: czw kwie 26, 2012 19:01
robiłem scan dzis , wyszły mi błędy które się powtarzają, na swoje potrzeby przetłumaczyłem je sobie ale jakby ktoś mądrzejszy na to rzucił okiem, będę wdzięczny:
Thursday,26,April,2012,18:15:40:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ4W152738 Mileage: 229190km/142412miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
Part No SW: 03G 906 016 BT HW: 028 101 176 1
Component: R4 1,9L EDC G010SG 7210
Revision: 12345678 Serial number: VWZ7Z0D9517412
Coding: 0000072
Shop #: WSC 00330 259 09948
VCID: 76E7E2EB7A07
No fault code found.
Readiness: 0 0 0 0 0
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021190
Shop #: WSC 01324 785 00200
VCID: 3A7F36DB0E9F
Part No: 1K0 907 044 K
Component: ClimatronicPQ35 061 0201
Shop #: WSC 00000 000 00000
VCID: 2F69178FC5DD
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000650392
Coding: 01890F020004200000120C000000000000
VCID: 408B44336843
Subsystem 1 - Part No: 1T0 955 119 C
Coding: 00065493
Shop #: WSC 00000
1 Fault Found:
Component: 05 AIRBAG VW62 0506 2112
Coding: 0012341
VCID: F2EF5EFB966F
Component: Lenksäulenmodul 012 0030
Coding: 0000042
VCID: 306B14F3D8E3
Part No: 1T0 920 860 G
Component: KOMBIINSTRUMENT VDD 3354
Coding: 0003101
Shop #: WSC 00266 266 08014
VCID: 356525E72781
Part No: 1K0 815 071 P
Component: Zuheizer 031 1312
Coding: 0000112
VCID: 326F1EFBD6EF
5 Faults Found:
02456 - Line Filling
005 - No or Incorrect Basic Setting / Adaptation
02251 - Heater Unit Locked
000 - - - Intermittent
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 26
Reset counter: 35
Mileage: 227441 km
Time Indication: 0
Date: 2000.00.00
Time: 25:45:00
02085 - Incorrect Control Module Installed
Fault Priority: 0
Fault Frequency: 26
Reset counter: 35
Mileage: 227441 km
Time Indication: 0
Date: 2000.00.00
Time: 25:45:00
01408 - Under-Voltage Shut-Off (fixed Value)
Fault Status: 00100000
Fault Priority: 0
Reset counter: 108
Mileage: 228780 km
Time Indication: 0
Date: 2000.00.00
Time: 23:39:19
Malfunction
Temperature: 40.0°C
Temperature: 49.0°C
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 26001043050342
Coding: 3D3F1340078002
VCID: 2759FFAFED2D
Component: IMMO 3354
VCID: 356525E72781
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0127
Coding: 0000116
VCID: F4E358E3EC7B
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.0 1302
VCID: 2E570A8BC2D7
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 00E802087F2D8404084F0100
VCID: 306B14F3D8E3
Part No: 1T0 959 702
Coding: 0000116
VCID: F5E565E7E701
Part No: 1K0 035 186 J
Component: Radio GR0 0014
Revision: 0001002S Serial number: VWZ2Z2D1243903
Coding: 0040400
VCID: 2D550D87CFD1
2 Faults Found:
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
00879 - Connection to Speaker Front Right
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0201
Coding: 0000048
VCID: 2F69178FC5DD
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 306B14F3D8E3
Chassis Type: 1K0
Coding: 0000072
VCID: 76E7E2EB7A07
Coding: 0021190
VCID: 3A7F36DB0E9F
VCID: 2F69178FC5DD
VCID: 408B44336843
Coding: 00065493
Shop #: WSC 00000
1 Fault Found:
Coding: 0012341
VCID: F2EF5EFB966F
Coding: 0000042
VCID: 306B14F3D8E3
Coding: 0003101
VCID: 356525E72781
Coding: 0000112
VCID: 326F1EFBD6EF
5 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 26
Reset counter: 35
Mileage: 227441 km
Time Indication: 0
Date: 2000.00.00
Time: 25:45:00
Fault Priority: 0
Fault Frequency: 26
Reset counter: 35
Mileage: 227441 km
Time Indication: 0
Date: 2000.00.00
Time: 25:45:00
Fault Priority: 0
Reset counter: 108
Mileage: 228780 km
Time Indication: 0
Date: 2000.00.00
Time: 23:39:19
Malfunction
Temperature: 40.0°C
Temperature: 49.0°C
VCID: 2759FFAFED2D
VCID: 356525E72781
Coding: 0000116
VCID: F4E358E3EC7B
VCID: 2E570A8BC2D7
Component: KSG 0201
VCID: 306B14F3D8E3
Coding: 0000116
VCID: F5E565E7E701
Coding: 0040400
VCID: 2D550D87CFD1
2 Faults Found:
011 - Open Circuit
Coding: 0000048
VCID: 2F69178FC5DD
Coding: 0000048
VCID: 306B14F3D8E3
