Błędy z Autoscanu
- Auto:: 5T 1,6 CRKB 2016
- Imię:: Staniaław
- Podziękował: 7 razy
oto moje wyniki pierwszego podłączenia kabelka
proszę o interpretacje
Thursday,11,July,2013,09:37:25:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 18 19 25 3D 42 44 46 52 56 62 72 76
77
VIN: WVGZZZ1TZ5W037214
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Sporadic communication error 1000
3D-Special Function -- Status: OK 0000
44-Steering Assist -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Part No: 1K0 820 047 CE
Component: Climatic PQ35 050 0303
Shop #: WSC 00000 000 00000
VCID: 69D3A37D4062C31
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K1 937 049 HW: 1K1 937 049 *
Component: Bordnetz-SG 1.0 H30 0201
Revision: 00H30000 Serial number: 00000000890364
Coding: 018B8F0000041000001200000000000000
VCID: EDDB576DF48A5F1
Coding: 00065493
Shop #: WSC 00000
4 Faults Found:
00380 - Special Vehicle Control Module (J608)
00985 - Right Tail Light (M2)
01519 - Bulb for Back-Up Lights; Right (M17)
Address 15: Airbags
Cannot be reached
Component: Lenksäulenmodul 012 0030
Coding: 0010042
Shop #: WSC 01324 785 00200
VCID: 30650E19A338729
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
015 - Cannot Be Tested at this Time - MIL ON
Address 17: Instruments
Cannot be reached
Part No: 1K0 815 007 BG
Component: Standheizer 021 3803
Revision: 00021000 Serial number: 09011559000000
Coding: 0001112
Shop #: WSC 34614 142 86913
VCID: 6AD1DC714564C89
4 Faults Found:
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
01410 - Heater Over-Temp
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 148.0°C
Temperature: 32.0°C
02251 - Heater Unit Locked
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 26001047220566
Coding: 3F3F17C1078002
VCID: 2757E54596F6351
1 Fault Found:
00474 - Control Module for Immobilizer
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 175
Time Indication: 0
Date: 2000.00.00
Time: 13:38:35
Part No: 1T0 920 871 A
Component: IMMO VDD 0812
Shop #: WSC 01942 161 63991
VCID: 31630B1DA8327B1
Address 3D: Special Function Labels: None
Part No SW: 1T0 907 427 HW: 1T0 907 427
Component: MFG 010 X411
Revision: M0010000 Serial number: 00000000001652
Coding: 0101010101
Shop #: WSC 40380 123 17214
VCID: F2E14411EDB4809
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 02 Einparkhilfe 0101
VCID: 2D5B176DB40A1F1
2 Faults Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
009 - Open or Short to Ground
006 - Short to Plus
Address 77: Telephone
Cannot be reached
a to po skasowaniu błędów
Thursday,11,July,2013,09:48:01:32264
Chassis Type: 1K0
77
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 00065493
Shop #: WSC 00000
Address 15: Airbags
Cannot be reached
Coding: 0010042
Cannot be reached
Coding: 0001112
4 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 32.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Coding: 0101010101
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Chassis Type: 1K0
77
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 00065493
Shop #: WSC 00000
4 Faults Found:
Address 15: Airbags
Cannot be reached
Coding: 0010042
1 Fault Found:
Cannot be reached
Coding: 0001112
4 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 32.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 175
Time Indication: 0
Date: 2000.00.00
Time: 13:38:35
Coding: 0101010101
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
2 Faults Found:
006 - Short to Plus
Cannot be reached
Chassis Type: 1K0
77
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 00065493
Shop #: WSC 00000
Address 15: Airbags
Cannot be reached
Coding: 0010042
Cannot be reached
Coding: 0001112
4 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 32.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Coding: 0101010101
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
- Imię:: Staniaław
kabelek od naszego specjalisty w tym temacie na forum
przebieg 336...
ale może coś jeszcze robię nie tak bo to moje pierwsze podłączenie
może to dlatego że stacyjka nie była w pozycji zapłon ale miałem już słabą baterie w laptopie i dlatego nie próbowałem dalej
popróbuje jeszcze później a na razie proszę o pierwsze uwagi
przebieg 336...
- Imię:: Staniaław
ej panowie
proszę o wyrozumiałość ja dopiero zaczynam
a poza tym na swoje usprawiedliwienie powiem że w instrukcji wyczytałem :
"Uwaga: Podłączając kabel styku OBD w samochodzie należy pamiętać o tym, iż szyna CAN i ECU
otrzymują zasilanie dopiero, gdy kluczyk jest przekręcony na pozycji zaraz przed zapłonem. Jeżeli
nie spełnimy tego warunku to kabel i oprogramowanie zgłoszą brak dostępu do szyny CAN. Zawsze
po podłączeniu można zrobić sobie TEST (zakładka Options) aby sprawdzić czy wszystkie linie
działają poprawnie (bez zapamiętywania SAVE za każdym razem)."
no i vcds miał połączenie wiec myślałem że tak jest ok
ponowie autoscan wieczorkiem
- Imię:: Staniaław
a to aktualne skany
Chassis Type: 1K0
77
VIN: WVGZZZ1TZ5W037214 Mileage: 335570km/208513miles
02-Auto Trans -- Status: Malfunction 0010
Part No SW: 03G 906 016 DK HW: 028 101 194 6
Component: R4 1,9L EDC G000AG 6247
Revision: 12345678 Serial number: VWZ7Z0D0318158
Coding: 0000078
Shop #: WSC 34614 142 09746
VCID: 6FE7CD657E862D1
4 Faults Found:
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
RPM: 2331 /min
Torque: 188.0 Nm
Speed: 47.0 km/h
Load: 60.0 %
Voltage: 14.21 V
Bin. Bits: 00001000
Absolute Pres.: 2029.8 mbar
Absolute Pres.: 1152.6 mbar
16785 - EGR System
P0401 - 000 - Insufficient Flow - Intermittent
RPM: 1407 /min
Torque: 36.0 Nm
Speed: 65.0 km/h
Load: 11.8 %
Duty Cycle: 14.7 %
Bin. Bits: 00001000
Mass Air / Rev.: 260.0 mg/str
Mass Air / Rev.: 615.0 mg/str
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 000 - Signal too High - Intermittent
RPM: 798 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00001100
Temperature: 45.9°C
Temperature: 31.5°C
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Bin. Bits: 00001000
Bin. Bits: 11000000
(no units): 1.0
Readiness: 1 3 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 R HW: 02E 927 770 AD
Component: GSG DSG 041 0812
Revision: 00004010 Serial number: 00000407220488
Coding: 0000020
VCID: 2143FB5DF8D2CB1
3 Faults Found:
17100 - Transmission Input Speed Sensor (G182)
P0716 - 000 - Implausible Signal - Intermittent
18149 - Clutch Pressure Adaptation
P1741 - 001 - Limit Reached - Intermittent
P1741 - 002 - Limit Reached - Intermittent
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021190
VCID: 3A712C317544B89
Coding: 00065493
Shop #: WSC 00000
4 Faults Found:
Part No SW: 1T0 909 605 B HW: 1T0 909 605 B
Component: 02 AIRBAG VW62 0506 1400
Revision: 07023000 Serial number: 0037SD08HW8U
Coding: 0012338
VCID: 346D020957204E9
1 Fault Found:
00532 - Supply Voltage B+
Coding: 0010042
Component: KOMBIINSTRUMENT VDD 0812
Coding: 0007103
Shop #: WSC 00012 000 00000
Coding: 0001112
4 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 32.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Coding: 0101010101
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0157
Coding: 0000116
VCID: F4ED420997A08E9
2 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00120 - Outside Warning Light/Door exit Light Driver Side
Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.6 1401
VCID: 2F670D65BE066D1
Address 46: Central Conv. Labels: 1K0-959-433-MIN.lbl
Part No SW: 1K0 959 433 J HW: 1K0 959 433 J
Component: 01 KSG PQ35 G2 031 0308
Revision: 00031000 Serial number: 00000000000000
Coding: 80E802087F2D8404084F016001
VCID: 377735054656A51
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Part No: 1T0 959 702
Coding: 0000116
VCID: F5EB7F0D9CDA971
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
Part No: 1K0 035 186 P
Component: Radio BVX 016 0023
Coding: 0010400
VCID: 336F0115522E491
3 Faults Found:
01042 - Control Module; Not Coded
000 - -
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
Part No: 1K0 959 704 B
Coding: 0000048
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
1 Fault Found:
Address 77: Telephone Labels: 1K0-035-729-UNI.lbl
Part No: 1K0 035 729 E
Component: CIB PAH HW 202 SW 0308
Coding: 0000364
VCID: 2B5F19758A1E111
a to po kasowaniu i paru km
Chassis Type: 1K0
77
02-Auto Trans -- Status: OK 0000
15-Airbags -- Status: OK 0000
Coding: 0000078
1 Fault Found:
RPM: 2457 /min
Torque: 164.0 Nm
Speed: 49.0 km/h
Load: 54.9 %
Voltage: 14.21 V
Bin. Bits: 00001000
Absolute Pres.: 1938.0 mbar
Absolute Pres.: 1081.2 mbar
Readiness: 0 0 0 0 0
Coding: 0000020
Coding: 0021190
Coding: 00065493
Shop #: WSC 00000
4 Faults Found:
Coding: 0012338
Coding: 0010042
Coding: 0007103
Coding: 0001112
4 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 32.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Coding: 0101010101
Coding: 0000116
1 Fault Found:
Coding: 0000116
Coding: 0010400
3 Faults Found:
000 - -
011 - Open Circuit
011 - Open Circuit
Coding: 0000048
Coding: 0000048
1 Fault Found:
Coding: 0000364
i moje komentarze
-turbina (nieszczelna rura intecollera) zauważyłem podczas dzisiejszej wymiany oleju w dsg czy to może być to?
-egr błąd nie wrócił ale pewnie zaraz się pojawi bo egr jest totalnie zasyfiony
-ogrzewanie postojowe uwagi mile widziane ale w tej chwili to nie jest najważniejsze
-o co chodzi z tym radiem?
-czujki parkowania która to prawa zewnętrzna czy wewnętrzna
dzięki marynarz75 ale mam nową zabawkę i chciałbym się na razie sam pobawić przecież to właśnie najlepszy sposób nauki
ale oczywiście pomoc kolegów będzie wskazana jeśli będzie niezbędna
Chassis Type: 1K0
77
Coding: 0000078
4 Faults Found:
RPM: 2331 /min
Torque: 188.0 Nm
Speed: 47.0 km/h
Load: 60.0 %
Voltage: 14.21 V
Bin. Bits: 00001000
16785 - EGR System
RPM: 1407 /min
Torque: 36.0 Nm
Speed: 65.0 km/h
Load: 11.8 %
Duty Cycle: 14.7 %
Bin. Bits: 00001000
RPM: 798 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00001100
Temperature: 45.9°C
Temperature: 31.5°C
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Bin. Bits: 00001000
Bin. Bits: 11000000
(no units): 1.0
Coding: 0000020
3 Faults Found:
Coding: 0021190
Coding: 00065493
Shop #: WSC 00000
4 Faults Found:
Coding: 0012338
1 Fault Found:
Coding: 0010042
Coding: 0007103
Coding: 0001112
4 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 32.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Coding: 0101010101
Coding: 0000116
2 Faults Found:
Coding: 0000116
1 Fault Found:
Coding: 0010400
3 Faults Found:
000 - -
011 - Open Circuit
011 - Open Circuit
Coding: 0000048
1 Fault Found:
Coding: 0000048
1 Fault Found:
1 Fault Found:
Coding: 0000364
Chassis Type: 1K0
77
Coding: 0000078
1 Fault Found:
RPM: 2457 /min
Torque: 164.0 Nm
Speed: 49.0 km/h
Load: 54.9 %
Voltage: 14.21 V
Bin. Bits: 00001000
Coding: 0000020
Coding: 0021190
Coding: 00065493
Shop #: WSC 00000
4 Faults Found:
Coding: 0012338
Coding: 0010042
Coding: 0007103
Coding: 0001112
4 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 37
Reset counter: 165
Mileage: 333824 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:36
01406 - No Flame
Fault Priority: 0
Fault Frequency: 1
Reset counter: 136
Mileage: 334143 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:29
Start
Temperature: 71.0°C
Temperature: 45.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:03
After-Run
Temperature: 32.0°C
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 129
Mileage: 334697 km
Time Indication: 0
Date: 2000.00.00
Time: 07:48:47
Coding: 0101010101
Coding: 0000116
1 Fault Found:
Coding: 0000116
Coding: 0010400
3 Faults Found:
000 - -
011 - Open Circuit
011 - Open Circuit
Coding: 0000048
Coding: 0000048
1 Fault Found:
Coding: 0000364
i moje komentarze
- Cesarz
- Imię:: Michał
- Podziękował: 629 razy
spokojnie, nikt Ci jej nie zabierzestach pisze: ale mam nową zabawkę i chciałbym się na razie sam pobawić
[ Dodano: Czw Lip 11, 2013 20:28 ]
a moze raczej srodkowo - prawa?stach pisze:-czujki parkowania która to prawa zewnętrzna czy wewnętrzna
[ Dodano: Czw Lip 11, 2013 20:31 ]
co do webasto to: http://touranklub.pl/forum/viewtopic.ph ... ht=webasto
