problemy z ogrzewaniem - logi z VCDS
wladek0706
Auto:: VW TOURAN 1.9 TDI SE 2005
Imię:: wladek
Post autor: wladek0706 »
Rozkmini mi ktoś poniższe logi z VCDS'a?
Thursday,21,May,2015,17:20:55:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: -------------
15-Airbags -- Status: Malfunction 0010
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L EDC G000SG 6246
Revision: 12345678 Serial number: ------------
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 67DD5D1756980F26359-8032
6 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
RPM: 378 /min
Torque: 170.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 00001100
Temperature: 6.3°C
Bin. Bits: 01110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
RPM: 378 /min
Torque: 170.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 00001100
Temperature: 6.3°C
Bin. Bits: 01110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
RPM: 378 /min
Torque: 170.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 00001100
Temperature: 6.3°C
Bin. Bits: 01110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
RPM: 378 /min
Torque: 170.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 00001100
Temperature: 6.3°C
Bin. Bits: 01110000
16725 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
RPM: 945 /min
Torque: 70.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00001100
Idle Stabilization: 0.0°KW
(no units): 48.0
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High - Intermittent
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00001100
Temperature: 24.3°C
Temperature: 18.9°C
Readiness: 0 0 0 0 0
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Revision: 00T12001
Coding: 0021190
VCID: 408FA68B1376181ED43-8015
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DF
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 6BD521274A702B46511-803E
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005008707
Coding: 00890F210004100000120C000000000000087B075C
VCID: 2A5BE423850AF24EEA7-807F
Coding: 00065493
Shop #: WSC 01324
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0DXSCZ
Coding: 0012338
VCID: 3561C75F5CB4ADB6775-8060
1 Fault Found:
00532 - Supply Voltage B+
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 634 0070
Coding: 0000042
VCID: 76E300530132E6AEBEF-8023
Address 17: Instruments
Cannot be reached
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Coding: 0000011
5 Faults Found:
000 - - - Intermittent
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 9
Reset counter: 225
Mileage: 240778 km
Time Indication: 0
Date: 2000.00.00
Time: 05:27:14
Malfunction
Temperature: 205.0°C
Temperature: 85.0°C
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 0
Fault Frequency: 23
Reset counter: 226
Mileage: 241434 km
Time Indication: 0
Date: 2000.00.00
Time: 17:10:45
OFF
Temperature: 53.0°C
Temperature: 71.0°C
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 19
Reset counter: 157
Mileage: 174608 km
Time Indication: 0
Date: 2000.00.00
Time: 28:09:19
01305 - Databus for Infotainment
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 36
Mileage: 139649 km
Time Indication: 0
Date: 2000.00.00
Time: 12:23:48
intryguje mnie zwłaszcza błąd:
czy przez ten czujnik mogę mieć problemy z nawiewem i układem chłodzenia silnika? co to powoduje?
Ostatnio zmieniony śr maja 27, 2015 22:48 przez wladek0706, łącznie zmieniany 1 raz.
Re: problemy z ogrzewaniem - logi z VCDS
wladek0706 pisze: 18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
Dopisuj się do istniejących wątków to po pierwsze ;)
po drugie to błąd czujnika dający sygnał na wentylator nie włączają Ci się przypadkiem od razu?
po trzecie wymień termostat to nie majątek a może pomóc
wymień również pompkę v55 i odblokuj piec webasto nie wiem jaka u was temp teraz ale jak będzie poniżej 4 st to szybciej się nagrzeje dzięki sprawnemu
wladek0706
Imię:: wladek
JEDARO pisze:
nie dopisałem do nowego wątku, bo ostatnio uczyniłem to dwukrotnie i bez odpowiedzi przez 3 dni post został ;)
wentylator nie włącza się od razu, ale nazbyt często włącza się po rozgrzaniu silnika, a do tego czasem trudno jest załapać temperaturę w chłodniejszy poranek
coś czuję, że cały układ chłodzenia jest do przejrzenia i podmianek - czyli nowe czujniki, pompa wody od webasto, termostat i nowy płyn do zalania ech...
wielkie dzięki za odpowiedź i sorry za założenie nowego tematu :)
