kamera cofania
trix
- Auto:: 2.0 TDI-CFHC- 2011
- Podziękował: 7 razy
Re: kamera cofania
Cały Auto-Skan
Radio mam chwilowo włożone od multivan`a i nie podłączone anteny FM, więc jest błąd
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFHC) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 DR HW: 03L 907 309 R
Component: R4 2,0L EDC H23 7451
Revision: 42H23--- Serial number: 00000000000000
Coding: 001D001A043400080000
Shop #: WSC 01324 020 00200
ASAM Dataset: EV_ECM20TDI01103L906018DR 003003
ROD: EV_ECM20TDI01103L906018DR_VW36.rod
VCID: 7D14257BE4FEF6FAAED834-8028
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 054 J HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2602
Revision: 05351112 Serial number: 00001012301166
Coding: 0000020
VCID: 1DD405FB04BE9EFACE1814-8048
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 323B601609280E034C1206E790207042350000
VCID: 76063A57C1C8ADA2EFA243-8022
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 EC HW: 5K0 907 044 EC
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000002
VCID: 700A0C4FA3AC8B92355E85-8024
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 M HW: 5K0 937 087 M
Component: BCM PQ35 H 011 0046
Revision: BE011001
Coding: 40180A38E8251AE040080080740011EC477D9008736DA560E48042000048
VCID: 3F689F73AE722CEAFC44EE-806A
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 13011 26 0512
Coding: 009795
Component: RLS 250111 05 54 0403
Coding: 0330ED
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 5N0 919 475 D HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0045
Revision: -------- Serial number: 32991102529254
Coding: 118101
ASAM Dataset: EV_EPHVA14VW3680000 001005
ROD: EV_EPHVA14VW3680000.rod
VCID: 3A9EEE67B55001C2CB7AD7-806E
Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
Component: 02 AIRBAG VW8 022 0100
Revision: 02022000 Serial number: 003K4D0200UT
Coding: 0012338
VCID: 3798F7538642D4AA341436-8062
Subsystem 1 - Serial number: 6332QSME317427100
Subsystem 2 - Serial number: 6342QSME177E0D28S
Subsystem 3 - Serial number: 6352QSME48003E4EO
Subsystem 4 - Serial number: 6362QSME440050764
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 AT HW: 5K0 953 569 H
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20110125300604
Coding: 199A140000
VCID: 7C12287FFFE4FFF299E601-8028
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Coding: 830000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1T0 920 881 A HW: 1T0 920 881 A
Component: KOMBI H05 0206
Coding: 181F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 328EC6476D20F98203CA7F-8066
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 A
Component: Standheizer 043 4730
Revision: 00043000 Serial number: 09022127000000
Coding: 0031012
Shop #: WSC 09294 002 1048576
VCID: 3380C343923A388A083C62-8066
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 250111F2000315
Coding: 356002
VCID: 318CC94B6826CA9A7AD048-8064
Component: IMMO H05 0206
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6A3E1E27857071427B1AC7-803E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 7E0 035 686 HW: 7E0 035 686
Component: RNS-MID H09 5274
Revision: AB001001 Serial number: VWZ6Z7R6875713
Coding: 00070000010000A10000
Shop #: WSC 00816 100 10954
VCID: 683A642F9B7C4B526D2E2D-803C
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V13 8348
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 5
Reset counter: 186
Mileage: 135424 km
Time Indication: 0
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 5
Reset counter: 186
Mileage: 135424 km
Time Indication: 0
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2121
Coding: 0000245
VCID: 487A84AFFBBCAB524DEE4D-801C
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.294 0802
Revision: 1AH03729 Serial number: 00110110356901
Coding: 0000258
VCID: 3B90EB63BA6AF0CAD06CDA-806E
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218109111807
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 6738671396624C2A643426-8032
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000245
VCID: 47788793F6A2A42A44F446-8012
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 E HW: 7L6 907 357 C
Component: AFS-ECU H04 0080
Revision: -------- Serial number: --------------
Coding: 030200000F000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002006
ROD: EV_HeadlRegulVWAFSPt_SE36.rod
VCID: 3686FA578148E5A22F2203-8062
Left_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0002
Coding: 320000
Right_headlamp_power_output_stage:
Subsystem 2 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0002
Coding: 320000
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
2 Faults Found:
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 5
Reset counter: 186
Mileage: 135424 km
Time Indication: 0
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 5
Reset counter: 186
Mileage: 135424 km
Time Indication: 0
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: E100085A
VCID: 710C094BA8A68A9A3A5088-8024
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2104
Coding: 0000208
Shop #: WSC 01324 020 1012551
VCID: 328EC6476D20318203CA7F-8066
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000140389063
Coding: 410D000100000000
VCID: 308ACC4F632CC39275DE45-8064
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C9 907 441 HW: 3C9 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525PA8-J340412
Coding: 0020007
Shop #: WSC 05311 000 00000
VCID: 683A642F9B7C8B526D2E2D-803C
1 Fault Found:
01043 - Control Module; Incorrect Software Version
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Time Indication: 0
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000208
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0982
Revision: -------- Serial number: 35502105095304
Coding: 020000010100010000000100
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_SE36.rod
VCID: 24A2301F27D467328156D9-8070
End-------------------------(Elapsed Time: 03:46)--------------------------
Coding: 0000020
Revision: 00H31001
Revision: 00003001
Coding: 0000000002
Revision: BE011001
Coding: 009795
Coding: 0330ED
Coding: 118101
Coding: 0012338
Coding: 199A140000
Coding: 830000
Coding: 181F01
Coding: 0031012
Coding: 356002
Coding: 000000
2 Faults Found:
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 5
Reset counter: 186
Mileage: 135424 km
Time Indication: 0
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 5
Reset counter: 186
Mileage: 135424 km
Time Indication: 0
Coding: 0000245
Coding: 0000258
Coding: 0000245
Coding: 320000
Coding: 320000
2 Faults Found:
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 5
Reset counter: 186
Mileage: 135424 km
Time Indication: 0
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 5
Reset counter: 186
Mileage: 135424 km
Time Indication: 0
Coding: E100085A
Coding: 0000208
Coding: 0020007
1 Fault Found:
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Time Indication: 0
Coding: 0000208
Mój Norweski Turek ==> Highline 2011r - 2.0 TDI CFHC - 7os<==
- yox
- Podziękował: 240 razy
Re: kamera cofania
Nie chce Cie martwic, ale prawdopodobnie modul od passata nie 'zagra', musisz poszukac np od Tiguana:
Part No SW: 5N0 907 441 A HW: 5N0 907 441 A
Component: J772__Rearview 0030
Revision: 00H11000 Serial number: 525PA8-J344076
Coding: 0000010
Shop #: WSC 12345 123 12345
VCID: 2D56919BB4029956C6-8078
Coding: 0000010
Re: kamera cofania
moze zawsze sprawdzic kodowanie Gateway na Passat + kodowanie RVC na Passat
Albo Kodowanie na Sharan, o ile 3C9 to przyjmie
trix
Re: kamera cofania
A czy od nowego tourana będzie działał moduł? Czy to inna platforma tak jak golf VII
Re: kamera cofania
to samo co golf 7trix pisze:A czy od nowego tourana będzie działał moduł? Czy to inna platforma tak jak golf VII
trix
Re: kamera cofania
Sterownik zmieniony na 5N0 907 441 A i zakodowany tak jak Yox pisał
W sterowniku 10 parktronik trzeba było jeszcze zaznaczyć kamerę.
Teraz po włączeniu wstecznego pojawia się obraz, a po lewej stronie obrazu jest autko z wizualizacją z czujników
trix
Re: kamera cofania
Mam jeszcze jeden mały problem
Sterownik jest podobno nowy i mam błąd związany z adaptacją. Jak się go pozbyć? Jakie adaptacje mam wykonać?
Spacewalker pisał że dla tourana się nie da ale może dla tiguana?
trix
Re: kamera cofania
Ehhh myślę o jednym piszę o drugim
Oczywiście kalibracji
Revision: 00H13000 Serial number: 525PA8-J399704
Coding: 0030010
Shop #: WSC 98765 666 38384
VCID: 2DB4EABB741E6E7A5EF8A4-8078
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 192
Time Indication: 0
Coding: 0030010
1 Fault Found:
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 192
Time Indication: 0
Re: kamera cofania
ale co się nie da ?trix pisze:Mam jeszcze jeden mały problem
jak masz błąd kalibracji - to kalibruj i po problemie,.
Temat od lat znany i w 100% wykonywalny
trix
Re: kamera cofania
Nigdy tego nie robiłem i nie mam pojęcia jak się za to zabrać
Może ktoś pomoże z tym
Re: kamera cofania
http://a6forum.pl/kalibracja-kamery-cof ... t1492.htmltrix pisze:Nigdy tego nie robiłem i nie mam pojęcia jak się za to zabrać
- Matys
- Auto:: 1T3 1.6 TDI, DSG 2011
- Imię:: Adam
- Podziękował: 12 razy
Re: kamera cofania
Podłącze się pod temat, czy kamera 5C6827566 będzie pasowała do 1T3 na zasadzie Plug and Play? Chce to podłączyć do RNS510. Mam możliwość taka kupić i się zastanawiam czy będzie to lepsza opcja od chińczyka...
