kodowanie
rafi
kodowanie
Post autor: rafi »
Panowie, kto mi pomoze dobrze zakodowac auto. Dzisiaj przeskanowalem i wyskoczyly mi takie bledy:
VIN: WVGZZZ1TZ5W005159
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Not registered 0001
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Part No SW: 03G 906 016 DK HW: 028 101 194 6
Component: R4 1,9L EDC G000AG 6247
Revision: 12345678 Serial number: VWZ7Z0D9957354
Coding: 0000078
Shop #: WSC 01324 785 00200
VCID: 6FE9D78F070D
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 R HW: 02E 927 770 AD
Component: GSG DSG 041 0812
Revision: 00004010 Serial number: 00000405140369
Coding: 0000020
VCID: 214DE1B78159
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021190
VCID: 3A7F36DB0CCF
Part No: 1K0 907 044 BE
Component: ClimatronicPQ35 090 0808
Shop #: WSC 00000 000 00000
VCID: 6BD1C39F3315
2 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - -
01274 - Air Flow Flap Positioning Motor (V71)
000 - -
Revision: 00H54000 Serial number: 00000001071499
Coding: AB888E2010041500C70F0C006400000000097F075540012C000000000000
Shop #: WSC 00066 000 00000
VCID: 33611BFF2BA5
Part No: 1T0 955 119 C
Coding: 00065493
Shop #: WSC 00066
Part No SW: 1T0 909 605 B HW: 1T0 909 605 B
Component: 02 AIRBAG VW62 0506 1400
Revision: 07023000 Serial number: 0037SD07J1G8
Coding: 0012338
VCID: 346318E32EAB
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0010042
VCID: 306B14F3DAB3
Part No: 1T0 920 861 A
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0005101
Shop #: WSC 00852 218 71509
VCID: 306B14F3DAB3
Part No: 1K0 815 071 P
Component: Zuheizer 031 1312
Coding: 0000012
Shop #: WSC 00535 218 78585
VCID: 326F1EFBD4BF
Revision: H07 01 Serial number: 010208F1001115
Coding: ED817F0E0002028002
Shop #: WSC 00111 111 45725
VCID: 306B14F3DAB3
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Mileage: 281005 km
Time Indication: 0
Date: 2000.00.00
Time: 00:38:19
Component: IMMO VDD 0814
VCID: 306B14F3DAB3
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0157
Coding: 0000116
VCID: F4E358E3EE2B
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.0 1401
VCID: 2F69178FC78D
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 18E802087F2D8404084F0100
Shop #: WSC 00535 218 72566
VCID: 306B14F3DAB3
Part No: 1T0 959 702
Coding: 0000116
VCID: F5E565E7E551
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0002
Coding: 0000001
VCID: F4E358E3EE2B
Address 56: Radio (J503) Labels: None
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 042 0082
Revision: 00000001 Serial number: VWZ1Z2M4269823
Coding: 01000400000005
Shop #: WSC 00028 028 00001
VCID: 72EFDEFB143F
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0201
Coding: 0000048
VCID: 2F69178FC78D
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
VCID: 306B14F3DAB3
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 02 Einparkhilfe 0101
VCID: 2D550D87CD81
VW Touran 1,9 TDI 2005r. DSG
Wymieniales cos?,np webasto?
rafi
Post autor: rafi »
lock00 pisze:Wymieniales cos?,np webasto?
Nie wymienialem webasta.
Wymienione zostalo radio rcd 300 na rcd 310 z 2012r. gateway na nowszy model L i Bordnetz na nowszy.
Ostatnio zmieniony śr sie 22, 2012 07:05 przez rafi, łącznie zmieniany 1 raz.
rafi pisze: gateway na nowszy model L
I tu coś źle zakodowałeś. Sprawdzić dokładnie co autko miało i to samo na nowym pomagają zrzuty ekranowe każdego Bajta. :mrgreen:
rafi
Post autor: rafi »
jeżu pisze:
Wszystko robil Jarry na spocie w warszawie, nie bylo za duzo czasu i to moze dlatego, ale i tak mu bardzo dziekuje za pomoc.
Potrzebowalbym rozkodowanie nr VIN i na tej podstawie zakodowac. Moglby ktos mi pomoc w tej sprawie?
rafi pisze:Potrzebowalbym rozkodowanie nr VIN i na tej podstawie zakodowac.
Nie da się odczytać po vinie jakie miałeś kodowanie.... Tym bardziej wklepać do nowego Gatewaya zwłaszcza że funkcje mogą być w innym "miejscu" w kodowaniu....
Skoro byla wymieniana bramka to moze na szybkosci Jarry cos nie zakodowal , na szybko zawsze cos moze umknac, robione byly screeny kub zapisywane co masz?
Jaka masz wersje touranka? i rocznik? i jaki miales wczesniejszy getway?
Ostatnio zmieniony pn sie 20, 2012 23:16 przez lock00, łącznie zmieniany 1 raz.
rafi
Post autor: rafi »
jeżu pisze:
To jak teraz moge prawidlowo zakodowac gateway? Metoda prob i bledow?
A nie możesz włożyć stary porobić zrzuty ekranu, a następnie włożyć nowy i ponownie zakodować ?
Jakbys napisal jaka masz wersje to mysle ze szybciutko bez podlaczania starego by sie doszlo :)
lock00 pisze:Jakbys napisal jaka masz wersje to mysle ze szybciutko bez podlaczania starego by sie doszlo
W jaki sposób? Wiesz co ma w aucie ? Co zakodował a co nie....? :omatko:
jeżu pisze:W jaki sposób? Wiesz co ma w aucie ? Co zakodował a co nie....? :omatko:
mam na mysli podstawy aby nie wykazywaly bledow, a jak cos dodatkowo zakodowal to pozniej wyjdzie i wie gdzie grzebac czyz zle mowie?
lock00, Używasz Vcdsa? Nie ma Czegoś takiego by zakodować podstawowe wyposażenie auta i później dodawać i sprawdzać czy są błędy.... Trwało by to bardzo długo... Zrzuty ekranowe dużo pomagają... a podmienić na starego gatewaya i je zrobić to naprawdę nie dużo pracy...
jeżu pisze:ock00, Używasz Vcdsa? Nie ma Czegoś takiego by zakodować podstawowe wyposażenie auta i później dodawać i sprawdzać czy są błędy.... Trwało by to bardzo długo... Zrzuty ekranowe dużo pomagają... a podmienić na starego gatewaya i je zrobić to naprawdę nie dużo pracy..
:omatko: owszem masz racje Ty to wiesz i ja wiem , ja kodowalem metoda prob i bledow(chociaz screena mialem z wszelkim kodowaniem i wertowalem co i jak) i majac standard bez wiekszych problemow sie zakodowalo , kolega zapytal metoda prob i bledow podal by model auta itp.. i mozna dojsc, to tak samo jak tez kodowalem pompe abs nie znajac szczegolow poprzedniej a standardowe kodowanie bylo inne ,ale inni co maja ten sam model podaja kodowanie i wszystko gra i buczy :) , tez mozna byloby przepiac i spisac byloby pewnie prosciej i szybciej, ale ja pracujac zawsze trzymam sie zasady jesli da sie cos zrobic informatycznie to sie robi(taka praca i zdecydowanie mniej sie na chodze....) a pozniej dopiero srubokret w reke, ale czasem srubokret jest szybszy, ale nie trzeba sie ruszac z siedzenia :P
rafi
Post autor: rafi »
No i udalo mi sie :) oto wynik
Friday,24,August,2012,18:58:25:10074
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 18 19 25 42 44 46 52 55 56 62 72 76
76-Park Assist -- Status: Malfunction 0010
Coding: 0000078
VCID: 6FE9D78F070D
Coding: 0000020
VCID: 214DE1B78159
Coding: 0021190
VCID: 3A7F36DB0CCF
VCID: 6BD1C39F3315
3 Faults Found:
00402 - Auxiliary Air Heater Element (Z35)
000 - -
000 - -
Coding: AB888F2011041500C70F0C006400000000097F075540010C000000000000
VCID: 33611BFF2BA5
Coding: 00065493
Shop #: WSC 00066
Coding: 0012338
VCID: 346318E32EAB
Coding: 0010042
VCID: 306B14F3DAB3
Coding: 0005101
VCID: 306B14F3DAB3
Coding: 0000012
VCID: 326F1EFBD4BF
Coding: ED817F0E000A028002
VCID: 306B14F3DAB3
VCID: 306B14F3DAB3
Coding: 0000116
VCID: F4E358E3EE2B
VCID: 2F69178FC78D
Component: KSG 0201
VCID: 306B14F3DAB3
Coding: 0000116
VCID: F5E565E7E551
Coding: 0000001
VCID: F4E358E3EE2B
VCID: 72EFDEFB143F
Coding: 0000048
VCID: 2F69178FC78D
Coding: 0000048
VCID: 306B14F3DAB3
VCID: 2D550D87CD81
2 Faults Found:
00436 - Left Rear Inner Parking Aid Sensor (G334)
009 - Open or Short to Ground
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
006 - Short to Plus
