Nie działający spryskiwacz tylnej szyby.
Robertaku
Auto:: Touran 1.9 AVQ, 2003
Imię:: Robert
Re: Nie działający spryskiwacz tylnej szyby.
Post autor: Robertaku »
Wstawiam scan może to ułatwi ocenę problemu...
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
Part No SW: 03G 906 016 A HW: 028 101 073 1
Component: R4 1,9L EDC G000SG 5032
Revision: 12345678 Serial number: VWZ7Z0C7164029
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 214DE1B7814F
No fault code found.
Readiness: 0 0 0 0 0
Part No: 1K0 907 379 D
Coding: 0053958
VCID: 33611BFF2BB3
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 AG
Component: Climatic PQ35 020 0101
Shop #: WSC 00000 000 00000
VCID: 69DDB99739FF
Part No SW: 1K0 937 049 F HW: 1K0 937 049 F*
Component: PQ35 BordnetzSG 1.0 0302
Revision: 12345678 Serial number: 00000000038551
Coding: 10898F000004100000120C000000000000
Shop #: WSC 80093 222 69422
VCID: 326F1EFBD4A9
Part No: 1T0 955 119 A
Component: Wischer WWS A-MPV 0101
Coding: 16711700
Shop #: WSC 80093
1 Fault Found:
Part No SW: 1T0 909 605 HW: 1T0 909 605
Component: 04 AIRBAG VW62 0102 2112
Coding: 0012340
VCID: F2EF5EFB9429
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 007 0030
Coding: 0000042
VCID: 306B14F3DAA5
Part No: 1T0 920 860 A
Component: KOMBIINSTRUMENT VDD 1312
Coding: 0003101
VCID: 2F69178FC79B
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
Part No: 1K0 815 071 A
Component: Zuheizer 0506
Revision: B Serial number: 09006207
Coding: 0000111
VCID: 2341EBBF9B53
Revision: H07 01 Serial number: 230807F2000141
Coding: E9801F06000A028002
VCID: 306B14F3DAA5
Component: IMMO 1312
VCID: 2F69178FC79B
Part No: 1K0 959 701 B
Component: Tuersteuergeraet 08 1915
Coding: 0000052
VCID: 2D550D87CD97
Part No: 1K1 909 144 E
Component: EPS_ZFLS Kl.10 1202
VCID: 2D550D87CD97
Part No: 1K0 959 433 C
Component: KSG 0545
Coding: 00E802087F2D8404084B0100
VCID: 306B14F3DAA5
Part No: 1K0 959 702 B
Coding: 0000052
VCID: 2E570A8BC091
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5P0 035 186 B HW: 5P0 035 186 B
Component: Media2.0 H02 0079
Revision: 01000001 Serial number: SEZ1Z3L4528620
Coding: 01060400040000
Shop #: WSC 04941 000 00000
VCID: 2E570A8BC091
1 Fault Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 92
Mileage: 227965 km
Time Indication: 0
Date: 2000.00.00
Time: 20:05:39
-- 17 lis 2014, o 13:55 --
Proszę o pomoc w ocenie błędów czego dotycząc.
-- 17 lis 2014, o 21:28 --
Proszę o pomoc
thomas_81
Auto:: Touran AVQ 1.9 2004
Post autor: thomas_81 »
Witam mam pytanie odnośnie dyszy spryskiwacza tylnego.Czy może ona w jakiś sposób sie zepsuć,prócz tego że się zapcha?
thomas_81
Thomas_81
Piotr1979
Post autor: Piotr1979 »
Częstą przypadłością systemu spryskiwania tylnej szyby jest uszkodzona (z powodu korozji) rurka mosiężna, która podaje płyn do dyszy .
Symptomy:
-dysza porusza się razem z wycieraczką i słabiej podaje ciśnienie
-zalana płynem wewnętrzna osłona tylnej klapy - niektórzy zwą to chyba tapicerką.
-zalana płynem przestrzeń na koło zapasowe lub zestaw naprawczy.
Szukajcie a znajdziecie.
thomas_81
Ale ja już wszystko sprawdzałem i jak ściągne dysze to leci normalnie a jak założe to nie leci wcale troche to dziwne bo tam jakieś ciśnienie jest to co się z tym płynem dzieje bo pod osłoną tylnej klapy sucho.
thomas_81
Thomas_81
leszeklen
Podziękował: 340 razy
Otrzymał podziękowań: 42 razy
Post autor: leszeklen »
Według mnie jasna sprawa ;)dysza do wymiany. Jest wykonana z amelinium utlenia się.
Wysłane z mojego GT-I9305N przy użyciu Tapatalka
Jest jeszcze inna opcja... Na dyszy oczywiście musi powstać ciśnienie, i ponieważ gdzieś po drodze jest uszkodzony przewód doprowadzający medium myjące, to z dyszy nie leci, tylko wypływa przerwanym, przełamanym przewodem.
Próbowałeś oglądać, a druga osoba pryskać? Może się sączy, a płyn faktycznie gdzieś spierdziela? zdejmij dyszę, zatknij palcem, lekko uchylaj, zobacz jak daleko poleci płyn, to będzie odniesieniem, jak duże ciśnienie wytwarza pompka i czy gdzieś po drodze popuszcza )
maximus82
Auto:: Touran 1.4 TSI 140KM BMY
Post autor: maximus82 »
Sprawdź jak radzi kolega, czy coś dolatuje i czy pod autem nie zostaje mokra plama. Bo jeżeli ucieka to gdzieś musi spływać.
Grzegorz
magic
Auto:: Touran 1.6 MPI 2008
Imię:: Maciej
Otrzymał podziękowań: 48 razy
Post autor: magic »
Albo jeszcze łatwiej... Pożycz dysze od kogoś (sąsiada, kolegi)ważne aby auto było z grupy VAG i będziesz miał klarowny obraz czy dysza jest do d... czy problem jest z przewodach doprowadzajacych plyn
never ever give up
karl
Auto:: BMN,2.0 tdi,2006
Imię:: Karol
Otrzymał podziękowań: 44 razy
Post autor: karl »
Piotr1979 pisze:Częstą przypadłością systemu spryskiwania tylnej szyby jest uszkodzona (z powodu korozji) rurka mosiężna, która podaje płyn do dyszy .
Symptomy:
mozna dokupic sama rurke z kolankiem bo reszta jest dobra
krzysztofn1983
Auto:: Vw Touran 1.9 TDI 2007
Imię:: KRZYSZTOF
Post autor: krzysztofn1983 »
Witam. Czy dysza tylnego spryskiwacza od golfa III(http://allegro.pl/dysza-spryskiwacz-tyl ... 70059.html) będzie pasowała do tourana?
Żuczek
Auto:: TOURAN, 2005
Imię:: Przemek
Post autor: Żuczek »
krzysztofn1983 pisze:Witam. Czy dysza tylnego spryskiwacza od golfa III(http://allegro.pl/dysza-spryskiwacz-tyl ... 70059.html) będzie pasowała do tourana?
z chęcią przyłączę się do przedmówcy - bo mi urwali na parkingu.
A zamiennik 3B9955985A jest trzykrotnie droższy.
Pozdrawiam :)
Johny7205
Podziękował: 69 razy
Otrzymał podziękowań: 60 razy
Post autor: Johny7205 »
Przestał mi działać spryskiwacz tylnej szyby.
1) przedni spryskiwacz lamp i wycieraczek działa
2) tylna wycieraczka działa
3) po przełączeniu manetki na spryskiwanie tylnej szyby słychać cykanie przekaźnika na bordnetzu więc to nie manetka.
Wygląda na to, że pompka nie dostaje napięcia do spryskiwania tylnej szyby.
Co to może być????
W grudniu przekładałem piec Webasto. Może wtyczka na pompce spryskiwcza nie łączy??? Ale wtedy nie było też przednich sprysków chyba??
Może przekaźnik 460??
Podpowiedzcie proszę.
Loszmi
Auto:: BXE, 1.9 Turbo Klekot,'08
Imię:: Miłosz
Post autor: Loszmi »
Podpinam się z pytaniem. Przednie wycieraczki załączają się dopiero jak spryskiwacze namoczą szybę. tak tez jest napisane w instrukcji.
Co z tyłem? U mnie najpierw wycieraczka drapie szybę, a potem zaczyna lecieć. Nie ma opóźnienia załączania wycieraczek.
CrystalDrill
Auto:: 1T1 1.6MPI BGU 2004
Imię:: Bartosz
Post autor: CrystalDrill »
Ja mam inny problem. Dziś po mrozach chciałem użyć tylniego spryskiwacza i woda zaczęła ciec przez podsufitkę przy szybie. Teraz pół sufitu mam w płynie do spryskiwacza. Muszę znaleźć manual jak się tam dostać ;(
