KODOWANIE
Re: KODOWANIE
CECM
LC,17,0,Emergency Brake Flash Light active
LC,17,1,Deactivation of Additional High Beam with Bi-Xenon
LC,17,2,Heated Front Window installed
LC,17,3,Diagnosis Terminal 50 active
LC,17,4,Used DRL-conncetor: 0=lowbeam / 1=fog lights
LC,17,5,Front Fog Lights deactivated with High Beam
LC,17,6,Parking Light Function inactive (USA/Canada)
LC,17,7,Control unit for special function fitted (Additional functions I active)
LC,18,0,Cold Diagnosis License Plate Lights active
LC,18,1,Cold Diagnosis Brake Lights active
LC,18,2,Cold Diagnosis Front Fog Lights active
LC,18,3,Cold Diagnosis Rear Fog Lights active
LC,18,4,Cold Diagnosis High Beam active
LC,18,5,Cold Diagnosis Turn Signals active
LC,18,6,Cold Diagnosis Back-Up Light active
LC,18,7,Cold Diagnosis Side Turn Signals active
LC,19,0,Cold Diagnosis Low Beam active
LC,19,1,Cold Diagnosis Front Parking Lights active
LC,19,2,Cold Diagnosis Rear Parking Lights active
LC,19,3,Diagnosis Rear Parking Lights active
LC,19,4,Diagnosis Terminal 75
LC,19,5,Diagnosis Terminal 15 Motorraum
LC,19,6,Electric Parking Brake installed
LC,19,7,Control unit for special function fitted (Additional functions II active)
LC,20,0-6,1,Daytime Running Lights Dimming
LC,20,0-6,1,Decimal Value (Resolution: 1%)
LC,20,7,unclear/Switchstatus 0=DRL active/1=disabled without tools
LC,21,3,Voltage-dependant PWM(???) 0=active
LC,21,4,Rear Fog Light as Brake Light
LC,21,5,TT Rear light design
LC,21,6,Leaving-Home Variant (0 = LH in LDS / 1 = No LH in LDS)
LC,21,7,Low Beam always active
LC,22,0,Personalization data display protocol(0 = Variant 1 no scroll / 1 = Variant 2 scroll footwelllight 5%)
LC,22,1,DRL in menu (AUDI only)
LC,22,2,Brake Light Deactivation with Rear Fog Light active
LC,22,3,Rear/Brake Light Function active
LC,22,4,Speed dependant Trunk Locking active
LC,22,5,"Light && Sight" Menu inactive
LC,22,6,Rear Parking Lights as Indicators active (North America)
LC,22,7,Diagnosis Rear Brake Lights inactive (North America)
LC,23,0,Xenon Headlights repeated Ignition active
LC,23,1,CAN Data Exchange Format active
LC,23,2,Internal Turn Light Control Algorithm active
LC,23,3~4,00,Turn Lights not active
LC,23,3~4,08,Turn Lights via Fog Lights
LC,23,3~4,10,Turn Lights via High Beam
LC,23,3~4,18,Turn Lights via Xenon Shutter
LC,23,5,Coming-Home Logic (0 = Old / 1 = New)
mexaris
Auto:: Passat 2.0 TDI BMP
Imię:: Krzysztof
Re: KODOWANIE
Post autor: mexaris »
A..... po polsku..? :roll:
PIOTREL
Auto:: 2.0 173Ps BMM mod 2008
Podziękował: 64 razy
Re: KODOWANIE
Post autor: PIOTREL »
:hahaha: ale masz wymagania.
Napisał byś chociaż dziękuję.
Re: KODOWANIE
mexaris pisze:A..... po polsku..? :roll:
:omatko: google... :D a na poważnie, sciągnij i zainstaluj VCDS wersja PL, nastepnie otwórz w "Notatniku" plik ... VCDS/labels/3C0-937-049-30-H.lbl będziesz miał po polsku :)
... niestety komfort i gateway to .clb, wiec w notatniku nie odczytasz, szukaj zrzutów na necie :)
mexaris
Imię:: Krzysztof
Re: KODOWANIE
PIOTREL no kurczę , dziękowałem już w tym temacie chyba ze dwa razy :hahaha: no ale jeszcze raz DZIĘKI ! yox! W każdym razie , o ile właśnie z tym jednym sobie poradziłem , to z pozostałymi dwoma nawet w necie ciężko coś znaleźć.No nic , szukam dalej...
Re: KODOWANIE
... jeśli nie masz swojego kabelka, to podjedż do kogoś i zrób zrzuty ekranu, poszczególnych bajtów w/w sterowników :)
Re: KODOWANIE
Tu masz pliki PL do podmiany labelsy i Lcode.. do vcds
https://drive.google.com/file/d/0B87HOR ... pCSVk/view
mexaris
Imię:: Krzysztof
Re: KODOWANIE
jeżu .... nie wiem co powiedzieć , chyba nikt nigdy nie dziękował tyle razy w jednym temacie , dzięki ! :hahaha:
Re: KODOWANIE
mexaris pisze:jeżu .... nie wiem co powiedzieć , chyba nikt nigdy nie dziękował tyle razy w jednym temacie , dzięki ! :hahaha:
dałbyś koledze "lajka" ;)
gartur
Auto:: TOURAN 2.0 TDI BMT 2011
Podziękował: 17 razy
Re: KODOWANIE
Post autor: gartur »
jeżu pisze:Tu masz pliki PL do podmiany labelsy i Lcode.. do vcds
jeżu, czy podmieniając te pliki w chińskim vcds-ie (16.8.0) istnieje możliwość uwalenia go, czy mogę spać spokojnie? :?
Re: KODOWANIE
Możesz spać spokojnie.. sam interfejs jest dalej w EN
gartur
Re: KODOWANIE
jeżu pisze:Możesz spać spokojnie.. sam interfejs jest dalej w EN
a wgrywając
gartur pisze:
a np. instalując na laptopie vcds 16.8.0 polsko języczną wersję a kabel z ali 16.8.0 EN, dalej nic się nie stanie i będzie ok? :?
Re: KODOWANIE
gartur pisze:... a np. instalując na laptopie vcds 16.8.0 polsko języczną wersję a kabel z ali 16.8.0 EN, dalej nic się nie stanie i będzie ok? :?
... nie będzie OK ;)
jakintos
Auto:: 2.0 TDI/BMM/DSG/140KM/06r
Imię:: jacek
Re: [19] CAN Gateway kodowanie diagnoza VCDS
Post autor: jakintos »
Panowie stałem się (mam nadzieję) szczęśliwym posiadaczem VCDS.
Szukałem ale nie znalazłem regulacji siły świecenia świateł długich H7.
Znalazłem że można je wyłączyć.
Czy taka funkcja istnieje?
Drugie pytanie, zaznaczyłem funkcje coming home ale nie świeci.
Czy to się uruchamia przy zapalonych ksenonach, zgaszeniu silnika i wyciągnięciu kluczka?
Jakby tak było to spale szybko palniki.
Pozdr
Moje światła dzienne: [youtube]https://www.youtube.com/watch?v=4DlGrSXOJZ0[/youtube]
Radio: Icom IC-7000, Magnum S9, Yaesu VX-7R, Baofeng GT-3TP, Uniden 520XL, Uniden 310E
Antena: Santiago 1200. Sirio 1000 Turbo, Nagoya MAG-79E
Γεια σας παιδια!
mexaris
Imię:: Krzysztof
Re: KODOWANIE
A po co Ci siła świecenia długich świateł , one mają świecić ile się da ! Krótkie rozumiem - w opcji świecenia jako światła dzienne (ja mam ustawione na 30 %) może chodzić o oszczędzanie żarówek albo o uruchamianie samochodu(bo uruchamia się na światłach) żeby nie doiły za bardzo akumulatora , ale długie ..? Po co...? Niech świecą i kilometr ! Jednak jeśli chodzi o zmniejszenie siły świecenia krótkich świateł , to ponoć w Twoim przypadku (xenonów) jest to niewskazane.Jeśli zaś chodzi o leaving home , zostawiasz po zgaszeniu silnika auto na tzw światłach i UWAGA - musisz otworzyć i zamknąć drzwi kierowcy! Inaczej nie zadziała.Wtedy zamykasz drzwi pilotem i w zależności od tego co masz ustawione w komputerze , tyle będą świecić światła.Ja mam ustawione na 10 sekund a oryginalnie miałem na 30 sekund.Wszystko do ustawienia...
