Jestem świeżo po zakupie vcds 11.3 i pierwsze co zrobiłem to oczywiście scan. Oto lista błędów jakie mi wyskoczyły. Oczywiście próbuję własnymi siłami to rozszyfrować np. wiem że mam spaloną prawą postojówkę
Tuesday,08,May,2012,14:50:51:10074
VCDS Version: Beta 11.3.0
Data version: 20110801
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ4Wxxxxxx Mileage: 198920km/123603miles
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
Part No SW: 03G 906 016 A HW: 028 101 073 1
Component: R4 1,9L EDC G000SG 5185
Revision: 12345678 Serial number: VWZ7Z0C8562599
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 214DE1B784ED
4 Faults Found:
18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
P1951 - 000 - - - Intermittent
RPM: 1470 /min
Torque: 40.0 Nm
Speed: 31.0 km/h
Load: 14.9 %
Voltage: 14.06 V
Bin. Bits: 00001000
Temperature: 62.1°C
Duty Cycle: 25.1 %
18353 - Control Module 1 for Cooling Fan: Output Short Circuit
P1945 - 000 - - - Intermittent
RPM: 2394 /min
Torque: 34.0 Nm
Speed: 18.0 km/h
Load: 12.5 %
Voltage: 13.98 V
Bin. Bits: 00001000
Temperature: 79.2°C
Duty Cycle: 9.6 %
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 - 000 - -
RPM: 882 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00001111
Temperature: 16.2°C
Bin. Bits: 10110000
16785 - EGR System: Insufficient Flow
P0401 - 000 - - - Intermittent
RPM: 1281 /min
Torque: 32.0 Nm
Speed: 18.0 km/h
Load: 8.6 %
Duty Cycle: 14.7 %
Bin. Bits: 00001000
Mass Air / Rev.: 250.0 mg/str
Mass Air / Rev.: 385.0 mg/str
Readiness: 0 1 0 0 0
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 K HW: 1K0 937 049 K*
Component: Bordnetz-SG 1.0 H29 0701
Revision: 00029000 Serial number: 00000000296347
Coding: 00890F020004100000120C000000000000
Shop #: WSC 00000 000 00000
VCID: 37792FEF3A69
Subsystem 1 - Part No: 1T0 955 119 B
Component: Wischer WWS A-MPV 0201
Coding: 16711828
Shop #: WSC 00000
2 Faults Found:
02395 - Parking Light Right Front (M3)
Component: 05 AIRBAG VW62 0506 2112
Coding: 0012341
VCID: F2EF5EFB918B
1 Fault Found:
00532 - Supply Voltage B+
Part No: 1T0 920 860 G
Component: KOMBIINSTRUMENT VDD 3350
Coding: 0000001
Shop #: WSC 80093 222 69422
VCID: 356525E72065
1 Fault Found:
00003 - Control Module
014 - Defective
Part No: 1K0 815 071 E
Component: Zuheizer 0707
Revision: C Serial number: 09006207
Coding: 0000011
VCID: 2759FFAFEAC9
5 Faults Found:
02085 - Incorrect Control Module Installed
(no units): 118.4
Load: 10.3 %
Temperature: -262.4°C
Raw, Form. N/A: 000 003 046
Temperature: -1115.2°C
(no units): 0.0
Raw, Form. N/A: 000 000 000
00664 - Fuel gauge
Error Code: 1025
Text: 00.00.00
Clock: 11:04
01321 - Control Module for Airbags (J234)
Error Code: 1374
Text: 00.00.00
Clock: 13:35
014 - Defective - Intermittent
Error Code: 1374
Text: 00.00.00
Clock: 13:35
Ign. Timing: 4.3 °BTDC
Error Code: 1374
Text: 00.00.00
Clock: 13:35
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 E
Component: EPS_ZFLS Kl.0 1202
VCID: 2D550D87C835
1 Fault Found:
02441 - Yellow Malfunction Lamp in Instrument Cluster
013 - Check DTC Memory
Mileage: 0 km
Temperature: -70.0°C
Voltage: 0.00 V
Voltage: 0.00 V
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 05 0107
Coding: 0000048
VCID: 2F69178FC239
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
