014 07:47
Proszę o sprawdzenie logów z audi A4. Kolega ma problemy z zapalającą się kontrolką silnika. Kasowałem błędy 2 tygodnie temu, a teraz problemy powróciły.
Jeśli nie ma możliwości sprawdzenia logów auta innej marki to proszę o usunięcie tematu
Logi:
Monday,14,April,2014,06:33:41:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E85A029049 Mileage: 187100km/116258miles
Address 01: Engine Labels: 06B-907-557-ALT.lbl
Part No SW: 8E0 909 557 H HW: 8E0 909 057 A
Component: 2.0L R4/5VS G 0002
Coding: 0011501
Shop #: WSC 63251 000 00000
VCID: 387536394848AA9
9 Faults Found:
16804 - Catalyst System; Bank 1
P0420 - 001 - Efficiency Below Threshold - MIL ON
17633 - Fuel Injector for Cylinder 1 (N30)
P1225 - 002 - Short to Ground - Intermittent
17635 - Fuel Injector for Cylinder 3 (N32)
P1227 - 002 - Short to Ground - Intermittent
17636 - Fuel Injector for Cylinder 4 (N33)
P1228 - 002 - Short to Ground - Intermittent
17634 - Fuel Injector for Cylinder 2 (N31)
P1226 - 002 - Short to Ground - Intermittent
17833 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground - Intermittent
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
P1117 - 002 - Short to Ground - Intermittent
17923 - Intake Manifold Valve (N156)
P1515 - 002 - Short to Ground - Intermittent
17949 - Fuel Pump Relay (J17)
P1541 - 004 - Open Circuit - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04275
Shop #: WSC 00011
VCID: E5CB2F4D7F7A671
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
37-10 - Faulty - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 63251
VCID: 63CFB155F14E991
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63251
VCID: 356B3F0D0F5A571
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
VCID: 3E7920216A6C949
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 04042
Shop #: WSC 63251
VCID: 3E7920213A6C949
Address 17: Instruments Labels: User\8E0-920-9xx-8E2.lbl
Part No: 8E0 920 931
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00001
Shop #: WSC 00006
WAUZZZ8E85A029049 AUZ6Z0D0267520
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BA
Component: Komfortgerát TA7 1512
Coding: 06976
Shop #: WSC 63251
VCID: 71E3CB1D3BB23B1
Subsystem 1 - Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 0205
Address 77: Telephone Labels: None
VCID: 55AB9F8DBF1A771
Note: Excessive Comm Errors
Monday,14,April,2014,06:48:58:32264
69 75 76 77
Coding: 0011501
Readiness: 0110 0101
Coding: 04275
Shop #: WSC 00011
2 Faults Found:
Coding: 00000
Shop #: WSC 63251
Coding: 00001
Shop #: WSC 63251
Coding: 0010602
Coding: 04042
Shop #: WSC 63251
Coding: 00001
Shop #: WSC 00006
Coding: 06976
Shop #: WSC 63251
Martwią logi ABSu. Nie da się ich wykasować...
Logi:
69 75 76 77
Coding: 0011501
9 Faults Found:
Coding: 04275
Shop #: WSC 00011
2 Faults Found:
Coding: 00000
Shop #: WSC 63251
Coding: 00001
Shop #: WSC 63251
Coding: 0010602
Coding: 04042
Shop #: WSC 63251
Coding: 00001
Shop #: WSC 00006
Coding: 06976
Shop #: WSC 63251
69 75 76 77
Coding: 0011501
Coding: 04275
Shop #: WSC 00011
2 Faults Found:
Coding: 00000
Shop #: WSC 63251
Coding: 00001
Shop #: WSC 63251
Coding: 0010602
Coding: 04042
Shop #: WSC 63251
Coding: 00001
Shop #: WSC 00006
Coding: 06976
Shop #: WSC 63251
