Prosze o pomoc - warto kupić z takimi błędami? logi z VCDS
: pt kwie 18, 2014 19:45
Jaki koszt napraw patrząc na logi tych 2 touranów, czy auta wartę są uwagi.
Moge gdzieś nieodpłatnie rozszyfrowac VIN aby sprawdzić wyposażenie aut?
Czyżby ten drugi touran miał cofnięty licznik?
PIERWSZY
Friday,18,April,2014,14:32:29:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVGZZZ1TZ5W175679 License Plate: MH
Mileage: 249710km-155162mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 47 52 56 62 72
VIN: WVGZZZ1TZ5W175679 Mileage: 249710km/155162miles
15-Airbags -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L EDC G000SG 6246
Revision: 12345678 Serial number: VWZ7Z0E1984166
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 67DD5D1756980F26359-8032
1 Fault Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
RPM: 882 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.60 V
Bin. Bits: 00001100
Temperature: 11.7°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Part No: 1K0 907 379 K
Coding: 0021190
Shop #: WSC 01150 210 64825
VCID: 3A7BD46375AA42CE9A7-806F
2 Faults Found:
01435 - Brake Pressure Sensor 1 (G201)
00810 - Sensor 1/2 for Brake Pressure
005 - No or Incorrect Basic Setting / Adaptation
Part No: 1K0 820 047 EF
Component: Climatic PQ35 084 0404
Shop #: WSC 00000 000 00000
VCID: 6CD7223B4F7E2C7E58B-8039
2 Faults Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
00898 - Control Circuit A/C compressor
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H37 0803
Revision: 00H37000 Serial number: 00000001743535
Coding: 00890F020004100000120C000000000000087B075C
VCID: 3979CB6F70AC49D693D-806C
Coding: 00065493
Shop #: WSC 00000
No fault code found.
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0CPL07
Coding: 0012338
VCID: 3561C75F5CB4ADB6775-8060
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000042
Part No: 1T0 920 961 AX
Component: KOMBIINSTRUMENT VDD 1014
Coding: 0003403
VCID: 8919FBAFE0CC195643D-80DC
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Coding: 0000011
VCID: 2A5BE423850AF24EEA7-807F
4 Faults Found:
01411 - Temperature Sensor (G18)
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 159
Reset counter: 83
Mileage: 248973 km
Time Indication: 0
Date: 2000.00.00
Time: 19:21:15
Malfunction
Temperature: 205.0°C
Temperature: 70.0°C
01409 - Repeated Flame-Out
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 14
Mileage: 246197 km
Time Indication: 0
Date: 2000.00.00
Time: 19:58:04
Malfunction
Temperature: 39.0°C
02251 - Heater Unit Locked
Fault Priority: 0
Fault Frequency: 1
Reset counter: 14
Mileage: 246197 km
Time Indication: 0
Date: 2000.00.00
Time: 19:58:04
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 20
Reset counter: 81
Mileage: 248877 km
Time Indication: 0
Date: 2000.00.00
Time: 29:36:36
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 290010540808DE
Coding: 3D3F1342078003
VCID: 29591B2F800CF956E3D-807C
Component: IMMO VDD 1014
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0158
Coding: 0000052
VCID: F4E7BA5B974E74BE00B-80A1
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.6 1502
VCID: 3169F34FA8DC81962BD-8064
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 01C802087F2D8505485FC61010CC
VCID: 79F90B6F302C89D6D3D-802C
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Shop #: WSC 00000
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 7 - Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1T0 035 456
Component: 08K Audioverst. 0003
Revision: 00001000 Serial number: 00000000000400
VCID: ECD7A23BCF7EAC7ED8B-80B9
Part No: 1T0 959 702
Coding: 0000052
VCID: F5E1875F9C346DB6375-80A0
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal
Part No: 1K0 035 195 A
Component: Radio BVX 006 0013
Coding: 0010010
VCID: 24470A1BE72E243ED0B-8071
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
VCID: 2F6DF537BEE897663D9-807A
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 306FF64BA3D6889E243-8065
DRUGI
Friday,18,April,2014,12:55:05:62939
VIN: WVGZZZ1TZ6W003178 License Plate: 05MH
Mileage: 280610km-174362mi Repair Order:
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ6W003178 Mileage: 280610km/174362miles
01-Engine -- Status: Malfunction 1010
Revision: 12345678 Serial number: VWZ7Z0E2155452
Coding: 0000072
6 Faults Found:
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 -
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00001100
Temperature: 60.3°C
(no units): 144.0
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
18051 - Please check DTC Memory of Electric Load Controller
P1643 - 000 -
RPM: 1554 /min
Torque: 34.0 Nm
Speed: 12.0 km/h
Load: 14.9 %
Voltage: 14.14 V
Bin. Bits: 00001100
Torque: 160.0 Nm
Bin. Bits: 0 00 0
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Revision: 00T12001
Coding: 0021190
VCID: 408FA68B1376181ED43-8015
1 Fault Found:
Part No: 1K0 820 047 DF
Component: Climatic PQ35 090 0505
VCID: 6BD521274A702B46511-803E
1 Fault Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000001918905
Coding: 00890F210004100000120C000000000000087B075C
Subsystem 1 - Part No: 2K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW357 012 0402
Coding: 00065493
Shop #: WSC 01324
3 Faults Found:
01505 - Bulb for Blinkers; Rear Right (M8)
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 278713 km
Time Indication: 0
ON
Voltage: 14.05 V
ON
ON
OFF
OFF
ON
00988 - Lamp for Brake Light; Right (M10)
Fault Priority: 1
Fault Frequency: 4
Reset counter: 171
Mileage: 279076 km
Time Indication: 0
ON
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
00985 - Right Tail Light (M2)
Fault Priority: 2
Fault Frequency: 3
Reset counter: 171
Mileage: 279085 km
Time Indication: 0
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
Revision: 09025000 Serial number: 0038BD0DCJMF
Coding: 0012338
1 Fault Found:
00532 - Supply Voltage B+
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
VCID: 76E300530132E6AEBEF-8023
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Part No: 1T0 920 962 A
Component: KOMBIINSTRUMENT VDD 1012
Coding: 0003401
Shop #: WSC 00630 210 88377
VCID: 326BFC43ADDABA8E527-8067
Coding: 0000011
5 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 255
Reset counter: 182
Mileage: 476612 km
Time Indication: 0
Date: 2000.00.00
Time: 23:13:16
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Malfunction
Temperature: 14.0°C
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Fault Status: 00101010
Fault Priority: 0
Fault Frequency: 19
Reset counter: 231
Mileage: 258589 km
Time Indication: 0
Date: 2000.00.00
Time: 08:15:55
OFF
Temperature: 158.0°C
Temperature: 17.0°C
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001055140FDF
Coding: 3D0F1340078003
1 Fault Found:
01314 - Engine Control Module
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 279032 km
Time Indication: 0
Date: 2000.00.00
Time: 09:39:31
Component: IMMO VDD 1012
Coding: 0000052
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 3365F94752C0B386591-8066
Component: KSG 0401
Coding: 00C802087F2D8405485BC61010CC
Shop #: WSC 12345 123 45725
Coding: 00000000
Shop #: WSC 00000
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
00893 - Switch for Trunk Handle (E234)
Coding: 0000052
1 Fault Found:
00936 - Electric Window Switch in Front Passenger Door (E107).
Part No: 1K0 035 186 P
Component: Radio BVX 016 0023
Coding: 0020200
-- Pt kwi 18, 2014 19:57 --
PIERWSZY
Coding: 0000072
1 Fault Found:
RPM: 882 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.60 V
Bin. Bits: 00001100
Temperature: 11.7°C
Bin. Bits: 10110000
Coding: 0021190
2 Faults Found:
2 Faults Found:
Coding: 00065493
Shop #: WSC 00000
Coding: 0012338
Coding: 0000042
Coding: 0003403
Coding: 0000011
4 Faults Found:
Fault Priority: 0
Reset counter: 83
Mileage: 248973 km
Time Indication: 0
Date: 2000.00.00
Time: 19:21:15
Malfunction
Temperature: 70.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 14
Mileage: 246197 km
Time Indication: 0
Date: 2000.00.00
Time: 19:58:04
Malfunction
Temperature: 39.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 14
Mileage: 246197 km
Time Indication: 0
Date: 2000.00.00
Time: 19:58:04
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 20
Reset counter: 81
Mileage: 248877 km
Time Indication: 0
Date: 2000.00.00
Time: 29:36:36
Coding: 0000052
Component: KSG 0401
Coding: 00000000
Shop #: WSC 00000
Coding: 0000052
2 Faults Found:
Coding: 0010010
Coding: 0000048
1 Fault Found:
Coding: 0000048
DRUGI
Coding: 0000072
6 Faults Found:
P1641 - 000 -
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00001100
Temperature: 60.3°C
(no units): 144.0
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
RPM: 924 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001111
Temperature: 15.3°C
Bin. Bits: 10110000
P1643 - 000 -
RPM: 1554 /min
Torque: 34.0 Nm
Speed: 12.0 km/h
Load: 14.9 %
Voltage: 14.14 V
Bin. Bits: 00001100
Torque: 160.0 Nm
Bin. Bits: 0 00 0
Revision: 00T12001
Coding: 0021190
1 Fault Found:
1 Fault Found:
Coding: 00065493
Shop #: WSC 01324
3 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 278713 km
Time Indication: 0
ON
Voltage: 14.05 V
ON
ON
OFF
OFF
ON
Fault Priority: 1
Fault Frequency: 4
Reset counter: 171
Mileage: 279076 km
Time Indication: 0
ON
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
Fault Priority: 2
Fault Frequency: 3
Reset counter: 171
Mileage: 279085 km
Time Indication: 0
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
Coding: 0012338
1 Fault Found:
Coding: 0000042
1 Fault Found:
Coding: 0003401
Coding: 0000011
5 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Reset counter: 182
Mileage: 476612 km
Time Indication: 0
Date: 2000.00.00
Time: 23:13:16
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Malfunction
Temperature: 14.0°C
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Fault Priority: 0
Reset counter: 188
Mileage: 477199 km
Time Indication: 0
Date: 2000.00.00
Time: 21:08:44
Fault Priority: 0
Fault Frequency: 19
Reset counter: 231
Mileage: 258589 km
Time Indication: 0
Date: 2000.00.00
Time: 08:15:55
OFF
Temperature: 17.0°C
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 279032 km
Time Indication: 0
Date: 2000.00.00
Time: 09:39:31
Coding: 0000052
Component: KSG 0401
Coding: 00000000
Shop #: WSC 00000
1 Fault Found:
Coding: 0000052
1 Fault Found:
Coding: 0020200
