KODY BLEDOW
Skrzyniu21
Imię:: Krzysztof
Podziękował: 11 razy
Otrzymał podziękowań: 15 razy
Re: KODY BLEDOW
Post autor: Skrzyniu21 »
Witam, proszę o analizę błędów auto to passat b6 2.0TDI dziś przestały świecić doświetlanie zakrętów i mruga kontrolka spalonej żarówki, nie idzie skasować błędów..
Sunday,05,February,2017,16:52:09:62939
VCDS Version: Release 12.12.0
Address 01: Engine Labels: 03G-906-021-BMM.clb
Control Module Part Number: 03G 906 021 NK HW: 03G 906 021 AB
Component and/or Version: R4 2,0L EDC G000SG 9354
Software Coding: 0000072
Work Shop Code: WSC 66565 257 00032
VCID: 75E1075F1C34EDB6B75-8020
1 Fault Found:
005748 - Powertrain Data Bus
P1674 - 000 - Implausible Message from Instrument Cluster - Intermittent
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 188767 km
Time Indication: 0
Date: 2017.01.16
Time: 14:22:30
RPM: 4179 /min
Speed: 92.0 km/h
Load: 65.9 %
Voltage: 14.36 V
Bin. Bits: 00001000
Torque: 263.5 Nm
Bin. Bits: 0 00 0
Readiness: 0 0 0 0 0
Sunday,05,February,2017,16:53:15:62939
Control Module Part Number: 3C0 937 049 AE HW: 3C0 937 049 AE
Component and/or Version: Bordnetz-SG H52 2002
Software Coding: E38A8F4701041A00470A00000F000000000B5D435C0001
Work Shop Code: WSC 49085 136 51158
Additional Info: 3C1955119B Wischer 031106 022 0601 1K0955559AH RLS 050609 054 0402
VCID: 6CD7223B4F7E2C7E58B-8039
1 Fault Found:
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 107
Mileage: 184634 km
Time Indication: 0
Date: 2016.12.09
Time: 11:40:00
OFF
Voltage: 12.50 V
OFF
ON
OFF
OFF
OFF
Sunday,05,February,2017,16:57:37:62939
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Control Module Part Number: 5M0 907 357 A HW: 5M0 907 357 A
Component and/or Version: AFS-Steuergeraet X014
Software Coding: 2301953
Work Shop Code: WSC 05311 000 00000
Additional Info: ID-L fehlt AFS-Lst.-Modul l .... 7L6941330 AFS-Lst.-Modul r X018
VCID: 326BFC43ADDABA8E527-8067
5 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 216
Reset counter: 107
Mileage: 188083 km
Time Indication: 0
Date: 2017.01.10
Time: 12:41:05
Voltage: 14.06 V
Speed: 33.8 km/h
ABS 1
01042 - Control Module; Not Coded
000 - - - MIL ON
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Invalid
Invalid
Invalid
Posiadam VCDS 12.12.
przemo86m
Auto:: AZV, 2.0 TDI 136 KM, 2004
Imię:: Przemek
Re: KODY BLEDOW
Post autor: przemo86m »
Witam, czy ktoś może na to rzucić okiem.
kolega jakiś czas temu miał czyszczone wtryski i podczas jazdy auto zaczęło się dławić aż zgasł, kilkukrotna próba odpalenia i nic tylko aku rozładował - auto nie odopala.
dodam że jest to Seat Altea 2.0 z 2006r.
Monday,20,February,2017,18:41:31:37412
VCDS Version: Release 11.11.0
Data version: 20111111
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 1010
46-Central Conv. -- Status: Sporadic communication error 1000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FH HW: 028 101 190 9
Component: R4 2,0L EDC G000SG 6185
Revision: 12345678 Serial number: SEZ7Z0D2614713
Coding: 0050072
Shop #: WSC 01286 386 08256
VCID: 6ED9BF1C798C1AE
2 Faults Found:
18104 - Powertrain Data Bus
P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
RPM: 0 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 11001100
Bin. Bits: 11000000
(no units): 1.0
16618 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition)
RPM: 2772 /min
Torque: 250.0 Nm
Speed: 88.0 km/h
Load: 53.7 %
Voltage: 14.29 V
Bin. Bits: 00101000
Absolute Pres.: 2121.6 mbar
Absolute Pres.: 2590.8 mbar
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 N
Component: ASR FRONT MK70 0103
Coding: 0017025
Shop #: WSC 06402 785 00200
VCID: 3D7B4850646AB16
No fault code found.
Part No: 5P0 907 044 B
Component: ClimatronicPQ35 004 0101
Shop #: WSC 00000 000 00000
VCID: 2F676218BE06536
3 Faults Found:
00709 - Sunlight Photosensor 2 (G134)
007 - Short to Ground
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - - - Intermittent
Part No SW: 1K0 937 049 L HW: 1K0 937 049 L*
Component: Bordnetz-SG 1.0 H29 0701
Revision: 00029000 Serial number: 00000001194270
Coding: 89880F2700041000001E00000000000000
VCID: 387559444B4894E
Subsystem 1 - Part No: 5P0 955 119 A Labels: 1KX-955-119.LBL
Component: Wischer SE359 012 0401
Coding: 00056272
Shop #: WSC 00000
4 Faults Found:
00483 - Control Module for Auxiliary Air Heater
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
01321 - Control Module for Airbags (J234)
01330 - Central Control Module for Central Convenience (J393)
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
Component: 0H AIRBAG VW8 022 0600
Revision: 05022000 Serial number: 0033JD0CVW8Z
Coding: 0012360
VCID: 2D5B7810B40A216
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0002042
VCID: 31636460A832456
Part No: XXXXXXXXXXX
Component: Lenkradmodul 005 0060
2 Faults Found:
00457 - Control Module for Network (J519)
01299 - Diagnostic Interface for Data Bus (J533)
Part No: 5P0 920 822 E
Component: KOMBIINSTRUMENT VO3 1054
Coding: 0000101
Shop #: WSC 80093 222 69422
1 Fault Found:
00003 - Control Module
014 - Defective
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 210010441503BB
Coding: 3D3F0B40078202
VCID: 27578A3896F60B6
6 Faults Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 3
Reset counter: 153
Mileage: 210179 km
Time Indication: 0
Date: 2000.00.00
Time: 12:54:42
Fault Priority: 2
Reset counter: 113
Mileage: 210179 km
Time Indication: 0
Date: 2000.00.00
Time: 12:55:50
Fault Status: 00100100
Fault Priority: 2
Reset counter: 153
Mileage: 210185 km
Time Indication: 0
Date: 2000.00.00
Time: 16:22:17
01305 - Databus for Infotainment
Fault Priority: 1
Reset counter: 113
Mileage: 210475 km
Time Indication: 0
Date: 2000.00.00
Time: 16:21:04
01304 - Radio
Fault Priority: 2
Reset counter: 113
Mileage: 210475 km
Time Indication: 0
Date: 2000.00.00
Time: 16:21:06
00474 - Control Module for Immobilizer
Fault Priority: 2
Fault Frequency: 53
Reset counter: 153
Time Indication: 0
Date: 2000.00.00
Time: 22:45:51
Component: IMMO 1054
1 Fault Found:
00381 - Databus Instrument Cluster
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
Part No: 1T0 959 701 A
Component: Tuersteuergeraet 09 0139
Coding: 0000016
VCID: 356B50705C5A696
2 Faults Found:
011 - Open Circuit
Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.13 1301
VCID: 2E597F1CB90C5AE
1 Fault Found:
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MIN.lbl
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 00C000BC090005050C4F0900
Shop #: WSC 21680 456 16984
VCID: 30656164A3384CE
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
Part No: 1T0 959 702 A
Coding: 0000016
VCID: 3669577C415C62E
2 Faults Found:
011 - Open Circuit
Address 56: Radio
Cannot be reached
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0206
Coding: 0000016
2 Faults Found:
011 - Open Circuit
Part No: 1K0 959 704 B
Coding: 0000016
2 Faults Found:
011 - Open Circuit
Address 7D: Aux. Heat
Cannot be reached
-- Pn lut 20, 2017 21:51 --
po auto skanie i zapisaniu błędów, skasowałem błędy i ponownie zrobiłem auto skan i wyszło to
wiele się nie zmieniło
01-Engine -- Status: OK 0000
_____________________________
LALA BY przemo86m - zobacz
PPD/ZWzPD
Re: KODY BLEDOW
... zacznij od sprawdzenia/podmiany modułu komfortu, wykasuj błedy i spróbuj odpalić ;) jesli odpali sprawdz turbo...
Mefju
Auto:: OCTAVIA III CKFC
Otrzymał podziękowań: 57 razy
Re: KODY BLEDOW
Post autor: Mefju »
w Golfie żony, po zimie zdechła klima, auto całą zimę garażowane itp, nigdy wcześniej nie miałem takiej sytuacji, żeby nawet klima nie ruszyła.
Wednesday,29,March,2017,14:32:57:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Control Module Part Number: 1K0 907 044 DD HW: 1K0 907 044 DD
Component and/or Version: ClimatronicPQ35 130 1213
Software Coding:
Work Shop Code: WSC 00000 000 00000
VCID: 6CDDDA694F90D69
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
ktoś coś??
Na kompresorze 6.0 bar, brak czynnika? Obrazek
Skoda Octavia III 2.0 TDI CKFC 2013
VW Golf V 1.9 TDI BXE 2008 Obrazek
Grzesiek3253
Auto:: Touran 1.9 TDI 2006 (BKC)
Imię:: Grzesiek
Otrzymał podziękowań: 19 razy
Re: KODY BLEDOW
Post autor: Grzesiek3253 »
witam
pomoże ktoś zlokalizować błąd ?
C0681
Gerardos
Auto:: Touran 1.6 mpi + LPG 2004
Imię:: Gerard
Podziękował: 56 razy
Otrzymał podziękowań: 67 razy
Re: KODY BLEDOW
Post autor: Gerardos »
:?: panowie podpowiedzcie co tu się dzieje : :?:
Sunday,30,April,2017,17:50:29:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WVGZZZ1TZ4W076583 License Plate:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ4W076583 Mileage: 182200km-113213miles
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 CG
Component: SIMOS71 1.6l 2VG 5359
Revision: 00000003 Serial number: VWZ7Z0C8491576
Coding: 0000071
Shop #: WSC 01324 785 00200
VCID: 66C3DCFE51A6E7723A-8032
2 Faults Found:
16784 - EGR System
P0400 - 008 - Malfunction
RPM: 0 /min
Voltage: 12.34 V
Load: 19.2 %
Load: 0.0 %
RPM: 0 /min
Voltage: 12.14 V
Load: 19.2 %
Load: 0.0 %
18358 - Radiator Fan (V7)
P1950 - 007 - Movement Restricted / Jammed - Intermittent
RPM: 928 /min
Temperature: 91.5°C
Temperature: 48.0°C
Speed: 1.0 km/h
Readiness: 0000 0000
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0019142
VCID: 3A7B588E759EB392AE-806E
Part No: 1K0 907 044 L
Component: ClimatronicPQ35 061 0201
VCID: 306F7AA6A3E279C210-8064
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 K HW: 1K0 937 049 K*
Revision: 00029000 Serial number: 00000000271342
Coding: 108F8F02000410002D120C000000000000
Shop #: WSC 12345 123 12345
VCID: 377D41BA468CAEFA51-8062
Coding: 00065493
Shop #: WSC 12345
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
Component: 05 AIRBAG VW62 0506 2112
Coding: 0012341
VCID: 72EBB0AE6D6E0BD2A6-8026
Component: Lenksäulenmodul 012 0030
Coding: 0000042
Part No: 1T0 920 872 F
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0007101
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 031007F1000420
Coding: E9801F060002028002
Component: IMMO VDD 4312
Component: Tuersteuergeraet 09 0111
Coding: 0000052
VCID: 74E7B6B6177A05E2B4-8020
Part No: 1K1 909 144 E
Component: EPS_ZFLS Kl.0 1202
VCID: 2D5163D2B4D0142A3B-8078
Component: KSG 0201
Coding: 18E802087F2D8404080B0100
Coding: 0000052
VCID: 75E18BB21C001CEA83-8020
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: RCD310 EU H04 5006
Revision: -----08S Serial number: VWZ4Z2N1194372
Coding: 01000400040009
Shop #: WSC 01357 011 00200
VCID: 72EBB0AEAD6E0BD2A6-8026
1 Fault Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 200
Mileage: 181374 km
Time Indication: 0
Date: 2000.00.00
Time: 13:26:26
End-------------------------(Elapsed Time: 01:17)--------------------------
Re: KODY BLEDOW
Standardowe bledy i problemy z egr i opornica wiatrakow nadmuchu na chlodnice. Wszystko do odszukania na forum.
Gerardos
Imię:: Gerard
Re: KODY BLEDOW
A co to takiego ?
Nie wiem czy dobrze wyczytałem , ale pod tymi kodami piszą coś o xenonach, a ja ich nie mam :shock:
Gerardos pisze:Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Coding: 00065493
Shop #: WSC 12345
1 Fault Found:
Re: KODY BLEDOW
W prawej lampie jakis problem ze swiatlem mijania byl kiedys tam. Zerknij na wsowki od zarowek i glowna wtyczke do lampy bo bywa ze ona ma tam zielono i to nie z zazdrosci. Wsowki warto podoginac. Ostatnio robilem w B6 i swiatla swiecily slabo bo wsowki sie grzaly.
Dexieco
Auto:: Touran, 1,9TDi, 2004
Re: KODY BLEDOW
Post autor: Dexieco »
Panowie podrzucę wam swój zrzut z VCDS-a, Pomoże ktoś to rozszyfrować ? Martwi mnie ten brake light switch.. często na autostradzie mi się to zapala i dupa z tempomatu i zapierdzielania xD
Wrzucam okrojone, tylko tam gdzie są błędy.
Kod: Zaznacz cały
VCDS Version: Release 15.7.1 (x64) Running on Windows 7 x64
Data version: 20150904
www.Ross-Tech.com
Diagnostyka
Monday,15,May,2017,16:16:45:05031
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
   Mileage: 287490km-178638miles
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 BT    HW: 028 101 176 1
   Component: R4 1,9L EDC G000SG  5644
   Revision: 12345678    Serial number: VWZ7Z0D9279534
   Coding: 0000072
   Shop #: WSC 00066 001 57865
   VCID: 76E47EF701D49A8E77-8022
2 Faults Found:
18049 - Please check DTC Memory of A/C Controller
            P1641 - 000 -
                    RPM: 882 /min
                    Torque: 28.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.60 V
                    Bin. Bits: 00001100
                    Temperature: 80.1°C
                    (no units): 0.0
16955 - Brake Switch (F)
            P0571 - 000 - Implausible Signal - Intermittent
                    RPM: 903 /min
                    Torque: 26.0 Nm
                    Speed: 23.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 00001110
                    Torque: 146.0 Nm
                    Bin. Bits:  0 01  0
   Part No: 1K0 907 044 K
   VCID: 2F6A8B93BE0EEB46F4-807A
1 Fault Found:
00819 - High Pressure Sensor (G65)
            009 - Open or Short to Ground
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000493872
   Coding: 01890F020004100000120C000000000000
   VCID: 3878B0CF4B402CFEA5-806C
   Subsystem 1 - Part No: 1T0 955 119 B  Labels: 1TX-955-119.CLB
   Component: Wischer WWS A-MPV   0201
   Coding: 16711828
   Shop #: WSC 12345
1 Fault Found:
00526 - Brake Light Switch (F)
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 1K0 815 071 F
   Component: Zuheizer        030 1009
   Revision:        B    Serial number: 09008374
   Coding: 0000011
   VCID: 2858608F9BE0BC7E35-807C
5 Faults Found:
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 36
                    Mileage: 287488 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:01:54
                        OFF
                    Temperature: 78.0°C
                    Temperature: 78.0°C
01406 - No Flame
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 13
                    Mileage: 225477 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:18:12
                        Start
                    Temperature: 39.0°C
                    Temperature: 38.0°C
00664 - Fuel gauge
                    Fault Status: 00100010
                    Fault Priority: 0
                    Reset counter: 71
                    Mileage: 287075 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:32:46
                    Fault Priority: 0
                    Reset counter: 71
                    Mileage: 287075 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:32:46
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 G
   Component: Radio BNO           0013
   Coding: 0040400
   Shop #: WSC 01324 785 00204
   VCID: 2A5C9A8785EC8E6E23-807E
1 Fault Found:
            014 - Defective
End-------------------------(Elapsed Time: 02:17)--------------------------
Skierniewice, VCDS 15.7.1, tomasz.klimek48@gmail.com
Re: KODY BLEDOW
... więc wymień czujnik stopu, manual na forum ;)
avisek
Auto:: 1T1 1.6FSI(BLP)
Imię:: Emil
Re: KODY BLEDOW
Post autor: avisek »
Witam, nie mogę ogarnąć dwóch błędów w moim Touranku.
Adres 01: Silnik Plik etykiet: 03C-906-056-BAG.lbl
Oznaczenie elementu: 03C 906 056 AM HW: Hardware No
Komponent i/lub wersja: MED9.5.10 G00 6097
Kodowanie: 0000072
VCID: 6ED9B52979C97168C30
2 - ilość znalezionych błędów. Oto one:
19490 - Czujnik 2 temperatury zasysanego powietrza (G299)
P3034 - 002 - sygnał za duży - MIL zapalona
17480 - Czujnik tlenków azotu (G295); sterowanie podgrzewaniem
P1072 - 008 - usterka el. w obwodzie - MIL zapalona
Co do pierwszego to nie mam już pomysłu. Wymieniony już był na nowy , nowa kostka, nowe przewody. Nie wiem gdzie szukać problemu.
Drugi myślę ,że kwestia sprawdzenia kabli przy Nox.
hermes802
Auto:: 2015 2.0 TDI
Re: KODY BLEDOW
Post autor: hermes802 »
pomoże ktos jak to naprawic . Kasowanie Vcds nic nie pomaga:(
01218 - Zapalnik bocznej poduszki powietrznej; strona pasażera (N200)
001 - Górna wartość skrajna przekroczona - MIL zapalona
01228 - Przełącznik wyłączania poduszki powietrznej pasażera (E224)
008 - Niezrozumiały sygnał - MIL zapalona
Kod: Zaznacz cały
MK&KM
[/i]
Kod: Zaznacz cały
[i]ZWzPD[/i]
[/i]
2.0 Cr 140KM
Re: KODY BLEDOW
Przecie wszystko masz napisane. Zapalnik bocznej poduszki ma defekt albo kabloteka do tej poduchy. To masz sprawdzic bo jest duza opornosc. To samo z wylacznikiem poduszki pasazera.
hermes802
Auto:: 2015 2.0 TDI
Re: KODY BLEDOW
Usterka wykasowana . Zobaczymy czy sie pojawia ponownie:)
Kod: Zaznacz cały
MK&KM
[/i]
Kod: Zaznacz cały
[i]ZWzPD[/i]
[/i]
2.0 Cr 140KM
