OPS 8K - przód i tył - montaż
msg90a1
- Auto:: Tiguan
- Imię:: Wiktor
Re: OPS 8K - przód i tył - montaż
Chassis Type: AX (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 2E 37 42 44 46 47 4C
4F 52 53 56 62 72 75 77
VIN: WVGAV3AX7EW542795 Mileage: 23310km-14484miles
05-Acc/Start Auth. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
2B-Steer. Col. Lock -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 997 027 N HW: 06J 907 309 A
Component: MED17.5.2 TFSI 2 06 0397
Revision: P3H07--- Serial number:
Coding: 0423010A19070160
Shop #: WSC 13903 001 1048576
VCID: 4088D82F1390643E1D-8014
1 Fault Found:
001378 - System Voltage
P0562 - 000 - Too Low - Intermittent
Readiness: 0000 0100
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 NK HW: 09G 927 750 NK
Component: AQ 250 6F 2253
Coding: 0000840
Shop #: WSC 01357 011 00200
VCID: 071A0333763E93061C-8052
Subsystem 1 - Part No: 09G 927 750 NK
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BD HW: 5N0 614 109 BD
Component: J104 C6 450M VD01 0011
Coding: 0005158
VCID: 6ED456977984A24EBF-803A
No Faults Found
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0194517112
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G.rod
VCID: 346084FF9F28C89E89-8060
2 Faults Found:
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
65813 - Supply voltage
U1011 00 [008] - Voltage too Low
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3AA 907 044 BH HW: 3AA 907 044 BH
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 0010019002
ASAM Dataset: EV_Clmiatronic A01010
ROD: N/A
VCID: 77FA73F3CEDEE3866C-8022
No ASAM data for: "EV_Clmiatronic" (VW36 *)
2 Faults Found:
13635840 - ROD - Unknown Error Code
- 00 [008]
9672448 - ROD - Unknown Error Code
- 00 [008]
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 R HW: 5K0 937 086 R
Component: BCM PQ35 M 122 0173
Revision: BJ122001
Coding: EF180A1B80232EC401880041100085444801AC86564D8DF064800000A040
VCID: 4382D723C2867F2600-8016
Subsystem 1 - Part No SW: 5N1 955 119 B HW: 5N1 955 119 B
Component: WWS316 040913 24 0664
Coding: 009795
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
00532 - Supply Voltage B+
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 AD HW: 5N0 959 655 AD
Component: J234__207 VW10 HI 2318
Revision: 27019000 Serial number: 003N4PKUZWDD
Coding: 0012343
VCID: 7F0A9BD32EEEDBC624-802A
Subsystem 1 - Part No: 5N0 959 339 B
Component: BF-Gewichtsens. 003 0001
Subsystem 2 - Serial number: 0000000000DXLU
Subsystem 3 - Serial number: 0026.06.130000300000650073˙†63
Subsystem 4 - Serial number: 650073˙†6332MTS622302643Z˙†63
Subsystem 5 - Serial number: 02643Z˙†6342MTS644772483A˙†63
Subsystem 6 - Serial number: 72483A˙†6351HTS6I7HRBCKRJ˙†63
Subsystem 7 - Serial number: RBCKRJ˙†6361HTS63V0HLDKJ5˙†63
Subsystem 8 - Serial number: HLDKJ5˙†63727TS648S0BCKRQ˙†63
Subsystem 9 - Serial number: 0BCKRQ˙†63827TS690958CKJ%˙
Subsystem 10 - Serial number: 58CKJ%˙
No fault code found.
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 BL HW: 5K0 953 569 L
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130925200460
Coding: 110A140000
VCID: 75E679FBD4D291967E-8020
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 820000
2 Faults Found:
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
136194 - Supply voltage
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5N0 920 973 E HW: 5N0 920 973 E
Component: KOMBI H04 0811
Serial number: 00000000000000
Coding: 211F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3664BEF78954DA8EB7-8062
2 Faults Found:
12671232 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
13635840 - Supply voltage
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 240913F1000390
Coding: 756002
VCID: 7BF26FC3FAF6C7E608-802E
1 Fault Found:
03075 - Parallel Parking Assistance Control Module (J791)
004 - No Signal/Communication
Component: IMMO H04 0811
Coding: 000007
ASAM Dataset: EV_Immo_UDSV_DD_RM09 A03710
ROD: N/A
VCID: 6ADC5A878D6C4E6EE3-803E
No ASAM data for: "EV_Immo_UDSV_DD_RM09" (VW36 *)
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000207562003
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPV3W6X A01001
ROD: N/A
VCID: 306888EF6B30F4BEED-8064
No ASAM data for: "EV_ELVMarquMPV3W6X" (VW36)
9 Faults Found:
- 00 [008]
13893888 - ROD - Unknown Error Code
- 00 [008]
13893632 - ROD - Unknown Error Code
- 00 [008]
1049345 - ROD - Unknown Error Code
- 00 [008]
12664832 - ROD - Unknown Error Code
- 00 [008]
12665089 - ROD - Unknown Error Code
- 00 [008]
12666368 - ROD - Unknown Error Code
- 00 [008]
12666369 - ROD - Unknown Error Code
- 00 [008]
12666372 - ROD - Unknown Error Code
- 00 [008]
Address 2E: Media Player 3
Cannot be reached
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 F HW: 1K0 035 274 F
Component: RNS315-NAR H73 0409
Serial number: VWZAZ2N0523287
Coding: 0409006101000C0000008000
ASAM Dataset: EV_RNS315NRAV2UDS 001705
ROD: N/A
VCID: 275A63B35EFEB3063C-8072
Subsystem 1 - Part No: 3AA 919 866 A
Component: EUR_E_V8 0069
No ASAM data for: "EV_RNS315NRAV2UDS" (VW36 *)
2 Faults Found:
1048661 - ROD - Unknown Error Code
- 00 [009]
1048669 - ROD - Unknown Error Code
- 00 [009]
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 701 F HW: 3C0 959 793 B
Component: TUER-SG FT 002 0503
Revision: 13110009 Serial number: 0007511334
Coding: 0004B4
ASAM Dataset: EV_TSGFPQ35RBFVW46X A04001
ROD: N/A
VCID: 3878B0CF83402CFEA5-806C
Subsystem 1 - Part No SW: 5N0 959 703 G HW: 3C0 959 794 D
Component: J388__TSG-HL 009 1504
Serial number: 00000008192982
Coding: 000490
No ASAM data for: "EV_TSGFPQ35RBFVW46X" (VW36)
7 Faults Found:
65538 - ROD - Unknown Error Code
- 00 [008]
66048 - ROD - Unknown Error Code
- 00 [009]
68098 - ROD - Unknown Error Code
- 00 [008]
68100 - ROD - Unknown Error Code
- 00 [008]
65793 - ROD - Unknown Error Code
- 00 [008]
131329 - ROD - Unknown Error Code
- 00 [008]
131584 - ROD - Unknown Error Code
- 00 [008]
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
Component: J500__APA-BS KL.285 1401
Revision: 1BH04841 Serial number: 00132620051601
Coding: 0000258
VCID: 418EDD2B189A6D3612-8014
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0085584
ASAM Dataset: EV_AudioVerst01KanalSTT3 S01001
ROD: N/A
VCID: 26446EB759F4AA0E07-8072
No ASAM data for: "EV_AudioVerst01KanalSTT3" (VW36)
3 Faults Found:
9636883 - ROD - Unknown Error Code
- 00 [008]
9637139 - ROD - Unknown Error Code
- 00 [008]
- 00 [008]
Address 4C: Tire Pressure II
Cannot be reached
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 050B0500
VCID: 6FEA4B93BE8EAB46B4-803A
Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 2 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 702 F HW: 3C0 959 792 B
Component: TUER-SG BT 002 0503
Revision: 15110009 Serial number: 0007523610
Coding: 0004B4
ASAM Dataset: EV_TSGPBQ35BRFVW46X A04001
ROD: N/A
VCID: 397EB5CBB84A35F65A-806C
Subsystem 1 - Part No SW: 5N0 959 704 G HW: 3C0 959 795 D
Component: J389__TSG-HR 009 1504
Serial number: 00000008165557
Coding: 000490
No ASAM data for: "EV_TSGPBQ35BRFVW46X" (VW36)
8 Faults Found:
- 00 [008]
- 00 [008]
67330 - ROD - Unknown Error Code
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Coding: 0026156
VCID: 3664BEF74154DA8EB7-8062
Address 75: Telematics (J949) Labels: None
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0086
Serial number: 000003554140510
Coding: 02130602C2423A107F1606000000
ASAM Dataset: EV_OCULow 001010
ROD: EV_OCULow.rod
VCID: 53A2E7633AE6EFA6B0-8006
5 Faults Found:
0035 - Databus
U1121 00 [008] - Missing Message
13893888 - Function Restricted due to Exessive Voltage
U1401 00 [008] - -
9458451 - Cellular Antenna
B1053 13 [008] - Open Circuit
2103041 - Control Module
B1788 F0 [009] - Start Prohibition Deactivated
Address 77: Telephone (J412) Labels: 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007665315187
Coding: 0A100300A0010110
ASAM Dataset: EV_UHVMUI 001007
ROD: N/A
VCID: 2E5496977104E24EFF-807A
No ASAM data for: "EV_UHVMUI" (VW36 *)
3 Faults Found:
9457664 - ROD - Unknown Error Code
- 00 [008]
- 00 [008]
- 00 [008]
End-------------------------(Elapsed Time: 04:52)--------------------------
1 Fault Found:
Coding: 0000840
No Faults Found
Coding: 0005158
No Faults Found
Coding: 030C0C
2 Faults Found:
U1400 00 [008] - -
Revision: 00001K01
Coding: 0010019002
ROD: N/A
2 Faults Found:
- 00 [008]
- 00 [008]
Revision: BJ122001
Coding: 009795
2 Faults Found:
Cannot be reached
Coding: 0012343
Coding: 110A140000
Coding: 820000
2 Faults Found:
U1400 00 [008] - -
Coding: 211F01
2 Faults Found:
U1111 00 [009] - -
Coding: 756002
1 Fault Found:
Coding: 000007
ROD: N/A
ROD: N/A
9 Faults Found:
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
Cannot be reached
ROD: N/A
2 Faults Found:
- 00 [009]
- 00 [009]
Coding: 0004B4
ROD: N/A
Coding: 000490
7 Faults Found:
- 00 [008]
- 00 [009]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
Coding: 0000258
ROD: N/A
3 Faults Found:
- 00 [008]
- 00 [008]
- 00 [008]
Cannot be reached
Coding: 050B0500
Coding: 0004B4
ROD: N/A
Coding: 000490
8 Faults Found:
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
- 00 [008]
Coding: 0026156
ROD: EV_OCULow.rod
5 Faults Found:
0035 - Databus
U1401 00 [008] - -
ROD: N/A
3 Faults Found:
- 00 [008]
- 00 [008]
- 00 [008]
- yox
- Podziękował: 240 razy
... sprawdż podłączenie zasilania, albo sterownik uwalonymsg90a1 pisze:Address 10: Park/Steer Assist
Cannot be reached
msg90a1
- Auto:: Tiguan
- Imię:: Wiktor
yox pisze:... sprawdż podłączenie zasilania, albo sterownik uwalonymsg90a1 pisze:Address 10: Park/Steer Assist
Cannot be reached
sprawdziłęm jeszcze raz zasilanie jest po stacyjce, masa jest, podłączenie z can jest chodź wykazuje jakieś opory ale równo na jednym i drugim kablu (0,5mm2)
serwis mówi 650zł za sterownik
marcopollo
- Auto:: passat b7
- Imię:: marek
Witam. dokładam PDC z OPS przód i tył do Touran 2009 2,0 tdi 140KM Automat z Navi i hak oraz Vebasto. zestaw zakupiłem z pewnej firmy z Gorzowa Wielkopolskiego i utknąłem z podłączeniem dwóch kabelków do Gateway. Może ktoś mi podpowiedzieć na jakie piny się wpiąć bo nie chcę nic usmażyć. Wydłubałem wtyczkę z Gateway-a i piny zajęte to 1,5,6,8,9,10,11,13,14,15,16,18,19,20. gdzieś na forum znalazłem rozpiskę pinów z Gateway i na mój rozum muszę się wpiąć na Pin 6 Can Low i Pin 16 Can High. Dobrze myślę? z góry dziękuję za wszelkie informacje. Pozdrawiam.
- jeżu
- Auto:: PB8
- Podziękował: 215 razy
- Otrzymał podziękowań: 679 razy
Tak dokładnie... w gateway Can L - pin 6 i Can H - pin 16
Sterownik PDC podpinasz pod magistralę Can napędu..
- m0nter
- Auto:: Touran BMN 2007
- Podziękował: 31 razy
Może nie typowy montaż, ale ustawienia
Czy da radę ustawić tak OPS, żeby jak w nowych VAGach, pracował w tle przy małych prędkościach?
Wiem, że można z przycisku sobie uruchomić u nas. W Octavii III fajnie to działa jak się manewruje na parkingu/wjeżdża w bramki na autostradzie, to z automatu przy zbliżaniu się do przeszkody pokazuje się obraz auta i odległość (ale dopiero po "złapaniu" przeszkody przez czujnik).
- yox
. musisz wymienić modułm0nter pisze:Może nie typowy montaż, ale ustawienia
- m0nter
żeby to tylko moduł był... mam maglownicę 1K1909144M, nie uśmiecha mi się jej wymieniać
Zostanę przy tym co mam
w końcu to tylko daily żony, a ja mam dwie inne zabawki
- yox
.. na tym maglu też ci pójdzie, kolega jeżu ma identyczny, ale 'pumpe' ABS musiałbyś wymienic na MK60-EC1m0nter pisze:żeby to tylko moduł był... mam maglownicę 1K1909144M, nie uśmiecha mi się jej wymieniać
Zostanę przy tym co mamw końcu to tylko daily żony, a ja mam dwie inne zabawki
wnyku
- Auto:: 1T2
- Imię:: Rav
mam RNS 510 1T0 035 680A
HW: H04 SW 1020
parktronic tył i przód + park assist
Czy po wymianie modułu i długim kodowaniu w radiu będzie mi się wyświetlało OPS czy coś jeszcze będę musiał wymienić?
HW: H04 SW 1020
- m0nter
Poczytałbyś tematy na forum i byś wiedział
Będzie się wyświetlać OPS. Jestem po podobnym "zabiegu"
- soil
- Auto:: Touran 09 1.4 TSI BMY DSG
- Imię:: Dawid
poszukuje schematu/rozpiski pinów wtyczki (od strony silnika, wtyczka nr 6X0973717) do wiązki 1T0971095AG (czyli: pdc/ops, halogeny, czujnik temp) - posiada ktoś?
adzi
- Auto:: Touran 2005 2.0 tdi dsg
- Imię:: Andrzej
Witam wszystkich, czy mógłby mi ktoś trochę rozjaśnić jak to jest z tymi czujnikami? Planuje montaż ops przód i tył i nie wiem jakie czujniki szukać, na początku chce założyć moduł 1T0 z końcówką C i wiem że do niego odpowiednie są czujniki 3C0 z końcówką S, docelowo chcę założyć pla 2.0 i moduł 3AA do którego są nowsze czujniki i teraz rodzi się pytanie, czy ten pierwszy moduł obsłuży te "nowsze" czujniki typu 4H0 lub 1S0 i na odwrót czy ten nowszy moduł obsłuży te"starsze". Wiem że dla niektórych pytanie może być banalne, ale wolę się upewnić, żeby nie kupować dwa razy.
miki55
- Auto:: 1.9 bls
- Imię:: Rafał
- Podziękował: 19 razy
Ja miałem założony 3AE919475 na 8 czujek i spisywał się idealnie. czujki miałem z końc. S. Po wymianie na PLA wszystko śmiga oczywiście po dołożeniu bocznych czujników 1T0 919 297 A z przodu i tych z S na tyle. A i jeszcze nowe czujniki ABS z tyłu.
