RCD 510 z chin kodowanie
Vidette
Auto:: Touran 1.9 2004
Imię:: Kamil
Post autor: Vidette »
Mam problem z kodowaniem chińskiego rcd 510 a mianowicie w VCDS 11.11.3 nie mam dostępnych opisów ponad to cały czas chodzi zmieniarka i nie mam aktywnego modułu cd. Gateway wymieniony na L Proszę o pomoc:
Sunday,29,March,2015,13:31:36:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ5W003542 Mileage: 164650km/102308miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
56-Radio -- Status: Not registered 0011
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L EDC G000SG 6246
Revision: 12345678 Serial number: VWZ7Z0D9936911
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 67D7A5455676F51
No fault code found.
Readiness: 0 0 1 1 1
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021190
VCID: 3A712C317544B89
Part No: 1K0 907 044 K
Component: ClimatronicPQ35 061 0201
Shop #: WSC 00000 000 00000
VCID: 2F670D65BE066D1
Address 09: Cent. Elect. Labels: User\3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000797406
Coding: 01890F020004200000120C000000000000
VCID: 40855ED91398E29
Coding: 00065493
Shop #: WSC 00000
Part No SW: 1T0 909 605 B HW: 1T0 909 605 B
Component: 02 AIRBAG VW62 0506 1400
Revision: 07023000 Serial number: 0037SD0744YE
Coding: 0012338
VCID: 346D020957204E9
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000042
VCID: 30650E19A338729
Address 17: Instruments Labels: User\1K0-920-xxx-17.lbl
Part No: 1T0 920 861 A
Component: KOMBIINSTRUMENT VDD 0714
Coding: 0003103
Shop #: WSC 00448 264 89436
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K078200349
Coding: E9807F060000028002
Shop #: WSC 04941 785 00200
2 Faults Found:
01305 - Databus for Infotainment
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 151
Mileage: 164652 km
Time Indication: 0
Date: 2000.00.00
Time: 12:11:58
000 - -
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 111
Mileage: 164652 km
Time Indication: 0
Date: 2000.00.00
Time: 12:12:03
Component: IMMO VDD 0714
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0157
Coding: 0000116
VCID: F4ED420997A08E9
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.6 1301
VCID: 2E591061B90C649
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 00E802087F2D8404084F0100
Shop #: WSC 00025 264 06910
Part No: 1T0 959 702
Coding: 0000116
VCID: F5EB7F0D9CDA971
Address 56: Radio (J503) Labels: None
Part No SW: 56D 035 190 A HW: 56D 035 190 A
Component: RCD510USBRVC 001 0003
Revision: -----001 Serial number: VWZ4Z3N8102995
Coding: 0100046404000B
Shop #: WSC 00078 790 00192
VCID: 2241F4513DD4D09
6 Faults Found:
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Mileage: 164652 km
Time Indication: 0
Date: 2000.00.00
Time: 11:38:24
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Mileage: 164652 km
Time Indication: 0
Date: 2000.00.00
Time: 11:38:24
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Mileage: 164652 km
Time Indication: 0
Date: 2000.00.00
Time: 11:38:26
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Mileage: 164652 km
Time Indication: 0
Date: 2000.00.00
Time: 11:38:26
01317 - Control Module in Instrument Cluster (J285)
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 111
Mileage: 164652 km
Time Indication: 0
Date: 2000.00.00
Time: 11:38:23
00856 - Radio Antenna
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Mileage: 164652 km
Time Indication: 0
Date: 2000.00.00
Time: 11:38:23
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0201
Coding: 0000048
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
Re: RCD 510 z chin kodowanie
Bramkę trzeba poprawnie zakodować.... to raz..
Wrzuć do katalogu labels taki plik i zobacz czy masz podpowiedzi..Rozpakuj wcześniej
5M0-035-1xx-56.rar
(6.49 KiB) Pobrany 139 razy
Zrób tak jak Jeżu napisał.
Tu masz temat o kodowaniu Gateway, znajdź ten z literką "L" i zobacz czy w swoim masz zakodowane Bajt 5 bit 1 [56] Radio (analog), i czy przypadkiem nie masz zaznaczoną nawigację Bajt 4 bit 6 [37] Navigation
http://touranklub.pl/forum/viewtopic.php?t=1745
Co do VCDS-a to wgraj pliczek i może będą się pokazywać opisy.
bogus5marcin
Auto:: Touran 1.9 BKC
Post autor: bogus5marcin »
Co do RCD 510 z chin istnieje jeszcze taki problem, że ryżowe kabelki maja problem z kodowaniem tego radyjka. Jak juz dorzucisz do biblioteki pliki które otrzymałeś od Tomka i ujrzysz przy próbie kodowanie napis "Out of range" lub coś podobnego oznacza to że twoja wersja radia ma SW które poprawnie zakodujesz tylko oryginalnym VCDS'em (lub ewentualnie ryżowym w wer. 12.12). Chinole sporo zmienili w radyjkach RCD510 od 2013 roku, a z twojego skanu i wersji wnioskuje, że masz radio z roku 2013 ponieważ masz je w wersji A czyli poprawionej pod względem SW w działaniu BT i jeszcze paru rzeczy.
Vidette
Imię:: Kamil
Zrobione, radio [56] zaznaczone plik skopiowane niestety problem pozostał. do kabelka 11.11.3 raczej nie da rady aktualizować oprogramowanie ? Ewentualnie ktoś ze śląska jest w posiadaniu takiej wersji ?? Jakieś inne rozwiązanie?
Ewentualnie wrzuciłby ktoś jak wyglądają podpisane bajty ?
Tak to wyglądało w radiu bez A na końcu...
Kodowanie własnie robiłem kiedys na takiej wersji jak masz i po dograniu pliku było ok..
na wer 12.12.3 nie trzeba nic...
bogus5marcin
Ewentualnie jeżeli nadal będziesz mieć problem z zakodowaniem radia tzn nie przyjmie to wprowadź radio w tryb serwisowy.
Adaptacje -> kanał 50 => wartość 0 zmień na 1,następnie TEST i jeżeli ok to ZAPISZ
Dla pewności wyjmij kartę SD z czytnika bo jeżeli będzie na niej jakiś plik .bin radio może (lecz nie musi) przejść w tryb aktualizacji SW
SBL
Auto:: 1T2 1.9TDI BXE 2008r
Imię:: Sławek
Post autor: SBL »
Aby VCDS widział poprawne opisy kodowania potrzebuje w katalogu Labels pliku o nazwie 56-56.lbl w którym jest przekierowanie do pliku z opisem kodowania 5M0-035-1xx-56.clb. Rozpakuj zamieszczone pliki i skopiuj je do katalogu Labels i wtedy sprawdź czy będą widoczne opisy kodowania dla tego radia.
56D035190A.zip
(4.47 KiB) Pobrany 155 razy
