Touran 1.9 TDI 101 KM - błędy 1411 i 1409
: sob wrz 23, 2017 12:55
Tak jak w temacie pacjent Touran 1.9 TDI 101 KM
Błędy z Vaga poniżej Czy ktoś z Was wie gdzie znajduje się czujnik temperatury G18 i jak się do niego dostać
Thursday,07,September,2017,16:03:28:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Address 18: Aux. Heat Labels: 1K0-815-007.CLB
Control Module Part Number: 1K0 815 007 R
Component and/or Version: Standheizer 011 1403
Software Coding: 0000112
Work Shop Code: WSC 42684 126 88683
VCID: 3365F94752C0B386591-8066
2 Faults Found:
01411 - Temperature Sensor (G18)
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 3
Reset counter: 200
Mileage: 248071 km
Time Indication: 0
Date: 2000.00.00
Time: 16:00:23
Ctrl. Pause
Temperature: 205.0°C
Temperature: 55.0°C
01409 - Repeated Flame-Out
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 200
Mileage: 248071 km
Time Indication: 0
Date: 2000.00.00
Time: 16:00:23
Malfunction
Temperature: 55.0°C
2 Faults Found:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 200
Mileage: 248071 km
Time Indication: 0
Date: 2000.00.00
Time: 16:00:23
Ctrl. Pause
Temperature: 55.0°C
Fault Priority: 0
Fault Frequency: 1
Reset counter: 200
Mileage: 248071 km
Time Indication: 0
Date: 2000.00.00
Time: 16:00:23
Malfunction
Temperature: 55.0°C
