Strona 3 z 4
Re: KODOWANIE
: pn lut 27, 2017 10:17
autor: yox
CECM
LC,17,0,Emergency Brake Flash Light active
LC,17,1,Deactivation of Additional High Beam with Bi-Xenon
LC,17,2,Heated Front Window installed
LC,17,3,Diagnosis Terminal 50 active
LC,17,4,Used DRL-conncetor: 0=lowbeam / 1=fog lights
LC,17,5,Front Fog Lights deactivated with High Beam
LC,17,6,Parking Light Function inactive (USA/Canada)
LC,17,7,Control unit for special function fitted (Additional functions I active)
LC,18,0,Cold Diagnosis License Plate Lights active
LC,18,1,Cold Diagnosis Brake Lights active
LC,18,2,Cold Diagnosis Front Fog Lights active
LC,18,3,Cold Diagnosis Rear Fog Lights active
LC,18,4,Cold Diagnosis High Beam active
LC,18,5,Cold Diagnosis Turn Signals active
LC,18,6,Cold Diagnosis Back-Up Light active
LC,18,7,Cold Diagnosis Side Turn Signals active
LC,19,0,Cold Diagnosis Low Beam active
LC,19,1,Cold Diagnosis Front Parking Lights active
LC,19,2,Cold Diagnosis Rear Parking Lights active
LC,19,3,Diagnosis Rear Parking Lights active
LC,19,4,Diagnosis Terminal 75
LC,19,5,Diagnosis Terminal 15 Motorraum
LC,19,6,Electric Parking Brake installed
LC,19,7,Control unit for special function fitted (Additional functions II active)
LC,20,0-6,1,Daytime Running Lights Dimming
LC,20,0-6,1,Decimal Value (Resolution: 1%)
LC,20,7,unclear/Switchstatus 0=DRL active/1=disabled without tools
LC,21,3,Voltage-dependant PWM(???) 0=active
LC,21,4,Rear Fog Light as Brake Light
LC,21,5,TT Rear light design
LC,21,6,Leaving-Home Variant (0 = LH in LDS / 1 = No LH in LDS)
LC,21,7,Low Beam always active
LC,22,0,Personalization data display protocol(0 = Variant 1 no scroll / 1 = Variant 2 scroll footwelllight 5%)
LC,22,1,DRL in menu (AUDI only)
LC,22,2,Brake Light Deactivation with Rear Fog Light active
LC,22,3,Rear/Brake Light Function active
LC,22,4,Speed dependant Trunk Locking active
LC,22,5,"Light && Sight" Menu inactive
LC,22,6,Rear Parking Lights as Indicators active (North America)
LC,22,7,Diagnosis Rear Brake Lights inactive (North America)
LC,23,0,Xenon Headlights repeated Ignition active
LC,23,1,CAN Data Exchange Format active
LC,23,2,Internal Turn Light Control Algorithm active
LC,23,3~4,00,Turn Lights not active
LC,23,3~4,08,Turn Lights via Fog Lights
LC,23,3~4,10,Turn Lights via High Beam
LC,23,3~4,18,Turn Lights via Xenon Shutter
LC,23,5,Coming-Home Logic (0 = Old / 1 = New)
Re: KODOWANIE
: pn lut 27, 2017 10:59
autor: mexaris
A..... po polsku..? :roll:
Re: KODOWANIE
: pn lut 27, 2017 11:12
autor: PIOTREL
:hahaha: ale masz wymagania.
Napisał byś chociaż dziękuję.
Re: KODOWANIE
: pn lut 27, 2017 11:23
autor: yox
mexaris pisze:A..... po polsku..? :roll:
:omatko: google... :D a na poważnie, sciągnij i zainstaluj VCDS wersja PL, nastepnie otwórz w "Notatniku" plik ... VCDS/labels/3C0-937-049-30-H.lbl będziesz miał po polsku :)
... niestety komfort i gateway to .clb, wiec w notatniku nie odczytasz, szukaj zrzutów na necie :)
Re: KODOWANIE
: pn lut 27, 2017 13:37
autor: mexaris
PIOTREL no kurczę , dziękowałem już w tym temacie chyba ze dwa razy :hahaha: no ale jeszcze raz DZIĘKI ! yox! W każdym razie , o ile właśnie z tym jednym sobie poradziłem , to z pozostałymi dwoma nawet w necie ciężko coś znaleźć.No nic , szukam dalej...
Re: KODOWANIE
: pn lut 27, 2017 23:33
autor: yox
... jeśli nie masz swojego kabelka, to podjedż do kogoś i zrób zrzuty ekranu, poszczególnych bajtów w/w sterowników :)
Re: KODOWANIE
: wt lut 28, 2017 09:24
autor: jeżu
Tu masz pliki PL do podmiany labelsy i Lcode.. do vcds
https://drive.google.com/file/d/0B87HOR ... pCSVk/view
Re: KODOWANIE
: wt lut 28, 2017 21:15
autor: mexaris
jeżu .... nie wiem co powiedzieć , chyba nikt nigdy nie dziękował tyle razy w jednym temacie , dzięki ! :hahaha:
Re: KODOWANIE
: wt lut 28, 2017 22:04
autor: yox
mexaris pisze:jeżu .... nie wiem co powiedzieć , chyba nikt nigdy nie dziękował tyle razy w jednym temacie , dzięki ! :hahaha:
dałbyś koledze "lajka" ;)
Re: KODOWANIE
: ndz mar 26, 2017 19:18
autor: gartur
jeżu pisze:Tu masz pliki PL do podmiany labelsy i Lcode.. do vcds
jeżu, czy podmieniając te pliki w chińskim vcds-ie (16.8.0) istnieje możliwość uwalenia go, czy mogę spać spokojnie? :?
Re: KODOWANIE
: ndz mar 26, 2017 19:27
autor: jeżu
Możesz spać spokojnie.. sam interfejs jest dalej w EN
Re: KODOWANIE
: czw mar 30, 2017 18:20
autor: gartur
jeżu pisze:Możesz spać spokojnie.. sam interfejs jest dalej w EN
a wgrywając
gartur pisze:
a np. instalując na laptopie vcds 16.8.0 polsko języczną wersję a kabel z ali 16.8.0 EN, dalej nic się nie stanie i będzie ok? :?
Re: KODOWANIE
: czw mar 30, 2017 19:26
autor: yox
gartur pisze:... a np. instalując na laptopie vcds 16.8.0 polsko języczną wersję a kabel z ali 16.8.0 EN, dalej nic się nie stanie i będzie ok? :?
... nie będzie OK ;)
Re: [19] CAN Gateway kodowanie diagnoza VCDS
: pt maja 19, 2017 20:43
autor: jakintos
Panowie stałem się (mam nadzieję) szczęśliwym posiadaczem VCDS.
Szukałem ale nie znalazłem regulacji siły świecenia świateł długich H7.
Znalazłem że można je wyłączyć.
Czy taka funkcja istnieje?
Drugie pytanie, zaznaczyłem funkcje coming home ale nie świeci.
Czy to się uruchamia przy zapalonych ksenonach, zgaszeniu silnika i wyciągnięciu kluczka?
Jakby tak było to spale szybko palniki.
Pozdr
Re: KODOWANIE
: czw sty 04, 2018 20:56
autor: mexaris
A po co Ci siła świecenia długich świateł , one mają świecić ile się da ! Krótkie rozumiem - w opcji świecenia jako światła dzienne (ja mam ustawione na 30 %) może chodzić o oszczędzanie żarówek albo o uruchamianie samochodu(bo uruchamia się na światłach) żeby nie doiły za bardzo akumulatora , ale długie ..? Po co...? Niech świecą i kilometr ! Jednak jeśli chodzi o zmniejszenie siły świecenia krótkich świateł , to ponoć w Twoim przypadku (xenonów) jest to niewskazane.Jeśli zaś chodzi o leaving home , zostawiasz po zgaszeniu silnika auto na tzw światłach i UWAGA - musisz otworzyć i zamknąć drzwi kierowcy! Inaczej nie zadziała.Wtedy zamykasz drzwi pilotem i w zależności od tego co masz ustawione w komputerze , tyle będą świecić światła.Ja mam ustawione na 10 sekund a oryginalnie miałem na 30 sekund.Wszystko do ustawienia...
