Czy ktoś ma jakiś pomysł co to może być, albo od czego zacząć ?
Gdzie w tych touranach może być umieszczony moduł AFS'u ?
Poniżej zamieszczam autoscan:
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AS HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 7003
Revision: -------- Serial number: 00000000000000
Coding: 00194036032401080000
Shop #: WSC 12345 123 23456
ASAM Dataset: EV_ECM16TDI02103L906023AS 003002
ROD: EV_ECM16TDI02103L906023AS.rod
VCID: 77E4FB7F9FCDBD3A2ECAF51-8022
No fault code found.
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 323B401609220EFA4C1102E590197051350000
VCID: 041E9CB3DE1BE6223B48FA5-8050
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 A HW: 7N0 907 426 A
Component: AC Manuell H15 0101
Revision: 00010001
Coding: 0000000003
Shop #: WSC 01324 020 00200
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 32720A6B342F9812D994FCD-8066
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AB HW: 5K0 937 087 AB
Component: BCM PQ35 H 122 w171
Revision: BE122001
Coding: 48180A38802500E000C800C0150089644BFD9008624DA5BBE484C3000049
VCID: 75F8F17785C1CFAA3CF6DF9-8020
Subsystem 1 - Part No: 1T1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 13051 21 0512
Coding: 009FB5
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 5N0 919 475 D HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0045
Revision: -------- Serial number: 32901225103201
Coding: 108001
ASAM Dataset: EV_EPHVA14VW3680000 001005
ROD: EV_EPHVA14VW3680000.rod
VCID: 3A62224BEC5F6052112454D-806E
Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
Component: 02 AIRBAG VW8 022 0100
Revision: 02022000 Serial number: 003K4D000S3S
Coding: 0012338
VCID: 37643B7FDF4D71BAEE4AB51-8062
Subsystem 1 - Serial number: 6332QSME66614F36M
Subsystem 2 - Serial number: 6342QSME7A600536D
Subsystem 3 - Serial number: 6352QSME3B581332D
Subsystem 4 - Serial number: 6362QSME3C582920J
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 DM HW: 5K0 953 569 AP
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20131217200874
Coding: 110A160000
VCID: 78E6F84392D3B24227D0FE5-802C
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1T0 920 871 D HW: 1T0 920 871 D
Component: KOMBI H04 0404
Coding: 181F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 347E0C73CE3B9622CB68EA5-8060
Part No: 5K0 963 271 C
Component: Zuheizer 051 2606
Revision: 00051000 Serial number: 09021535000000
Coding: 0000011
Shop #: WSC 01324 785 00200
VCID: 2F74031F271DB97AB6BADD1-807A
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 0602
Revision: H25 Serial number: 120510F2001233
Coding: E9A17F06400A1204008002
VCID: 2E4A1E1B2017B072BDAC28D-807A
Component: IMMO H04 0404
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AC2D20BDC7F10D2A14444D-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663249125
Coding: 030100
VCID: 2A42120B1CFFD05261C404D-807E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 B
Component: RNS-MID H04 3810
Revision: AB001001 Serial number: VWZ6Z7J2250014
Coding: 0C000000040000A52007
VCID: 2F74031F271DB57AB6BADD1-807A
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2111
Coding: 0131253
VCID: 48864883A2B30E4297B0CE5-801C
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.0 1101
Revision: 1AH03728 Serial number: 00101270089201
Coding: 0000258
VCID: 3B6C274FE36555DA0A32591-806E
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0131253
VCID: 47844BBFAFAD013A9EAAC51-8012
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 090000000D000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_SE36.rod
VCID: 37643B7FDF4D7D3AEE4AB51-8062
Left_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0007
Coding: 320000
Right_headlamp_power_output_stage:
Subsystem 2 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0007
Coding: 320000
1 Fault Found:
5275648 - Left/Right Driving Switch-Over Active
C1080 00 [009] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 24
Mileage: 96843 km
Date: 2016.12.05
Time: 18:01:29
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H25 0602
Coding: 030B185A
VCID: 71F0C567F1A9E38AE00E0B9-8024
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2104
Coding: 0131216
Shop #: WSC 01324 020 1012552
VCID: 32720A6B342F9492D994FCD-8066
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0131216
VCID: 337C0F6FCB359D9AD262E11-8066
End-------------------------(Elapsed Time: 02:38)--------------------------
-- Cz gru 08, 2016 11:49 --
Czy nikt nie ma żadnego pomysłu ?
-- Cz gru 08, 2016 15:00 --
Chyba, że ktoś chciałby się podjęć naprawy (oczywiście nie za darmo).
